Question about Plumbing
How to repair a leaking danze 61/9 faucet, likely the ceramic cartridge?
dnewcombe1
  • 1564 Answers
SOURCE: remove the cartride for the danze d454612
First you have to remove the main lever/handle. This is done by loostening the allen head setscrew at the pivot point front base of thge handle. Underneath you'll see a collar or nut that is easily removed with a pair of Channel Lock pliers (adjustable) then after marking the front of the valve with a permanent marker(just make a dot) so it is assembled the same way, pry out the valve and repair or replace it, Thank you, Dana.
Posted on Jan 23, 2010
  • 35 Answers
SOURCE: slow running tap
If you have recently turned off your water supply you may have disturbed some sediment in the water lines causing this problem.....Unscrew the airator at the end of the faucet and there is a screen inside( take note how this screen is in place). This should give you water pressure back!
Posted on Dec 19, 2008
  • 30 Answers
SOURCE: Looking for parts breakdown picture for DANZE NSF
NSF 61(-9) is a standard rather than the model number (it's often very difficult to identify the model number. If you are able to find the model number, the link attached has all the technical specs for Danze products (even discontinued ones). http://www.danze.com/tech_specs.asp
Otherwise, I suggest browsing their faucet section until you find yours.
Good luck.
Posted on Sep 18, 2009
SOURCE: REcently installed Danze Ashburyee kitchen faucet
Disassembled hose and realized all I needed to do was tighten the brass coupling to the hose. Problem is fixed.
Posted on Jan 31, 2010
SOURCE: My Danze NSF 61 9 makes a loud howling noise.
You don't say how old your unit is. I have had the same problem with calcium buildup in my tankless heater. Pump vinegar into the unit and let is set for about and hour, then flush the unit.
Posted on Feb 26, 2010
We were trying to stop a leak in a danze songle handle shower faucet now the hot water won't turn off whar do we do?
you need a new cartridge if its fairly new. if its an older faucet it will have to be replaced, usually the hot water side warps the fixture and it leaks there nothing you can do about it except to replace it.
Aug 28, 2017 | Danze Home
Water is dripping out the back of the the Danza 61/9 kitchen faucet
Just in case you need to do so.
  1. Turn the water off. The water control knob is located under your sink and is connected to the drain. Turn it counterclockwise to turn off the water.
  2. 2
    Open the faucet to relieve any differences in pressure. Pull up on the faucet as you would if you were turning it on.
  3. 3
    Plug the drain of the sink with its stopper to prevent any parts from going down it.
  4. 4
    Turn the faucet handle sharply to one side to reveal a small cover plate. Pry the plate off carefully with a flat-bladed screwdriver.
  5. 5
    Unscrew the screw that is located behind the cover plate with a 4 mm allen key.
  6. 6
    Lift the handle off and remove the cap beneath it.
  7. 7
    Firmly grip the exposed cartridge with your hands and pull up to remove it.
Read more: How to Remove the Cartridge from a Danze D403412 ' eHow.com http://www.ehow.com/how_7640485_remove-cartridge-danze-d403412.html#ixzz1D76xWEgn I your case I think all you need are new o-ring seals on the spout. once you have the handle off and have gotten to the cartage grab the spout and turn back and forth while pulling up and remove the spout you will see the o-rings. I would get the repair kit before you start. The video below is not your brand faucet but the o-ring replacement is about the same. http://www.youtube.com/watch?v=AipEYoYiIhc
Feb 05, 2011 | Danze D403412 Melrose Single Handle...
Need an instruction sheet for cartridge replacement for Danze Sheridan tub and shower faucet
This link will get you to the Danze illustrated parts list for the Sheridan single control tub and shower valve.
http://www.danze.com/products/pdfs/D510055_ip.pdf
Aug 08, 2010 | Danze Sheridan Tub & Shower Faucet
Bought a home, main kitchen faucet is a Danze NSF
I'm not familiar with a NSF 61/9, but I've used several other models. I believe these are all ceramic disc valve. They almost never wear out. If you remove the handle and the trim cap or bonnet, there should be a nut or adjusting ring you can tighten. Don't over do it. The handle give you quite a bit more leverage than the small tap when it is removed. Here is Danze web site and you can look up your exact model number and see a exploded parts list: www.danze.com
Jul 12, 2010 | Danze Plumbing
Looking for parts breakdown picture for DANZE NSF 61 Kitchen Faucet Any Links?
Good luck.
Sep 13, 2009 | Plumbing
My faucet drips and i believe there is no way to change the washer out. What can I do?
danze has a cartridge, if you have two handles you can turn the water off under the sink and isolate which one is leaking if you cant figure it out you can just take both of them out and have them both replaced. if it's a single handle there will just be one cartridge in there. you will have to remove the handle and a few other things and it should just pull right out of there. if you call danze they might send you some free cartridges if you ask nicely!
Aug 05, 2009 | Danze Plumbing
Plumbing Logo
2,508 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
