Sharp XG-PH50X Multimedia Projector Logo
A
Anonymous Posted on Jan 05, 2013
Sharp XG-ph50x projector. Lamp #2 red light blinking.
Use bulb in another XG-p50x and lamp #2 works fine with green indicator lights.
2 Related Answers
Anonymous
  • 3278 Answers
  • Posted on Mar 30, 2010
SOURCE: sharp xg-ph50x dlp projector shows vertical bars,
Hello.
That is an indication that lamp 2 is failing.
Hope this helps.
Anonymous
  • 12 Answers
  • Posted on Sep 12, 2010
SOURCE: The lamp indicator blinks to red after i replaced
PL RESET THE LAMP BYTAKING HELP IN MANUAL
The indicator of temperature is red, the indicator of the bulb is off and the fan after 3 o 5 minutes
PowerLite 7800p Multimedia Projector - Epson
www.epson.com/cgi-bin/Store/support/supDetail.jsp?...oid...
EpsonPowerLite 7800p Multimedia Projector. Support ... Indicator Light, Status, Description... Temperature, Red, The projector is overheating, which turns the lamp off ...
PowerLite 735c Multimedia Projector - Epson
EpsonPowerLite 735c Multimedia Projector ... Indicator Light, Status, Description ...Lamp/Temperature, Red, The projector is overheating, which turns the lamp off ...
Maintenance Indicators - ManualsLib
www.manualslib.com > ... > Notevision PG-F212X > Operation manual
The warning lights (power indicator, lamp indicator and temperature warning... ... Redon. Normal (Standby). Green on. Normal (Power on). Red blinks. Abnormal ... Sharpmultimedia projector model xg-mb67x-l operation manual (71 pages).
I have a Sharp XR-10X-XL projector, i have replaced the bulb but it still will not go on. The Stand by light and the bulb light are both on constant red, I have checked both the heat sensor and the fuse on...
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
I have a sharp projector RX30X the stand by light still red it doesn't blink and the device doesn't work what's wrong?
Have a nice day!
Jerry
Lampdeng Limited
Replaced both bulbs with brand-new bulbs. Now all
Verify that the lamp doors are securely closed. The blinking red lights indicate a lamp problem. In this case, both appear to be defective. I doubt that the lamps are the problem. double chack all connections and doors for proper seating. Update this if the problem remains.
Thanks,
Dan
My xg-e650ub also shut down while in use, and won't power up.
XG-C50
pls check the fans under the Optical Engine, under the prism
the fans easy to be failed
Have a nice day!
Jerry
Lampdeng Limited
XG-C50 Problem
Hello
Replace the fly-eye lens of projector.
Viren
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
