Question about Samsung HL-R6167W 61" HDTV
Tv would not come on at first. so would unplug for a little while and then turn back on. would come on eventually but with a messed up screen, green lines, etc. after it warmed up, and you would turn it off during a commercial and back on, it would eventually work its way clear... sometimes immediately.. also would hear noises like... so we took it apart and found pieces of glass in the color wheel. cleaned it all out and it worked perfectly UNTIL one night it made a huge POP and blew the bulb. We ordered a new bulb and replaced it but it kept shutting itself down with a perfect picture. So we ordered a new ballast to make sure it was getting a connection. new ballast didnt make a difference... Now it wont turn on at all... turn it on and it will go through its 3 cycles of trying to come on but the bulb wont light. (new bulb and housing cause we didnt wanna risk the chance of messing up the bulb) ... when even bypassed the heat sensor to make sure it wasnt that, and other things... any suggestions?
Basti
  • 1447 Answers
SOURCE: colored vertical lines through picture
Hi-
I suspect 2 things, 1 is loose connection on cables and wiring, 2nd is main board- if product is still within warranty call samsung support and have a service tech deal with it- Home service...
Thanks for using fixya, keep us posted!
thanks!
Posted on Jul 01, 2008
lukster
  • 217 Answers
SOURCE: color wheel
could be a jumper on the DMD board that must be removed, look for a small sticker that points to the jumper, or it could be a setting in the factory mode, mute-182-power will get you in there, check the settings for the color wheel
Posted on Jul 18, 2008
  • 304 Answers
SOURCE: Samsung DLP HLS4666W White spots after replacing ballast
No. The DMD bd has gone bad and needs to be replaced. You have two options to repair your tv. The only two options will require a trained Samsung Tech to do either. Replace the DMD bd or the entire Engine. The Engine is a lot easier but more expensive. The DMD bd is more complicated to replace and will take longer thus increasing the labor cost because aligning the DMD bd takes time to do it correctly.
Posted on Jul 16, 2009
jdvillanueva
  • 2098 Answers
SOURCE: Problem concerns Samsung HL-S5087W.
3 blinking led light at the front panel is an error code for lamp malfunction. If you've already replaced the bulb and yet the symptoms remain the same, then high chance that the fault came from the ballast board because the supply voltage is present.
Confirm if the bulb will lit upon powering on the unit. Open the lamp cover, bypass the lamp cover switch by putting tape to make it in closed position (making it still the lamp cover is attached to the housing) and then power on the unit. Check if the bulb will ignite or will light up, if not, you have to replaced the ballast board.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Jul 14, 2011
Slinteriors
  • 8617 Answers
SOURCE: According to the description, the color wheel went
did you install the correct color wheel? Most of the samsungs had retooled bearings in some color wheels and often a jumper has to be installed for the color wheel to work properly. Your wheel should be a BP96-01103A another thing that can happen is the thin brown ribbon cable can get plugged in backwards and will prevent the color wheel from working also. That ribbon only has contacts on one side of the ribbon. I would double check that if the correct color wheel was received for your model.
Posted on Aug 08, 2011
Testimonial: "YOU ARE THE MAN! The ribbon wire was backwards!! Thanks for getting it right the FIRST time. Your colleagues were not as effective!"
My COby tv wont turn on.
I unplugged my TV for 5 minutes after 5 minutes I pressed the Power button on the side of the TV not the power button on remote for a full minute. Plugged the TV back in, pressed the power button and it turned on. Doing this essentially does a reset.
Dec 26, 2016 | Coby Televison & Video
Black screen- fixable?
probably a faulty internal PSU, changing the capacitors on the on-board PCB should fix it but hard to tell without opening it up and testing.
Apr 26, 2012 | Hannspree XV32 32 in. LCD Television
RCA L26WD12 - for as long as we've had it, it would have problems turning on, being the light would turn green, but the screen would stay black. We'd have to unplug it and plug it back in. Eventually the...
The tv Tuner signal board is the causes and the problems.That the board,where the tv incomming broadcasting signal cable wire plug into it.U can do the basic things like take it aparts and putting it back together again?Yes,Tries websites like Shopjimmy.com,Ebay.com to buy a tv Tuner signal board for the replacement.
Mar 23, 2011 | RCA L26WD12 26 in. LCD TV
I think the video cable for my xbox is messed up. Why does it keep showing up these little circle things? Whenever I turn on my xbox it doesn't come up anything but a black screen with little circles...
NOT HD: Make sure red goes to red, white on white, and yellow on yellow, also make sure the switch that is on the xbox wire plug says TV not HD.
HD TV: Make sure red on red, white on white, yellow on yellow, blue on blue, green on green, etc. Also make sure the switch that is on the xbox wire plug says HD not TC
Oct 18, 2009 | Microsoft Xbox 360 Console
Green power lite blinks but does not turn solid green
check the lamp...lamp cover under front panel on left... take out lamp (unplug TV befor doing this) and see if it is broke ....if lamp is good replace it and put it back together plug set back in and try it agen some times the conector dont make good contect so just taking out and in fixes it..... also lisen to the set when you turn it on most of the time there is a little buzz when it is trying to fire the lamp if the buzz is not there it maybe the ballast board
good luck
Nov 11, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Green Screen
Turn Tv off by power point unplug even for 30 or 45 minutes then turn back on. that way the tv has time to reset back to normal
Sep 07, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
60" Samsung HDTV
Thats a very good possibility. The bearings in the color wheel eventually wear out. Have you noticed any noises lately when the green is messing up.?
Jan 19, 2008 | Toshiba 52HM95 52" HDTV Projection...
LCD TV picture is green
I just called Vizio and they said to unplug the TV, then physically hold in the power button on the TV for 2 minutes.
Nov 19, 2007 | Vizio L37 Television
When power turns off then screen turns green
Yes look for a loose connection in the powersupply, this mean holding up the circuit board and looking underneath. Be careful and unplug power from set. If you are not comfortable then have a tech do it. Maybe a bad cap in the powersupply also.
Aug 09, 2007 | JVC AV-48WP30 48" Rear Projection...
Samsung HL-R6167W 61" HDTV Logo
Henry  Thomas
Henry Thomas
