Question about Vacuums
Need Bissel 1719 series, 1718 series wiring schematic. Charging circuit has burnt resistor. Need to know resistor details
2 Suggested Answers
SOURCE: Need Bissel 1715 wiring schematic. Charging
Can not believe NO ONE could answer this.
The R1 resistor basically drops the 9V to around 5V for charging the battery pack. The resistor is a 10 ohm , 2 watt resistor. The other resistor is 220 ohm. This only limits the current to the LED.
The 10 ohm resistor burnt because the battery pack was left to sit too long without use and charging. So the cells shorted causing excessive current through the resistor when you attempted to charge the batteries.
After replacing the resistor, you will need to replace the battery pack before charging. Otherwise, you'll just burn the resistor again.
Posted on Dec 23, 2010
How do i put the wand back together on a rainbow e-series ?
The wire schematics in the handle assembly has four total wires. Two from the hose and two from the Receptacle Nozzle. Take one wire from the hose and one wire from the receptacle and connect together. Take the second wire from the hose and connect to the Switch Handle PN2E PN2. Take the second wire from the receptacle and connect to the other switch terminal. If you need more details, you can download the schematics at Rainbow Vacuum Schematics or you can call us at 800-523-0510.
RainVac
www.rainvac.com
May 30, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Burned resistor
I had two of them like this. Order resistor at Digikey. Match the resistor color rings to the online decoder at Digikey so you get the right one. Refresh the Ni-cd battery while you're in there. Search "youtube" for battery fix. It's easy to do.
Feb 02, 2013 | Bissell SpotLifter 2X Portable Deep Carpet...
I just adopted a Bissell 1719 spot cleaner from my sister-in-law but they don't have the manuals. How do I change the battery? I don't see any removable clips, just screws in the unit housing
Good evening,
Please see the below link for the user guide/manual to this unit:
http://www.retrevo.com/support/Bissell-1719-Vacuums-manual/id/10659bh140/t/2/
This unit should include a charger for the battery. Below is the instructions on how to charge and maintain the battery.
If you need to actually replace the battery, the instructions below show the process:
Just a quick note, these units do come with a Ni-Cad battery, which should last you at least 5 years (closer to 6 or 7), and make sure that dispose/recycle the battery properly.
This can all be found in the manual (link provided at the top). I hope this helps, and please let me know if you need clarification. Please rate this solution!
Thanks,
~PCF
Mar 15, 2011 | Bissell 1719 Spot Lifter 2X® Handheld...
My wife's Viking 6690 smoked this last weekend. I opened up the end where the power switches are and the board had a 0.01 ufd capacitor the blew up. That would be easy enough to repair. However when the...
According to you your machine's resistor burnt out. This resistor is located above the 240 volt capacitor which white base. change the resistor soon. For color code of the resistor you can follow the manual. You can visit also the product website for tech assistance.
Mar 10, 2011 | Vacuums
Need Bissel 1715 wiring schematic. Charging circuit has burnt resistor. Need to know resistor details.
Sep 27, 2010 | Bissell 1715-G Spotlifter Bagless Handheld...
My brand new bissel little green proheat pet series is spraying solution however it's not hot when it comes out. I put hot water in the tank & turned the heater on. Isn't this the whole point?
Have you checked the user manual? Can be found at http://www.bissell.com/searchresults.aspx?searchtext=little green&mode=userguides
If there is no element then the water will cool down naturally.
May 21, 2010 | Bissell 1425 Little Green ProHeat Handheld...
Bissel Proheat 2x circuit board
Use this link: http://www.4cleanerfloors.co.uk/cgi-bin/product.pl?PID=1278118_amp;brand=Bissell_amp;model=_amp;part=
I had the same problem. Ordered a PCB from Bissel it took 2 weeks to arive. I fitted it, then it blew again, turned out the brush motor was short circuiting. Ordered a new motor it took 10 weeks. I have now had to order the second circuit board.
Over 3 months to get this vac fixed - my advice is - don't buy Bissels!
Jul 09, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9400 Carpet Cleaner
I assume you checked the belts to see if any cogs were stripped of of the belt. If ok, then I wuld suspect the brush roll motor, it is any inexpensive part and doesn't take much for it to fail. Undo the top so you can get to it and unhook the belt and see if it still shuts of, if it does, ten replace it, it it doesn't, then there is a problem with brush rolls or belts.
May 13, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
Vacuums Logo
69 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
