Question about LG Hbm-905 Tri-mic Bluetooth Headset - Graphite/silver
Lg hbm-905 bluetooth pairing mode - LG Hbm-905 Tri-mic Bluetooth Headset - Graphite/silver
sandrew
  • 2961 Answers
SOURCE: LG HBM 300 Bluetooth headset
Normally the default password for headsets is 4 zero's 0000, unless you have previously set one with the phone.
Posted on Sep 05, 2007
SOURCE: My Bluetooth wont be reconized by my phone
i found the fix for it. u first must turn the headset off. then hold the power/talk (same button) for 5 seconds or until the headset makes a weird beeping noise not the same noise as powering on. the headset light will blink as the headset light is blinking have the phone discover the headset. it asks for a pin number the pin number is four zeros 0000. and thats it u are all set. i couldn't believe there is no place on the internet to tell u this i had to call lg corporate office.
Posted on Dec 07, 2007
  • 6 Answers
SOURCE: lost passcode
9999 or 0000 or 99999 or 00000
Posted on Jun 21, 2008
SOURCE: HOW DO I PLACE AN LG BLUETOOTH HBM710 IN "DISCOVERY MODE" ?
Just came across your question while searching for the same answer - Here's what I found out:
When it's off, press and hold the on button for 5 seconds - it'll turn on, but keep holding until you hear the short beep - the light's on and you're where you want to be. Here's the full text that I found from the manual:
-With the HBM-710 off, press and hold the PWR/END button for 5 seconds
(You will hear a short beep and the LED indicator will stay red, when the device enters pairing mode)
-Using your handset, find the "Bluetooth menu" and "search for" or "add" new devices
- Select "LG HBM-710" from the list of devices and pair it with your headset
- When asked for the Pass/PIN code during the pairing procedure, please enter "0000" (4 zeros)
- Once pairing has been completed successfully, you will hear a beep
- After pairing successfully, be sure to "connect" to the LF HBM-710
- If you want to pair with other devices in the future, the headset must be in "Pairing mode"
- If it will be not connected the "Pairing" for three minutes, it will be turned off.
Posted on Apr 08, 2009
SOURCE: how do i put my lg hbm-210 in to pairing mode
Hold the power button in until a solid blue light comes on. It is then in pairing mode
Posted on Feb 26, 2010
How to connect lg hbm-730 bluetooth to dv4 laptop
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Feb 12, 2010 | LG HBM 730 Bluetooth Headset Wireless...
Can the LG HBM 550 be paired a second time to another phone?
YES IT SHOULD BE ABLE TO BE PAIRED TO AS MANY PHONES AS YOU WANT BUT WILL ONLY WORK ON ONE AT A TIME.
Sep 16, 2009 | LG HBM-550 Wireless Headset
Cannot place LG-HBM-710 in discoverable mode
It sounds as if the device is not paired with your Chocolate. Press and hold the button on the face of the HBM-710 headset for approximately five seconds, or until the light comes on and stays on steadily, then discover the device with your handset's Bluetooth screen. Once it shows up in the list of devices, select in and pair it with your phone.
Jul 07, 2009 | LG HBM-710 Wireless Headset
Hoe do i put the lg hbm-760 in pairing mode????
Turn it on by holding the power button for four seconds, Then go to your phones bluetooth setup screen, search for new devices, and pair it. The blue led on the HBM-760 will turn solid blue during pairing. It is always discoverable. The default passkey is 0000. Hope this helps.
Jun 22, 2009 | LG Car Charger For HBM-710, HBM-760...
Apr 03, 2009 | LG HBM-710 Wireless Headset
Pairing 730 and lg vx 860
To put the LG HBM-730 into pairing mode you must press the MFB for 5-10 seconds from power off. Pairing mode is denoted by the LED glowing solid red. LG has chosen to stick with the default pairing code of '0000'. Using Bluetooth specification 1.2, as is the custom, the HBM-730 supports both headset and handsfree profiles.
I found this on the internet and hope it works for you
Sep 05, 2008 | LG HBM 730 Bluetooth Headset Wireless...
HELP....
Well my user manual for HBM-550 says:
Prior to using the Headset for the first time, you must pair it with a Bluetooth enabled handset.
With the HBM-550 off, press and hold the Pwr/End button for 5 seconds,
You will hear two short beeps and the LED indicator will flicker in red and blue alternately, when the divice enters Paring Mode.
Using your Handset, find the Bluetooth Menu and "search for" or "add" new devices.
Select "LG HBM-550" from the list of devices and pair it with your handset.
When asked for the pass/PIN code during the paring procedure, please enter "0000" (4zeros).
Once paring has completed successfully, you will hear a beep.
After paring successfully, be sure to "Connect" to the HBM-550.
If you want to pair with other devices in the future, the headset must be placed in pairing Mode.
If the HBM 550 is in "Paring Mode" for 3 minutes, without being paired to a device, the Headset will automatically turn off.
Aug 13, 2008 | LG HBM-550 Wireless Headset
Bluetooth HBM-730
just set the bluetooth earpiece to pairing mode and start searching bluetooth devices from your phone.
If you don't have a manual, just post back.
Feb 06, 2008 | LG HBM 730 Bluetooth Headset Wireless...
How do you put the LG earpiece in pairing mode???
0000 worked great for my LG to Motorola Headset Pairing. Thanks
Mike
Oct 11, 2007 | LG HBM 730 Bluetooth Headset Wireless...
I can set up my headset to my new phone
Step 1 - Enable Bluetooth functionality on the Motorola V3m. Note: The Bluetooth power must be set to ON position to pair the device. From the main screen, press Menu [Center NavKey]. Scroll to Settings & Tools. Scroll to Connections, press [Center NavKey]. Scroll to Bluetooth, press [Center NavKey]. Scroll to Setup, press [Center NavKey]. Scroll to Power XXX, press [Center NavKey]. Scroll to On or OFF, press [Center NavKey]. Step 2 - Put your fully charged Bluetooth headset into pairing mode. Start with your Bluetooth accessory powered off. Hold down the power/end key for 5 seconds. You'll hear a short beep and the LED light turns red. Your Bluetooth accessory is now in pairing mode and ready to be paired with your handset. Step 3 - Pair the Motorola V3m with a Bluetooth Accessory. From the main screen, press Menu [Center NavKey]. Scroll to Settings & Tools. Scroll to Connections, press [Center NavKey]. Scroll to Bluetooth, press [Center NavKey]. Scroll to Handsfree, press [Center NavKey]. Place accessory in pairing mode. See accessory pairing instructions. Scroll to Look For Devices, press [Center NavKey]. Phone displays Scanning. Scroll to XXXAccessory NameXXX, press [Center NavKey]. Phone displays Bond With XXXAccessory NameXXX. Press Yes [Right SoftKey]. Phone displays Enter Passkey. Enter 0000, press [Center NavKey]. (See accessory instructions as passcode may vary.) Phone displays Connected.
Jun 17, 2007 | LG HBM 730 Bluetooth Headset Wireless...
LG Hbm-905 Tri-mic Bluetooth Headset - Graphite/silver Logo
88 people viewed this question
Top LG Radio Communications Experts
TO Lady
Computer Repairing
Computer Repairing
Michael Vincent Cruz
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
