Question about Dacor 72731 - KNOB, PGM COOKTOP
Dacor 72731 - KNOB break all the time
Does anyone know of knobs that can be used to replace the original Dacor 72731 - KNOB on a gas cooktop ? The original knobs are junk They break way to easily.
SOURCE: My Dacor PGM365 knobs keep breaking off and I
http://www.reliableparts.com/ - DACOR refuses to fix the fundamental quality issues with the knobs. I've replaced a dozen in the past few years. I will never buy Dacor again because of the customer support refusing to acknowledge the issue.
Posted on Aug 03, 2010
SOURCE: Dacor Cooktop gas conversion
Where did you purchase the kit? Can you name the store with number or list the website? Also the part number information. Thanks
Posted on Feb 01, 2008
  • 110 Answers
SOURCE: Dacor cooktop ignition problem
TAKE THE BURNER CAPS OFF AND CLEAN THEM REALLY WELL AND MAKE SURE THAT THEY R PUT BACK ON PROPERLY THRER ARE GENERALLY A NOTCH THAT HAS TO BE LINED UP JUST RIGHT FOR THE CAPS TO FULLY SEED TO PROMOTE PROPER LITING
Posted on May 30, 2008
  • 110 Answers
SOURCE: Dacor PGM 304
ON DACOR AS WELL AS THERMADOR YOU HAVE TO TAKE ALL THE BURNER CAPS OFF AND INTHE CENTER OF EACH BURNER CELL YOU WILL SEE A RELEASE NUT THEIR ARE 3 TO 4 DIFFERENT TYPES BUT THE MOST COMMON REQUIRES 13/16 SOCKET OR A 3N1 PUTTY KNIFE TO UNSCREW THEM. BE VERY VERY CAREFUL IF THE NUTS DO NOT COME LOOSE FREELY DO NOT FORCE THEM!!! USE SOME LIQUID WRENCH AND LET IT SOAK FOR A WHILE THEN ATTEPMT AGAIN. OTHER WISE YOU WILL MANGLE YOUR GAS TUBE AND ORFICECES AND HAVE 7OR 8 PARTS TO ORDER INSTEAD OF ONE
Posted on Jun 01, 2008
  • 10865 Answers
SOURCE: Can't remove Dacor gas cooktop knobs-afraid too pull harder
The Dacor knobs have a history of breaking easily. For that reason I recommend that you clean them in place using cotton swabs, tooth brush, etc. WHatever cleaning agent you use, put it on and let it sit for 5 minutes to loosen up any grime.
They do pull off but they often break and they are pricey to replace.
Please rate my answer.
Posted on Feb 12, 2009
My Dacor PGM365 knobs keep breaking off and I can't find a place to get replacements. do you know of a source?
Jul 20, 2010 | Dacor 36 in.PGM365 Gas Cooktop
10-12 year old dacor 4 burner epicure cooktop --left front burner
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 29, 2010 | Dacor Epicure ESG366 Gas Cooktop
R rear burner not sparking
heatman101
May 02, 2010 | Dacor Preference SGM365SS Gas Cooktop
DACOR COOKTOP PGM-3651S
The top of the unit must come off. I suggest a qualified Dacor tech.
Mar 15, 2009 | Dacor 36 in.PGM365 Gas Cooktop
Feb 09, 2009 | Dacor Preference SGM365SS Gas Cooktop
No gas to hobs
use mactches for ur gas burner if the ignition not really work.put all gas in off position b4 cleaning by using a vacium in the place of the control knob,turn off the power b4 try to clean,tnx
Nov 24, 2008 | Dacor Preference SGM466 Gas Cooktop
Dacor SGG365 one burner control won't cause spark
your problem is most likely the spark switch, but it could be you spark module but that is highly unlikely
Oct 22, 2008 | Cooktops
Dacor PGM 304
Mar 12, 2008 | Dacor Preference SGM304 Gas Cooktop
Oven Striker
If I'm not mistaken, these dacor cooktops have an automatic re-ignition (meaning if the flame goes out, it will just relight it without you having to do it) If none of your burners will light, you probably have a bad spark ignition module. These are somewhat hard to change, as you have to take all the burners off and disconnect the spark wires and take the whole top of the cooktop off to get to the inner workings. Also, to get these burner bases off it takes a special tool by dacor, AND you usually have to replace all the burner seals once you take them apart.Your other, simpler option is to unplug the cooktop and plug a lamp or something in to the outlet the cooktop is using, just to make sure you have power. Just cause the breaker doesn't look like it's tripped, doesn't mean it isn't bad and the outlet is dead. Hope this helps!
Oct 12, 2006 | Dacor Preference SGM466SS Gas Cooktop
Dacor 72731 - KNOB, PGM COOKTOP Logo
100 people viewed this question
Top Dacor Cooktops Experts
jdthefixer
Mike
Mike
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
