Question about Music
Korg triton extreme synth. L/r outputs work fine by themselves put plug in both right side cuts out using headphone jack instead if you pull the right slightly out of input you get both sides working
Pul right side audio cord slightly out and both sides work
    New Friend:
    Problem Solver:
  • 5 Answers
I need more info to correctly troubleshoot this. However my best guess from what your telling me is that its either the Audio jack on the Korg or the headphones. If everything else is working properly replace the headphones and the Audio outputs. Post again with more details if that does not work
Posted on Jan 05, 2013
SOURCE: Problem using Kaoss Pad for synths.
Okay, maybe this is rude, but TOTALLY ignore Musicaldude's solution, if you haven't already found out the ugly way. Boosting the signal that goes into the KP will just make the input LED light up red and you'll hear digital clipping [gross] and eventually hit a ceiling of all-crappy-staticy-noise and no real guitar left. Having it in the FX loop, and the Headphone-out workaround are smart moves already, except the Headphone out adds noticeable noise/hum vs the usual outs. But to help close the gap between your guitar's volume and the miniKP's internal synths (and program 63 and 65's feedback noizes, which build up even louder than the synths) unplug one of the RCA plugs from the KP's OUTput, pick one, left or right, whichever. You'll notice this gives you a guitar volume boost. BUT its still not enough...the synths and 63 and 65's feedback are still speaker-blowingly loud. Check the manual, it says you can adjust the wet/dry volume by holding down Tempo and Preset A together, then turning the knob and picking 1 thru 99. Make sure you're on the synth setting you want to use already. Do this thing. Play the synth with your finger, while you lower the number with that knob. Stay around 50 if you've got the one RCA plug dangling, around 20 if both are in. Whatever you think matches your usual playing volume. When its where you like it, hold the A or B button (wherever you want to save this) down and click Hold, this will save it onto that preset button. Now from now on, NEVER use 63, 65, or the synths if you're on whatever preset you DIDN'T just save. i.e. If you chose preset B, from now on you can just tap preset B and it remembers your volume adjustment from before, voila, normal-volume touchpad synth. But go back to preset A for every other effect, or you'll barely be able to hear the FX. KORG should've given us more preset buttons to save onto. Godspeed. I've never seen this site before, but I have this pedal, and experienced the same b.s. myself. Now I'm down to one preset button and quick knob-turning. Whee.
Posted on Jan 19, 2009
SOURCE: Roland MV 8800 No inputs, phono
Hi, post on mvnation.com, they will be able to help.
Posted on Feb 07, 2009
CRTN
  • 716 Answers
SOURCE: Line 6 Spider 2x12 100w combo - Input jack issue
Its a 1/4" mono Panel-Mount Audio Jack
and can be bought at
Radio Shack, Best Buy, Any Music Store
Click Here
Average price about $3.00
Posted on Mar 10, 2009
  • 4234 Answers
SOURCE: Right side audio cutting out on a Mackie 32-8 mixer board
Try cleaning al of the sliders using an electronics cleaning spray. Choose one that contains a lubricant as well. Dirty sliders can cause this especially at low volume levels. If that does not cure the problem, there may be a defective IC inside the unit. Many mixers use opamp ICs as buffers and final stage amplifiers. These are inexpensive and can fail in that manner. Without knowing the specific make and model ogf your unit, I can't give you any details. Please post the make and model and I'll try to provide additional possibilities.
Dan
Posted on Apr 09, 2009
  • 5603 Answers
SOURCE: Peavey 115 Low hum Low volume from input
The preamp section has a problem. It could be anything in the preamp but is OFTEN the input jack itself. They take a lot of abuse.
Also the insert jack contacts that forward the preamp to the power amp if no external FX are used can go bad.
Additional things are circuit board cracks caused by rough handling and also controls that have had the knobs mashed in which can destroy the potentiometers they are connected to.
