Question about Samsung LN-R328W 32 in. HD-Ready LCD Television
Samsung LNR 328 appears to only show 16 or 32 colors no longer has the gradients between colors and shades. Was working fine one night and next morning was not. Is this a setting or is the TV shot? Thanks
SOURCE: Black/Dark Colors Fuzzy w/Red Pixel Outline
I have the same problem too....
Posted on Jun 19, 2008
SOURCE: When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Posted on Mar 03, 2009
Shuttle83
  • 1139 Answers
SOURCE: Rainbow color effect appears when Samsung LCD plays Wii or DVD
Hello, I have a question which video inputs are you using for your DVD and Wii connections? The reason I ask is because this sounds like video distortion cuased by noise. If possible can you send a picture of the screen when it has this problem and send which video ports are being used? If it is noise in the video you may have a saw filter problem, or a decoupling issue. In any event I'll know more once you send those pictures and which inputs you are using for your DVD and Wii. Thank you, Shuttle83 http://www.electron-age-technologies-llc.com service@electron-age-technologies-llc.com
Posted on Jun 10, 2009
  • 30 Answers
SOURCE: Samsung PS50C91HDX Sound but no picture
It sounds like the main board or screen may have gone
Posted on Sep 26, 2009
Testimonial: "A quick one to respond with a good answer to the problem."
SOURCE: My tv no longer shows the color red. No idea what
I have sound but my tv screen is black. Sometimes when I turn on the tv I get a picture but after 15 minutes or so the screen goes black again.
It's a 4 year old LCD.
Posted on Jan 05, 2010
I want to dye my hair red. Does the color on the box really show you how it will look on your hair?
Usually the color on the box gives an indication of the color and shade but it's not an exact example of how it will look on your hair. Red colors have intense pigments so the color tends to last longer. Some experts say that red hair colors often come out more vibrant in reality than they look on the box, so go for a shade that is one lighter than the one you really wanted.
Mar 04, 2013 | Health & Beauty
Samsung DLP TV- colors seem to mess up -Faces have green streaks
sounds like you are haveing an issue with th color wheel timing. either the color wheel is bad or the dmd board is bad.only way to know is to have a technician look at it.
Oct 22, 2007 | Samsung HCN4226W 42" Rear Projection...
I cannot use fill colour for shapes, text boxes etc on either Word or Publisher -Office 2007 I click on fill colour but shape remains blank - a series of dots do appear around the shape.
Apply a different shape fill You can fill a selected shape (such as data markers, titles, data labels, or a legend) with a solid color, gradient, picture, or texture. You cannot use shape fill to format lines in a chart (such as gridlines, axes, trendlines, or error bars).
On a chart, click the chart element that you want to change, or do the following to select it from a list of chart elements:
  1. Click a chart. This displays the Chart Tools, adding the Design, Layout, and Format tabs.
  2. On the Format tab, in the Current Selection group, click the arrow next to the Chart Elements box, and then click the chart element that you want to use.
On the Format tab, in the Shape Styles group, click Shape Fill
  1. Do one of the following:
    • To use a different fill color, under Theme Colors or Standard Colors, click the color that you want to use. Tip Before you apply a different color, you can quickly preview how that color affects the chart. When you point to colors that you may want to use, the selected chart element will be displayed in that color on the chart.
    • To remove the color from the selected chart element, click No Fill.
    • To use a fill color that is not available under Theme Colors or Standard Colors, click More Fill Colors. In the Colors dialog box, specify the color that you want to use on the Standard or Custom tab, and then click OK. Custom fill colors that you create are added under Recent Colors so that you can use them again.
    • To fill the shape with a picture, click Picture. In the Insert Picture dialog box, click the picture that you want to use, and then click Insert.
    • To use a gradient effect for the selected fill color, click Gradient, and then under Variations, click the gradient style that you want to use. For additional gradient styles, click More Gradients, and then in the Fill category, click the gradient options that you want to use.
    • To use a texture fill, click Texture, and then click the texture that you want to use.
Tip If you don't like the change that you made, you can undo it immediately. On the Quick Access Toolbar, click Undo default.aspx?assetid=za101819851033, or press CTRL+Z.
Jun 01, 2010 | Microsoft Office Professional 2007 Full...
Green shade color on screen over tyhe program that is been broadcast
its a loose connections to you color amplifier RGB. cold solder in that board section.
May 30, 2009 | Samsung HL-R6167W 61" HDTV
Mar 02, 2009 | Samsung LN-S3238D 32 in. LCD HDTV
White outlines in HD mode
is the screen control turned up to high if so you would see white lines on a dark picture
Oct 30, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Gradients
path problem? cutting problem
Oct 12, 2007 | Adobe Photoshop CS2 for PC
Severe gradient issues / problems with darker grays
So your sure when you go into the monitor settings, and color, it is set to like 9300k or something? It probably isn't the monitor, because the video games you said display just fine.
Dec 19, 2006 | Dell M992 19" CRT Monitor
Samsung LN-R328W 32 in. HD-Ready LCD Television Logo
44 people viewed this question
Henry  Thomas
Henry Thomas
