Question about Generic 18.5"" element flx18511b 720p widescreen lcd hdtv - 16:9 1000:1 dynam
Emerson element FLX18511B HAS NO SOUND - Generic 18.5"" element flx18511b 720p widescreen lcd hdtv - 16:9 1000:1 dynam
Emerson 55 inch LCD TV no picture, but backlight and sound works
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 10, 2016 | Emerson Televison & Video
How do I find the water leak in Emerson insinkerator H770-SS
The use-and-care manual says that the 'product will eventually fail,' and to install a drain catch pan.
The product has stainless steel tank with 3 year warranty. 1-800-558-5700.
The manual does not show parts diagram, element, or anode rod. This indicates that operation is inside a sealed 1-piece unit not meant for repairs.
High clorine content of water, and hard water, and water pressure over 80 psi will adversely affect any tank heater, and shorten lifespan causing probable leak.
Turn off power:
If you can remove cover from H770, then inspect 750 watt element for possible leaking. Then replace with new element of unknown type if element is leaking.
If leaking is coming from the tank itself, then the unit cannot be repaired. This is true for all tank water heaters.
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 04, 2012 | Emerson Water Heaters
Water heating not heating water
The Emmerson W152 is ordinary 1-year warranty 120Volt electric storage water heater, except with bronze tank. The bronze tank will not rust, and therefore tank does not have anode rod, and tank has 5 year warranty.
http://waterheatertimer.org/pdf/Emmerson-point-of-use-water-heater.pdf
Actions to take:
1) Check circuit breaker.
2) Emmerson plugs into 120V outlet. See if outlet works for other 120Volt light or can opener.
3) Turn off power and do following:
4) Open cover on water heater, and press in reset button.
If reset will not reset, then replace thermostat with ordinary generic thermostat from hardware store.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
5) If reset button is not tripped, test element.
6) Emmerson has 1500 watt element, and correct ohm reading at 120 volts should be around 9.6ohms
http://waterheatertimer.org/How-to-test-water-heater-element.html
7) This element is 7" long, and is also generic, and should be available at hardware, or plumbing supply, or Google-search 'Emerson appliance water heater element.'
Jul 29, 2012 | Emerson InSinkErator W-152 Point-Of-Use...
Beeping sound in Emerson CF1 ceiling fan
mcdevito75 here, Are you sure it:s the fan makeing a beep or a smke alarm that needs a battery??.
Jul 27, 2010 | Emerson CF1 Weathered Bronze Ceiling Fan
Emerson quiet kool model.eqk 1350 f serialo 20e 808320 wont heat, does it have an element? where is it located?
I looked up the model number parts
Their does not appear to be a heating element associated with this ac nor a reversing valve so I don't think it has a heat feature. You could mount it backwards and heat an area. That would look weird.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 29, 2010 | Emerson Quiet Kool 6GC53 Air Conditioner
Bake element fell apart. Changed it out with replacement element (Emerson CH 5862 PCN 458580, 240Volts, 2800 Watts) Still does not work.
As a general rule, when you change an oven element, you should change the thermostat as well as the element failing can sometimes take out the thermostat as well. (Info. courtesy of a NEFF engineer many years ago as they always change both if an element fails).
If you haven't done so, I would suspect the thermostat.
Feb 06, 2010 | Ovens
Digital frequency for tv sound on Emerson RP6248
You can't pick up the sound on this radio any more. With the new digital system, sound is digital as well and can only be picked up by a digital tuner. All this radio is good for now is regular radio broadcasting.
Jun 15, 2009 | Emerson RP6248 AM/FM/TV Radio
Staandard 20
the plyback of your tv had a problem, there's a leak that's why you heared a sound.
Oct 01, 2008 | Emerson EWF2004 20" TV
Generic 18.5"" element flx18511b 720p widescreen lcd hdtv - 16:9 1000:1 dynam Logo
Top Generic Televison & Video Experts
CoppellTVRepair.com
richie46
Are you a Generic Televison and Video Expert? Answer questions, earn points and help others
