Question about Celestron Optics
Skywatcher multifunction mount (Celestron, Acuter Merlin Az mount...) Hi I have a problem I can not solve here in Sweden. I have a mount of type "Acuter merlin AZ multifunction". The mount running well in manual mode with HC but does not work absolutely the autotracking. There is someone who can give me any suggestions or tell me if there are spare parts for this mount? Thanks.
SOURCE: Merlin Magix PRI
If D-channel is dropped, you will get red light.
When B-Channels are in use, you will get amber light.
Posted on Sep 08, 2008
SOURCE: colmination
what scope do you have as your picture suggests you have a dobsonian 10 inch. get back to me with your real scope and i will be able to help you
Posted on Oct 01, 2008
SOURCE: Changing time on the Avaya Merlin ETR - 34D
or, if this is a Magix, the 4424ld+
Posted on Mar 10, 2009
  • 3 Answers
SOURCE: How do I set up voicemail in merlin 410 system?
MFurrer is right... the voicemail unit was made by Voysys. It is known by several names: Merlin Classic Mail, vp100, model 100.
Some telcomm suppliers who deal in used or refurb equipment MAY still have one or you can contact King Technologies (they own the rights to this unit). Either of these is likely to give you "sticker shock" ($1000+). Ebay is about the only cheap place to find one, but there are always buzzards circling over these (myself included). If you find one, make sure it includes the power supply. The units on ebay have several typical problems: bad hard drive, no power supply or deleted admin mailbox. All these should be deal-breakers unless you're planning on buying several for parts. The deleted Admin box is the only one that can't be discovered until the unit is attached to phone sys. It is fixable but the people who know how don't seem to want to share this knowledge.
Jim
Posted on Jul 20, 2009
SOURCE: driver merlin u630
same problem srichantamit@gmail.com
Posted on Oct 28, 2009
Where can I get one please
Probably almost anywhere that has them on sale - shop around for the best value.
Feb 22, 2016 | Optics
How the specifications of telescopes is read
First you would look at the construction, a reflector or a refractor.
The first has at least 2 mirrors in it, and comes in several sub-types. The cheapest to begin with is a Newtonian, very cost effective. You can recognise these as having the eyepiece at the front end of the tube.
http://www.365astronomy.com/images/10237-skywatcher-quattro-12s-imaging-newtonian-telescope.jpg
Newtonians however have to be optically aligned (collimated) every so often to give a sharp image. This is simple enough when you learn how, but some find it a pain.
Refractors have no mirrors, only lenses, and you can recognise these as having the eyepiece at the rear of a longish tube. They don\'t need regular collimation. The better ones have more lenses in them, and in larger sizes are very expensive.
http://www.astronomyalive.com.au/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/7/0/709eq.jpg
The next spec you see is the aperture, or diameter of the optics. It is the diameter of the main mirror or lens, and governs the light gathering power of the scope. If you live in the city, there is no point to having a huge scope, as it only gathers lots of light pollution. If away from towns, a large scope will pick up faint nebula. 100 - 150mm (4"-6") is a good starter size.
Then you see the focal length (FL) quoted. This is the length of the light path in the scope. In a reflector it is folded up, and can be quite long without having a bulky tube (OTA). In a refractor it is straight, and so is limited in amateur scopes to about 1200mm.
The focal length governs the magnification you see, but only in partnership with the eyepiece (EP). These are interchangeable
http://www.atozastro.com/my_equip/eye_pieces_set.jpg
and each has its own focal length. The magnification is the scope FL divided by the EP FL. So a 1200mm FL scope with a 25mm EP gives a magnification of x48, which does not sound much, but is good for a sweeping view of the Milky Way. EPS range down to 4mm commonly, so there is wide choice.
There is not space here to discuss the mounts, but start with a robust AltAzimuth (AZ), say a Skywatcher AZ4. Another popular mount is the Dobsonian, confined to Newtonian reflectors.
I\'d urge you not to get a cheap department store scope. These are absolute junk with plastic lenses and poor construction. Depending on budget, get an affordable refractor first up, (so you don\'t have to fiddle with it much) with some Plossl type EPs (cost effective) like a
http://www.optcorp.com/celestron-astromaster-90-az-refractor-telescope-21063.html
May 24, 2014 | Measuring Tools & Sensors
4500 orbitor telescope
Download the manual in the link below. It is for the Orbitor 6000 which is a 6" Netownian Reflector telescope on an equatorial mount. Your telescope may have a Alta-Zimuth (AZ) mount instead, then click on the second link for the Celestron 114AZ. Although the telescopes are different from yours, the basic parts are very much similar and these manuals could be of help to you.
Orbitor 6000 manual:
Owners Manual User Guide for Citiwell International Orbitor 5500...
Celestron 114AZ manual:
114AZ 90AZ 70AZ Instruction Manual pdf Google Drive
Oct 09, 2013 | Citiwell International Orbitor 5500...
I am a beginner looking for a good telescope. I am currently looking at a Celestron Skywatcher telescope. There are three lenses which comes with it: super wide 10mm. lens as well as a wide angle 25 mm....
Magnification is the LEAST important property of a telescope. Quality optics and aperture are much more important.
The best bang for the buck is a reflector style telescope ion a Dobsionian mount. You get the most aperture for the least amount of money. Like this one--
http://www.telescope.com/Telescopes/Dobsonian-Telescopes/Classic-Dobsonians/Orion-SkyQuest-XT6-Classic-Dobsonian-Telescope/pc/1/c/12/sc/13/p/8942.uts?refineByCategoryId=13
The scope above has 6 inches of aperture and is mounted on a very stable alt az mount called a Dobsonian mount.
www.telescopeman.org
www.teleswcopeman.us
www.telescopeman.info
Aug 23, 2011 | Optics
Where to find them in sri lanka?
First I would not buy that very small 60mm telescope. You would be better off buying a pair of 10x 50mm binoculars and a good star chart.
Check out the Skywatcher brand of telescopes which are manufactured in Europe--
http://www.skywatcher.com/swtinc/index2.php
Jul 15, 2011 | Celestron PowerSeeker 60 EQ Astronomical...
Hi, Bought a used telescope with a GT mount. The polar adjustment will not go below 46 degrees without binding. The binding screw only turns 1/4 turn in each direction and appears to be binding the...
This scope does NOT need to be polar aligned --
Here is the manual:
http://www.celestron.com/c3/images/files/downloads/1228334587_nexstargt.pdf
This is an ALT AZ goto scope. Read the manual above. You use the hand controller to move the scope in Altitude and Azimuth(left-right).
You must align it on 2 stars in order for it to has successful gotos.
Aug 21, 2010 | Celestron NexStar 114GT (269 x 114mm)...
Problem focusing on distant objects
collimate your mirror.
sky and telescope shows you how to do it.
it's under 'Do-It-Yourself' section.
hope this helps :D
Aug 26, 2009 | Celestron AstroMaster 114 AZ (50 x 114mm)...
Colmination
Dec 27, 2007 | Celestron StarHopper 10 Telescope
Celestron colmination
There should be 2 sets of adjustments to be done. The first is to sight from the eyepiece holder, and see if the diagonal has the back mirror centered - don't be concerned about the off-center of the main mirror. Once the diagonal is centered, then use the adjuster screws to bring the main mirror into line. Adjust first one way then the next (in or out). When done, your eye should be centered in both mirrors. Then align the finder, and away you go.
Optics Logo
87 people viewed this question
Top Celestron Optics Experts
Vernon Taylor
Lawrence Oravetz
Are you a Celestron Optic Expert? Answer questions, earn points and help others
