Question about Garmin StreetPilot C330 GPS Receiver
Unit will not turn on.
Don't know if it is the battery or the fuse for lighter plug in, and can't find where or how to replace either. The manual does not tell .
  • 20 Answers
The battery may be dead, but more likely it's the fuse.
The battery, if that's the problem, must be replaced by Garmin, and they'll charge you more than the unit's worth.
The fuse, on the other hand, can easily be checked and replaced by you, and that IS discussed in the manual, Page 29, to be specific. Download directly from Garmin: http://www.garmin.com/manuals/StreetPilotc330_OwnersManual.pdf
Posted on Jan 20, 2009
The lighter does not work and I can not use a GPS system. Someone suggested it may be the fuse box, but I don't know which fuse it is because the fuses are not labeled and I don't have an...
Check all the fuses.
But the same fuse works a number of things such as the coutesy lights and an under hood light if equiped. If your interior and any under dash lights work then the fuse is good. You could also have a bad ground or a bad socket. Or even the GPS plug may not fit will in the cigar lighter socket well enough.
Aug 19, 2011 | 1989 Chevrolet S-10 Blazer
My garmin nuvi 650 na keeps depleting its battery even though I just fully charge it on the computer. It also does not charge when I plug it in the cigarette lighter in the car. The screen turns dark...
well if you have the factory car charger. There is a fuse inside of it. This is indicated in the manual. But it could also be the cigarette lighter fuse in the car is blown. I would make sure the cigarette outlet has power. If the cigarette lighter has power and you have the factory power cable that has a fuse try this. f the unit will not charge in your vehicle, you might need to replace the fuse that is located at the tip of the vehicle adapter.
1. to change the fuse unscrew the black, round end piece on the vehicle power adapter and remove it. inspect the fuse to see if it is blown. If not end here.
2. if determined the fuse is blown remove the fuse (glass and silver cylinder), and replace it with a 1A fast blow fuse.
3.ensure that the silver tip is placed in the black end piece. screw on the black end piece
let me know how this works by following up with a comment and i can instruct you on where to go from here. Thanks.
Aug 26, 2010 | Computers & Internet
Won't turn on.
if you still have an issue with this, ill be glad to help you..just reply to this post ..(see my feedback)
YOU CAN NOT CHARGE A MAGELLAN 4040 WITH A USB CABLE!
if the green light is on, on your car charger, the charger is working..if its on (the green light) and still wont start after holding the power button for up to ten seconds, let me know and i will help you further.
May 06, 2010 | Magellan Maestro 4040 GPS Receiver
Need to work a RAdar detector: whistler 1430
Does the unit turn on when you plug it into the lighter socket? If not, does the lighter socket power other 12 volt devices? IF the lighter socket works and the radar detector doesn't there is a fuse in the plug end of the power cord. Unscrew the tip to expose the fuse. Replace it with a 2 amp fuse from any auto parts store and try it again.
Feb 27, 2010 | Whistler Vehicle Parts & Accessories
My horn works so I know the fuse is good. How do
check the wiring behind the lighter and recheck fuse panel for a designated lighter fuse or the lighter housing may be bad if u have power to the lighter than replace lighter unit any auto store sells them
Feb 26, 2010 | 1993 Chrysler Concorde
Street pilot 330 will not turn on when plugged into car power supply. Poosible battery charge needed?
Does the car charger cord have a fuse in it at the point where it plugs
into the lighter port, a lot of car chargers have a fuse, I can't tell
if your end, the part that goes inside the lighter port has a cap that you unscrew to replace the fuse, and garmin does not show it.
If the car is running, and it does not work, there is something wrong with the car adapter, or the unit at the plug, the battery should not have anything to do with it.
If the battery starts the car the battery is fine.
Feb 07, 2010 | Garmin StreetPilot C330 GPS Receiver
Unit (tom tom 1xl) turning off
One hour is about the time the unit will run without a power source.
You need to check that the cigarette lighter is working. Check the car fuse.
Check the fuse (one of the six bumps) on the cigarette lighter plug has not blown.
Is the cigarette lighter / Tom Tom lead damaged in any way?
Peter
Mar 01, 2009 | Tomtom One XL GPS Receiver
No power to cigarette lighters
Two years later and you solved my dead cigarette lighter. manual says fuse 35--but it did not say to check 38 on the left fuse box. Thanks--blown fuse and everything works. Thanks
Dec 20, 2008 | 2007 Volkswagen Passat Sedan
Garmin StreetPilot C330 GPS Receiver Logo
88 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
