Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Amana model SRD 2555L door heater stays on - Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
2 Suggested Answers
  • 118 Answers
SOURCE: please how can i get
Try repairClinic.com . They carry a large selection of repair parts with detailed installation instructions. You'll need your model #, serial #, and year of manufacture.
Posted on Jan 04, 2011
OPEN DOOR WARNING STAYS ON DOOR OPEN OR DOOR CLOSED. NOTE THIS IS THE SECOND DOOR SWITCH.
No model number given. Do a google search for a manual (just search by model number). Repair parts and some troubleshooting help at: http://www.repairclinic.com/
Could be worn latch or out of adjustment. Hope this helps.
Aug 15, 2013 | Amana Microwave Ovens
Need a filter for Amanda SRD 522 TW which one do I need.
http://parts.sears.com/partsdirect/part-model/SRD%20522%20TW?shdMod=SRD+522+TW
you need the additional mfg number to help refine your search. use that link and pick one of the two which matches yours. then search for a filter and you can order it from there.
Aug 05, 2013 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
My new amana model #a2rxnmfws01 freezxer is not staying cold and the ice maker is not working
your amana freezer internal defrosting heater is not working, have the electronic board check for problem..
Feb 09, 2011 | Amana A2RXNMFWS (220 cu ft) Top Freezer...
Please how can i get a part for amana frige freezer model no srd 528 uw and serial no 9905167491
Jan 04, 2011 | Amana Refrigerators
My daughter has an Amana side by side SRD 20S4W. Water/ice puddle on the inside bottom of the freezer section and periodically spill under the door and onto the floor. The problem started about a month...
Yes there is. You will need to remove the back panel to acess it. Try using a turkey baster with warm water or a wire. After clearing mix a 50-50 baking soda water solution and run it down the drain, this will help prevent future clogs.
Jul 27, 2010 | Refrigerators
Amana side by side model DRS2362A. Recently the freezer is not staying cold enough to keep ice cream frozen. Tried cleaning out underneath (grill area) but this hasn't helped. Other foods seem to be...
If you see frost behind the back wall or begin to notice the fresh food compartment getting warmer then you might have a defrost problem. The defrost system is a heater and termination thermostat inside the evaporator and A timer. The termination thermostat shuts down the heater when it gets to be warm enough for the frost to melt. It is important for the thermostat to kill the heater because the defrost mode is 21 minutes long.
If that heater was to stay on for 21 minutes the ice box would be severely damaged. The Timer might be hung in the run mode and not jumping into defrost every 8 or 10 hour as it should. The heater element might have gone bad or the termination thermostat might be swollen and failed. That is some ideas to check. Service manual
Jul 16, 2010 | Amana Refrigerators
Freezer down won't stay shut model # ARB220ZCC
I called Amana and they would send me a part for $77 but they weren't sure it would solve the problem so I purchased a bungie cord for fifty cents that holds the door shut. It is a bit inconvenient but it workis for me!
I am thankful that Amana doesn't make autos!
Feb 24, 2010 | Amana Freezers
Amana Microwave stays on when I shut the door.
It'll be a bad door switch or a loose door switch mount.
See :
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
William E. Miller
prototech@usa.net
Sep 09, 2009 | Amana Radarange Microwave Oven
Oven door won't close tight
order and replace door springs part # 32052801 youll need 2
Feb 22, 2008 | Amana ACF3355AS Gas Kitchen Range
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
20 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
