Question about GE Energy Star WCVH6260F Front Load Washer
Off balance??? When I turn the washer on to a cycle it does the first initial turn one way then a turn the other way and then just stops. At first I thought it just wouldn't drain so I cleaned the pump filter, which was extremely dirty. But it still does the same thing and also doesn't drain. If it's not the pump filter, is it off balance? If it is off balance, how do I fix this? sslinkard
  • Samantha Slinkard Oct 12, 2007
    I unscrewed the bottom panel. It has three screws at the bottom to do this. There is a white circular lid in the middle. This is the pump filter. unscrew it. Warning! there will be a lot of water!!!. Then you can clean it out.
Can I ask you how you cleaned the pump filter? I had the exact same issue with my machine (GCVH6260HWW).
Posted on Aug 28, 2007
    President:
  • 1,294 Answers
Try to see if there is any block in the hose coming down from the tub to the filter
Posted on Jun 28, 2007
SOURCE:
Why does my washer gets off balance during the spin cycle and how to repair it
A QUICK FIX IS TO OPEN THE DOOR TO STOP WASHER, THEN RE-DISTRIBUTE THE LOAD SO IT BALANCES OUT IN THE SPIN CYCLE. OR, REMOVE SOME OF THE CLOTHES, IT COULD HAVE TO MANY IN IT.
Feb 21, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing machine shuts off before cycle is finished now it will not last one min. on before it shuts off...what to do?
We have a front-loading LG washer. Today, I took a look at it when it was beginning the spin cycle because it sounded a bit different. I noticed that it was beginning to spin and would stop because [I believe] it was detecting a strong off-balance. It would then try to spin in the opposite direction and the same happened. After two more attempts, it automatically shut off with no warning nor error. We set the washer to wash and spin again and I began to work on balancing it. After adjusting the feet and waiting for the spin cycle again, it continued successfully because of the reduced off-balance. I'm not sure if there are other reasons that would cause the washer to turn off. This is the only one I have come across so far.
Oct 22, 2009 | LG WM1812C Front Load Washer
Kenmore washer won't stop filling during initial wash cycle
I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
Washer stops several times in the middle of cycle
possibly it could be your un-balance switch getting very sensitive to any type of movement of the machine, normally they only actuate during the spin cycle when you have a very off balanced load of clothes
Oct 03, 2009 | GE Profile Prodigy WPSE4200A
The machine stops after the wash cycle and won't finish.
The code is UE
load too small.
• Load is out of balance.
• The washer has an imbalance
detection and correction
system. If individual heavy
articles are loaded (bath
mat, bath robe, etc.) and the
imbalance is too great, the
washer will make several
attempts to restart the spin
cycle. If an imbalance is still
detected, the washer will stop
and the error code will be
displayed.
• Add 1 or 2 similar items to help balance the load.
• Rearrange items to help balance the load.
please rate this help to keep the service online
Aug 20, 2009 | LG Washing Machines
Will not spin or agitate
Get the model number. It may have an off balance switch that is stuck. Try moving agitator like its off balance and then turn on.
May 18, 2009 | Washing Machines
The rinse cycle no longer works
Likely the balance sensor is failed - or the motor controller itself.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 16, 2009 | Washing Machines
Pounding noise after wash and final spin
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    if this helps please give a fix ya vote
  • Jul 14, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Stops mid cycle
    It may be a out of balance alarm during a spin cycle. Re-balance the clothes and hit start.
    Jun 12, 2008 | Fisher Paykel EcoSmart GWL15
    Zanussi wdj 1094 washer dryer
    possibly the motor brushes are worn, the clicking is the pcb relay changing the motor direction.
    May 19, 2007 | Zanussi FJS1225W Front Load Washer
    GE Energy Star WCVH6260F Front Load Washer Logo
    199 people viewed this question
    Top GE Washing Machines Experts
    Marvin
    Marvin
    geapptech
    jimorris77
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