Posted on Sep 22, 2009
I can hear only one side of the sound coming out from Korg triton extream keyboard. It's not the cable problem for sure. i tested both the earphone out put and the Left and right out put. Did a
So you're saying with headphones you also only hear one side? I would suspect the internal amp is panned all to one side. There are also several other settings in this unit where pan can be set so you may have to check several areas. If you don't have any specific custom settings made I would try a restore to factory defaults. If that doesn't resolve it you likely have a hardware failure which is likely not repairable. I strongly suspect a panning issue though.
Aug 18, 2012 | Korg Music
Microkorg sounds are off but lights are on and midi works, but i hear no sound it the headphones
Look into all the settings, some of these has a setting to turn internal speaker jacks on and off. I have a casio that can turn them off when playing into the computer.
May 04, 2012 | Korg MicroKorg synth (includes microphone)...
Sp250 right outout seems to have broken and as a result there is no sound coming from the speakers on the keyboard or through the PA. If we use the left output through the PA - it works, Could you advise...
Check if headphone jack also has right channel dead... If headphones work on both channels, switch contacts on headphone jack MIGHT be the problem.
Jan 17, 2011 | Korg SP-250
The external speakers attached to my m audio prokeys 88sx are no longer working. I have replaced the fuses in both but the fuses blow on power up. I then used the keyboard with a set of headphones. One of...
It is NOT likely the keyboard is "killing the speakers"... OR the headphones for that matter.
I suspect the problem is bad switch contacts in the headphone jack that cut off the speaker line outputs when headphones are plugged into the pro keys. These jacks are, to put it bluntly, JUNK... they are EASILY damaged by pulling the cable plugged into them sideways. You will need to service the unit.
Jan 16, 2011 | M-Audio Pro Keys 88 Premium Piano
Damper pedal no loner works. Could it be just a loose wire? screws on bottom have been lost.
Take it apart and see if there are any loose wires. If not, try to find screws that will replace the lost ones.
Jan 04, 2011 | Korg Ds1h Ds 1h Piano Half Damper Switch...
I have a new kaoss kp and when I put headphones in there is no sound. I dont have a cable to plug it in to the computor. Is there something I have to do to the settings or is it simply not working? Cheers
The Mini KP is an effect processor primarily. Sound passes in and through either with or without processing and effecting. Due to this fact you must have an incoming signal to process, or you wont hear anything. However there are a few settings that act more like a synth and tone generator.To initiate an effect you must touch the pad and hold contact. There is a hold button on the lower left side facing down. If you hit this button while an effect is being created, then you can let go without the effect stopping. You can adjust the effect in real time as well. Out of the 99 presets if you have tried them all with absolutely no sound output, then the problem is physical and will need a repair man/woman.
Dec 12, 2010 | Korg Mini Kp Kaoss Pad
Marshall MG50 DFX amp line out/headphones not working
Contrary to what's posted above, the Marshall MG series does not pass the speaker power output through the headphone jack, and inserting the headphones into the jack does not disable the speaker. The headphone amp is a separate circuit and it's input is taken before the master volume. So Jan's post is exactly right. Turn off the master volume and turn up all the other gain/volumes as high as they will go. The other issue is that the headphone jack's output does not drive low efficiency headphones well, so you need some headphones similar to Sony's MDR-V700s to hear it well. Earbuds just don't cut it.
Mar 07, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
A ''static'' sound coming from ALL outputs of Korg Triton
try cleaning ALL the contacts involved with Caig DeOxit (D5, S5. F6, G5, etc.) products*, they work very well. e.g.; cables, inputs, outputs, and (if you're confident) all the contact points "under the hood". this static you speak of sounds like less than stellar contact points and can addressed at home if you've the motivation to DIY.
* amazon.com/D5S6-Contact-Cleaner-F5S-H6-FaderLube/dp/B00HNV7WI2?SubscriptionId=AKIAILSHYYTFIVPWUY6Q&tag=duckduckgo-d-20&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B00HNV7WI2
Mar 31, 2017 | Music
Aug 07, 2008 | Korg Mini Kp Kaoss Pad
Music Logo
94 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
