Question about Sentry Fireproof Safe
Does anyone have the sentry safe model CSW3607 i need the factory code for it
5 digit passcode
  • big cock Jan 05, 2013
    its five digits long 1-9
SOURCE: csw3607 sentry safe will not open. when i use my 5
I hate to tell you, I just had this same problem on a brand new safe (x-mas present) and ended up having to crack it open. Unfortunately, from my extensive research on this problem on Sentry Safes it turns out that they use an encoded IC chip on the solenoid and if either a serial wire breaks going to the board or the IC chip fails, you get the 5 beep-of-death error. Needless to say, I'm thoroughly disappointed in Sentry and will discourage anyone from purchasing their products!
Posted on Jan 04, 2011
  • 10 Answers
SOURCE: defalt code for sentry safe 5 digits
You'll need to go here:
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
There is no "default code", but they do keep the serial number and code on file, for just this purpose.
Posted on Feb 18, 2008
SOURCE: Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
Posted on Aug 21, 2008
  • 76 Answers
SOURCE: Need factory code for Sentry Safe Model 1610 -
If you need your lost combination, you must send a notarized letter stating you are the owner of the safe. The link below will tell you everything that you will need to get your combination back:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Posted on Jul 06, 2010
  • 2509 Answers
SOURCE: i have a sentry safe model A3821 need factory code
The factory code is printed on the first page of your manual. If You don't have the manual you have to contact sentrysafe who will help here: https://www.sentrysafe.com/ContactUs/Call_Or_Email_Us
Posted on Jan 17, 2011
How do I change the combination on SENPL048E sentry portable security safe
Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • Mar 24, 2016 | Home Security
    I have lost the combination for my safe model V330 my model number V330 Sentry safe
    • Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
    • Retype the user code to verify it is working, and then close the safe.
    Mar 19, 2016 | Sentry FIRE-SAFE Combination Safe DS3431,...
    I have a sentry safe model OS0810 and i need a factory code as I cannot recall my pin code
    There is no 'factory code'. If there was anyone who knew it could open anyone's safe. You will need to take it to a locksmith. They will drill the door and put a new one on for you.
    your safe here
    http://www.sentrysafe.com/Products/230/OS0810_Electronic_FIRE-SAFE_
    What they tell you if you have lost your combination. You may be lucky if it hasn't been changed.
    Sentry Safe Lost Your Combination
    Dec 09, 2015 | Home Security
    How can i drill a hole into my keepsafe wall safe to open it?
    Keep the drill motor in the toolbox, you'll likely just ruin the safe.
    Go here instead: https://www.sentrysafe.com/CustomerCare/Lost_Your_Combination
    There are 3 possible ways to unlock and access
    the safe:
    1. Factory code
    (Found on the first page of the factory guide) You can
    always open the safe by entering the pre-set 5-digit
    factory code. This code cannot be deleted.
    2. User code
    If you prefer to employ your own code, you can
    program the safe to open using a 5-digit user code
    of your choice.
    3. User pin
    If you wish to give someone else temporary access
    to the safe, you can program a 5-digit user pin that
    can later be erased.
    Programming the user code
    NOTE: One (1) user code is allowed.
    To add:
    1. Press the Prog key , then enter the 5-digit
    factory code.
    2. Enter the 5-digit user code of your choice.
    To delete:
    1. Press the Prog key.
    2. Enter the 5-digit factory code twice.
    Programming user pin
    NOTE: One (1) user pin is allowed.
    To add:
    1. Press the Prog key 2 times.
    2. Enter your 5-digit user code.
    3. Enter the 5-digit user pin of your choice.
    To delete:
    3. Enter 0, 0, 0, 0, 0.
    NOTE: If your safe does not appear to be working,
    please check batteries before calling Sentry
    Customer Care.
    Jul 26, 2014 | Sentry KeepSafe Combination Fire Safe 12...
    How to fix a s0607
    I have a Sentry Model 1610 safe with an electronic lock. Entering the factory 5 digit code gives the green proceed light but the handle won't turn and the door won't open. How can I get the door open?
    Jan 30, 2014 | Sentry Safe Qe4531 Firesafe Waterresistant...
    Sentry safe model SC3877 lost original factory combo..Does anyone know it..
    Each safes ships with a different factory combo. You need to contact Sentry at 1-800-282-1438 for further assistance, or follow this link to the web site
    http://www.sentrysafe.com/CustomerCare/
    Dec 29, 2010 | Safe International Digital Electronic Safe...
    Csw3607 sentry safe will not open. when i use my 5 digit code the red light beeps 5 times. when i use the factory code it does the same thing. Sentry has told me to take it to a locksmith and have them cut...
    Dec 10, 2010 | Sentry Fire Safe - Safe - DS3607
    Need factory code for Sentry Safe Model 1610 - know its 5 digits but cant remember - never changed it from factory code but cant find the darn owners manual!
    Jun 13, 2010 | Sentry Fireproof Safe
    here is the customer service phone number for you. I am sure they will be able to help you. 800-828-1438
    Jul 02, 2008 | Sentry Fireproof Safe
    Sentry Fireproof Safe Logo
    61 people viewed this question
    Top Sentry Home Security Experts
    Jim London
    Jim London
    Computer Repairing
    Computer Repairing
    Joseph Vernice
    Joseph Vernice
    Are you a Sentry Home Security Expert? Answer questions, earn points and help others
