Question about RCA HD50LPW175 50" HDTV
Cannot start my 50 ' RCA Model RLDED5078A
Screen shows Please Run Auto Scan
Trying to start tv, screen says run auto scan again. cannot make it do that.
it sounds like you may not have a digital tuner in tv? if not you have to used a external digital tuner to your tv! they make many types, pick one up on line or local Walmart, etc! good luck!
Jun 12, 2017 | Televison & Video
RCA TV wont start
Could be an open internal fuse or power supply failure
Apr 12, 2017 | RCA Televison & Video
How to reset channel auto scan.After I finish channel scan,message pops up stating PLEASE RUN CHANNEL AUTO SCAN,
If when You scan, and you don't get at least one channel, it will keep showing You this message! look at screen it will show new channels! if no new channels check to make sure your coax is hooked up good, also make sure you are using right setting if outside antenna, select antenna, if cable select cable for your source!
Nov 03, 2016 | Televison & Video
I have av RCA RLDED5078A-D 50In LED I was watching it and the screen went black but I can still hear the sound!!
Probably the power supply board went out or the backlighting.
Unlikely it's the control board as the sound is still working.
Don't open up the TV to fix it yourself if you don't know what you're doing. There are HAZARDOUS voltages inside EVEN WITH THE TV UNPLUGGED!!!.
Find a couple of shops, get quotes, try to find reviews of the shops too. If it's still under warranty, by all means contact the company to get it fixed.
Sep 06, 2016 | RCA Televison & Video
Auto scan not working??
Make, model, and year please.
Jan 22, 2016 | Televison & Video
Antenna set up, channel scan
Asker resolved own issue.
Mar 17, 2014 | Televison & Video
Can't get rid of "Please Run Channel Auto Scan" stays on tv screen
for some reason it is not seeing you cable signal. you will need to make sure you have it set up for cable and not air. check your input options, like tv/av/hdmi/ ect hope this helps
Aug 05, 2012 | Dynex DX-LCD32-09 LCD TV
RCA HD50LPW175 50" HDTV Logo
243 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
