Question about Frigidaire Affinity ATF7000ES Front Load Washer
I have an affinity washer by frigidaire and I am getting an e20 problem code. The link will not work for the product manual from the company and the link on Fixya also does not work can someone help please. It is taking all day to do a load of laundry
  • 3 Answers
E20 = Clogged drain pump.
Tools I used: vice grips, both phillips and standard screw drivers, flash light and an 8mm socket with ratchet.
I solved this problem by removing the rear oval type cover by removing the 6 phillips screws that hold it on, but first thing is to unplug the machine! I unplugged the electrical connection going to the pump. Then I removed the hose closest to me by removing the pinch clamp with a pair of vice grips. Then I removed the two screws holding the pump down to the frame of the washer (8mm socket). Then I removed the farthest hose by removing the pinch clamp with the vice grips. Once this was done I took out the pump. The hose entering the pump contained a sock, debit card and thirty-five cents!
Once I removed all of the debris I reversed the order but this time I used an automotive hose clamp which makes re-assemble waaay easier!!! (Saves about 30 mins) Total repair time took me 1 hour, but if you use an aftermarket hose clamp instead of the pinch clamp on the hose coming into the pump this will save you at least 30 minutes because it is soo difficult to put back on because of the tight space.
One-hour, a minor cut and $2.35 for the clamps later all is fixed!
Posted on Sep 12, 2010
What do i do when my washer affinity frigidaire displays E20
Hello friend, thank you for your post!
I see your question is labeled under Frigidaire washer, ATF6000ES, and your washer is receiving an error code of "E20". "E20" stands for the water is not pumping out fast enough which means it could be an issue with your control panel or drain pump. I would recommend having a professional come out and properly repair your appliance. I hope this is helpful. -Matt
Sep 27, 2014 | Frigidaire ATF6000ES Front Load Washer
I thank you so much for your guidance on repairing my Affinity with the E20 code.I went through the process - It was totally clogged. I put everything back and the washer does not drain still. What do I...
The E20 code is a general pump failure code. This is usually the pump being clogged.
Try using a wet/dry vacuum on the end of the drain hose to see if there is a blockage that you don't see. If you still get the error you will need to replace the drain pump.
Here is the new drain pump to order.
Nov 25, 2012 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
When washer turns on there is a horrible buzzing sound, e 20 error message was on before
This is a blocked drain error code (E20) which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums, buzzes or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
Spin cycle goes very slow or doesn't work.
Hello, After looking at the User Manual for our Washer, E20 is an error code for the drain. It said that either the house drain line is clogged or the washer drain line is clogged. After my husband took the drain line off the washer, cleaned it out, we noticed that the lines had a lot of detergent build up and figured that this is probably the cause of the error code. We put the washer back together and it is working properly. We have always used the "he" detergent for the front loader and always used the proper amount; however, from now on, we will use less than the recommended amount.
I hope this helps some of you who are having this problem.
Thanks
May 19, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Error code E20
Hello there
the Dreaded E20 fault is a drain problem
washer will show the E20 code and may not spin.
So i would first look for a clog in the hose right before the water pump there is a little cup in the black hose that could be full of suff if so empty the cup and it should work good after this
hope this will help you out
Best regards Michael
Dec 26, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washer stops and signals E20 error code
Click on your model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site!
Jan 24, 2008 | Frigidaire Laundry Affinity 3.5 Cu. Ft....
Frigidaire affinity front loading washer
Any E20 code means your washer doesn't drain.  More than likely there is a screw, nail, coin, bobby pin, etc locking up your pump and causing it not to drain.  Keep in mind that your washer has a 1 yr warranty but some service companys will charge for this kind of repair because it is not technically covered under warranty.
Aug 21, 2007 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
135 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
