Question about Pelonis HO0218 Oil Filled Electric Radiator Heater
I have a Pelonis Electric Oil-Filled Radiant Heater. It no longer heats. I've had it for about two years. I did some research and from what i can tell, the most likely solution (though I'm no
  • Jenna Dewey Jan 07, 2013
    Thanks all, for your comments! They're much appreciated. As an update, now my heater won't even turn on (usually there's a red light showing it's at least working, or has an electrical current)... Any ideas? Thanks so much!!!
5 Suggested Answers
  • 3 Answers
SOURCE: Pelonis HO-0128 makes strange noise
Nothing wrong with it. This is a normal sound made as the oil heats. As the heater heats up, the sounds should subside.
Posted on Feb 23, 2009
  • 251 Answers
SOURCE: DURING A RECENT MOVE THE BOX CONTAINER MY PELONIS
Missmanda your heater should be fine , just put it in its normal position for 2 or 3 hours to allow the oil to drain down correctly, during this time visually check it for oil leaks ( the oil is usually vegetable oil ), look for oil drips around the base and from the side covers , if you find any do not use the heater , when you do come to turn it on stay with the heater for at least 30 minutes to check for smoke,sparking or any other evidance of damage.
Hope this helps
Posted on Dec 01, 2009
heatman101
  • 43501 Answers
SOURCE: My Pelonis oil filled radiator heater is leaking a
Here is a tip that I wrote that will help you to understand about oil filled radiator heaters....
Oil Filled Radiator Heater Leaking
heatman101
Posted on Jan 12, 2011
  • 67 Answers
SOURCE: I gave my grandson a
Helen: Take your heater to any electric he should be able to repair it. Ken's Repair
Posted on Jan 19, 2011
Testimonial: "Thank You for your help, I will keep your website in mind for other issues. Thank You"
Pelonis heater smells like burning something
Three possibilities come to mind: First, there may be some foreign objects stuck between the sections of the coils where they connect or in their individual holes, the next is that the cord or outlet in your house is getting too hot (the circuit is being overloaded, perhaps; and finally, the clincher, you have a tiny oil leak in the coils themselves.
Jan 15, 2013 | Pelonis WM-HO202C Oil Filled Radiator...
Sir ; I bought my Pelonis heater at Home Depot a few years ago , and it is the best heater I have owned . However , last week I was rolling it into another room as I was about to wash my floors , and the...
Vincent, you're in luck. Pelonis has created a DIY repair site, that you can also order specific repair parts from. And the casters you need are available. Click on the the link below and then under ORDER PARTS click on HERE in the text section.
http://www.pelonis.com/service_first.htm
Hope this helped you find what you needed. Please let me know. Thanks.
May 06, 2011 | Pelonis HO0218 Oil Filled Electric...
I wondering if my Pelonis gas-filled heater is emitting dangerous fume causing me to feel depressed... do you have the phone number of the company?
Have you tried not using the heater for several days to a week, to see if your depressive state improves? That would be the litmus test involving the heater, wouldn't it?
Never the less, their phone # is 1-866-876-4332
Feb 16, 2011 | Pelonis HO0221 Electric Radiator Heater
Doesn't heat up as first bought three years ago.
Not unless it leaks oil on the floor. The oil has nothing to do with heating, your unit is actually an electric heater with oil added as "thermal ballast."
The first suspect is the plug that you plug into the wall. These sometimes overheat and electrical continuity is lost.
Solution: new plug from the hardware store. Cut off the old one and take it with you so you can get something very similar. Don't do anything if you're not comfortable with handyman-level electrical repairs.
Next suspect is the cord itself. These have a hard life on electric heaters.
After that you're inside the unit. First suspect is the thermostat, since it's the only moving part. A burned out heating element, or a burned wire connection, is possible, but not the first thing to look for.
Generally, this kind of heater often lasts for years and years--and often doesn't. Once you're past replacing the plug it's not unlikely that repair will cost more than a new heater.
I'm not shilling for Home Ripoff, but they have a $60 "baseboard" (type) heater with remote control that I'm looking at, I've read good reviews about it. However look closely, it's very long, and sticks out from the baseboard more than you might expect.
Mar 28, 2010 | Pelonis Heating & Cooling
The oil does not circulate or lubricat anything. It just holds heat. No harm done.
Eric
Dec 01, 2009 | Pelonis WM-HO202C Oil Filled Radiator...
Won't heat
Is there a thermostat? where are you from and do you understand electrics? do you have a volt meter?
Dec 22, 2007 | Pelonis WM-HO202C Oil Filled Radiator...
Pelonis HO0218 Oil Filled Electric Radiator Heater Logo
119 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
