Question about Canon PowerShot A75 Digital Camera
Camera won't turn on
Hi - our canon powershot a75 has been great for years, but now it won't turn on. we tried changing the batteries, but it still won't work. help!
  • Canon Master
  • 4,738 Answers
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Posted on Jan 20, 2009
Have a 4-5 yr old Canon S2 IS PowerShot A75 Digital Camera. The batteries are new &/or charged but the camera won't always work reliably - says to change batres. but if I just open the bat. door...
Sometimes, the lower contacts get bent downward after years of use, causing the batteries to ride low in the compartment, and thus making poor contact when the battery door is closed. Try lifting/bending these interior battery contacts upward, so that the batteries ride higher when inserted.
Oct 29, 2011 | Canon PowerShot S2 IS Digital Camera
1. Most likely is discharged or improperly inserted batteries. Make sure to use freshly charged AA batteries that are inserted with the correct polarity. The Inner 2 have the minus side up and the outer 2 batteries have the + side facing up.
2. Close the battery door fully because the battery cover pushes on a small sensor that has to be closed before the camera will turn on. The battery cover slides and clicks into place. If the battery cover sensor is bent or damaged then the camera would not turn on. The battery cover sensor is tiny, and out of the way and probably not obvious that is has one.
3. Insert the proper memory card and close the memory card cover securely. If it's left open or not seated fully the camera may not turn on. I
4. Also remove the memory card and re-seat it, then close the cover again in case it was not fully closed.
5. Remove the batteries and check that the battery terminals are clean and they appear to be intact. For example, corrosion from leaking batteries could cause a poor connection.
6. Was the camera dropped? If it was dropped that can bend the metal battery contacts, then when you put the batteries in it doesn't really contact the battery properly.
7. If it still won't turn on have an electronics guy check it over, or at the local college electronics teacher. I've fixed these before and the main DC circuits are not too complicated. These camera's can even be powered up using a regulated 6V DC power supply connected properly to the battery terminals, (just for testing) and in that case you don't need batteries to tell that the camera works or not. These draw about 300mA of current when ran from 5V to 6V DC.
I attached a JPG photo showing a similar Canon A60 running via a DC power supply and no batteries. This one was apart at the time to fix a stuck zoom lens, and when it's apart there is no where to put the batteries so I have to power it this way.
You do not have to take it apart or use this method. I just mentioned this so it's clear that all it needs to run is 5 -6V DC from properly charged and inserted batteries (or an external source). Don't try connecting anything if you are not familiar with electronics because connecting it up wrong can damage the camera. Try the suggestions mentioned early and it will probably work since these are pretty reliable cameras.
Jul 15, 2010 | Canon PowerShot A75 Digital Camera
My canon a75 continually says low battery after changing them
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Jul 16, 2009 | Canon PowerShot A75 Digital Camera
Canon A75 - viewfinder shows- purple distorted picture.
Its bad ccd imager in camera and this part will be replaced.
Canon will repair Free of Cost A75 camera as per announced scheme.
Click Canon CCD Imager Advisory for details.
Mar 15, 2009 | Canon PowerShot A75 Digital Camera
I have a canon digital camera. The display is not working.
The A75 was a great camera, but after about a year of use, many complained of problems such as the one you describe (search on "Canon A75 Black Screen of Death" to see :-).
I believe that for a time Canon was offering replacements, but that was several years ago, so it is likely that this program is no longer available (might be worth a try at canon.com, but don't get your hopes up). The only good news is that you can get a much, much better version of this camera, the Canon A590 IS for just over $100.
Dec 30, 2008 | Canon PowerShot A75 Digital Camera
Camera not working
check the battery connections for corrosion if not that there is a 3.2 fuse (plastic) incasement under the on off button that may be open.
Sep 22, 2008 | Canon PowerShot A75 Digital Camera
Overexposed pictures
CCD sensor has stopped working properly that is why your pictures are "noisy" ( see  pic  bellow  )  You  are  in  luck  because  Canon  agent  will  repair   this  particular  fault  free  of  charge  even  if  your  camera  is  out  of guarantee ,  so  phone  them. b9dcb97.jpg
Oct 13, 2007 | Canon PowerShot A75 Digital Camera
Powershot A75- zoom doesn't work/ always says change batteries
It is very unlikely to be a problem with the batteries if you are sure they are new and the right size and correctly inserted. The fact that it turns on at all would indicate that the batteries are fine. A "stuck" zoom on this range of cameras is often solved by giving the camera a gentle slap. (I have an A95 which had a similar problem that solved itself when my girlfriend dropped it). I wouldn't recommend dropping your camera, but try a little soft violence and you may find it works. If not, then a repair shop is definitely the best solution as these cameras have few internal parts that an amateur could fix. Possibly another solution could be to try the external power supply - most main camera shops should be able to supply - thus eliminating completely the possibility of the batteries being the problem, but it sounds like a mechanical issue with the zoom mechanism.
Feb 23, 2007 | Canon PowerShot A75 Digital Camera
Canon PowerShot A75 Digital Camera Logo
77 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
