Question about Frigidaire GLTF1670A Front Load Washer
I have a front loading frigidaire washer gallery 1670 series
It is leaking water underneath and I was wondering if it is worth fixing. It is 7 years old.
  • Anonymous Jan 25, 2009
    both shock absorber assy.(on both sides) are broken. water is leaking from machine
  • 220 Answers
I would say yes, its worth keeping. Mine leaked a while ago and I bought a new pump assembly. I think it was about $70. You can remove the two screws on the bottom of the bottom face plate and remove the cover. The pump is on the right side. Look for goo leaking out of the shaft seal. Verify before you buy parts, It could be the rubber boot torn or something similar.
Don't reach inside untill its unplugged.
You can replace the shocks easily too. Lots of parts places online with illustrated parts catalogs.
Posted on Feb 03, 2009
Frigidaire gallery series Model GLGH42FS1 stackable washer leaking
see this causes and fix it. God bless you
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is down under neath. To disassemble your washer follow the appropiate tutorial. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Tub Seal
This is in the center of the tub. The seal is inexpensive but will require some labor to install. Check the tutorials on disassembling the cabinet then remove the agitater and inner tub. Enter your model # above for a diagram or illustration.
Oct 11, 2012 | Frigidaire Washing Machines
My Frigidaire Gallery front load washer is leaking water from underneath. Ideas?
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Check for tips on the link below to identify parts and removal:
Sep 03, 2011 | Frigidaire GLTF1240A Front Load Washer
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
I have a Frigidaire gallery series front load washer that flashes an E10 error code. What is this for.
E10 = long fill.
Check hoses, faucet and water valve screens first. Clean if necessary. If this did not help - something has failed in the washer, either the pressure switch, control board, or water valve.
Apr 10, 2010 | Frigidaire ATF6000ES Front Load Washer
I transported my frigidaire front load washer.water leaks.
Check your pipes /drain and sump hose sounds lie something has came off in transit
Apr 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire gallery series front load washer leaking water on side where soap dispenser is. Have had two different repair places take a look at it- replaced soap dispenser- still leaks - repair people can't...
turn down the water pressure on the water line to the washer if the water pressure is to high it will splash out of the filler. there should be a vale on the main water line to the washer.
May 19, 2017 | Frigidaire Gallery Supreme Series...
I have an 11.5 year old Frigidaire Gallery with an increasing leak present at the end of each load. A drip pan has been enough to catch it so far, but am concerned I'm seeing more and more water. Expected...
could have a leaking drain hose, pump. If your handy and dont want to spend several hundred dollars for a new washer and the washer is working fine veside the leak, I would just fix the leak.
Aug 29, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Jan 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer fills with water but will not agitate to wash the clothes.
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire GLTF1670A Front Load Washer Logo
166 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
