Question about Harmar AL600 Hybrid Platform Lift
My hybrid power chair lift wont go up mand down but will move in and out of my van
My hybrid power chair lift wont go up down but will move in and out
Bruno Electra-Ride III stair chair lift goes up but will not come down.
good test method the motor works ok
faulty up down switch
or the part/solenoid ? that reverses the current to the lift motor so they run clockwise and reverse
for up and down the stairs
wow some have remotes
could be a faulty receiver it remote to the chair
Nov 13, 2016 | Cars & Trucks
Tip
Helpful Information when posting problems ith power chairs, scooters or lift...
If you are having problems with a power chair, mobility scooter or lift chair Give as much information as you can. Did Medicare pay for the mobility product? How old is the product? How old are the batteries? When you are getting flashing lights on the battery level indicator or light on scooter console. Count the number of flashes ie: 4 flashes pause 4 flashes pause etc. If the lights are scrolling are they moving right to left or left to right? As much info as you can give will help in telling what problem you are having and easier to help if possible.
In problems with lift chairs does to chair go up but not down? Will the chair move up or down at all? Do you have a red light visible on your transformer that is plugged into the wall socket?
Thanks
Lennie
on Sep 13, 2010 | Health & Beauty
The speed lights keep flashing. It still moves.
The speed light flashing usually indicate that the chair is in "Limp Mode" This could be either the motor is getting too hot or the chair has a lift on the seat. If the chair runs fine for a while and then this condition appears, you may have a bad motor or a brake dragging causing the motor to get hot. the controller will allow less power to the motors to help it cool down and still keep you mobile. If you have a lift on the chair that raises up the chair, you will have to lower the chair down to gain the full power back. If neither one of these solutions are the problem, then you will need a Tech to come out and look at the problem. you may have a more serious problem that a tech can troubleshoot.
May 11, 2015 | Pride Jazzy 1103 Ultra Standard Power...
How do i lift off the chair out of the shoprider cobra scooter
Lift the lever to turn seat and locate the release point. I think the seat is facing to the left of the scooter, then lift off. If not check for lock screw.
Oct 06, 2014 | Shoprider Health & Beauty
Position will not move up
The hand control could be the problem. Make sure you did not accidentally cut through the cables in the lift mechanism.
May 05, 2014 | Mega Motion LC-362 Easy Comfort Three...
Pronto m41 moves slow at all times
If you have a seat lift on your chair, you will have to lower the seat lift. This is call limp mode so the chair does not move to fast and tip over while the person is in the chair. If this is not the case, then your chair controller may be over heating and it will also cause the chair to go into limp mode. this is a better option than totally stopping. the way to correct this is to let the chair sit and "cool down" for a little while. It usually takes about 30 minutes, sometimes less in cooler environments to get the chair back to normal use. If neither are the solution, then you have a problem with the chair that causes the controller to reduce the output. You will need to get an authorized Tech to check the chair out to determine the root cause.
Oct 30, 2013 | Invacare Pronto M41 Power Wheelchair
Hoveround MPV 5 - Used Power Wheelchair: i have a hoeround xhd and pickup lift where does t...
You will need tie downs to the power chair. It is a metal piece the fits over the chair post and sits under the seat and had two metal loops to hook on to. The Hoveround field technician will install it for you.You need to order the tie downs from Hoveround, your insurance will most likely NOT cover the cost.
May 18, 2010 | NRS Hoveround MPV 5 - Used Power...
Can the MPV 5 be disassembled for transport? I can't find anything on the subject.
The MPV is not designed to break-down easily for transport. The only "simple" thing that comes off is the seat which will make it about 40 pounds or so lighter, so you still have over 150 pounds to lift without taking the batteries out, which would get it down under 100 pounds...still a lot of weight to tote around. To take off the seat, first disconnect the joystick control cable, then unlatch the seat and lift off the base. This is safer and easier with two people.
The cheapest way to transport is using a ramp. Here's where I buy mine for our clients, and they are the strongest and the lowest priced ramps I have found. http://www.pviramps.com/
You can go with an electric lift, but the cost is going to be a few thousand dollars when all's said and done. If you install one on a car, you'll need at least a class II hitch, and I have found that usually you will also have to get air-shocks to compensate for the extra weight on the tail end. Even some vans, like the Honda, sag too much in the rear with a lift and chair on the rear end.
Jun 23, 2009 | NRS Hoveround MPV 5 - Used Power...
How do you lay down rear seat flat?
I just bought a 93 GMC Safari Van and couldn't figure this out either. Luckily, I did have the manual. It appears that the  lever under the front of the sofa moves in forwards and backwards. There is a lever on the corner of each side. Lift up on each and pull cushion forward. Also, you can push on the back of the sofa to help it go down. Hope this helps!
Oct 15, 2008 | 1998 GMC Safari
Harmar AL600 Hybrid Platform Lift Logo
52 people viewed this question
Top Harmar Health & Beauty Experts
Robin Hill
Robin Hill
Jeff Tilburn
Jeff Tilburn
Are you a Harmar Health and Beauty Expert? Answer questions, earn points and help others
