Question about Technics SA-AX540 Receiver
Terrible sound I used this unit for around 3 years without a problem and then it sat in a storage unit for aprox one year. I just picked up my things from storage and went to hook up my JBL control 5 monitors to mess around with some sound and now when everything is connected I get zero sound up to about 40% volume and then start getting a little bass at that point. From 40% to 100% I get small amounts of bass and I can barely hear the highs and words. Along with the audio problems the light on the input selector knob has gone out although it allows me to still change between the different inputs. The problem affects all inputs in the same way, and when I turn the knob to change inputs I hear a POP sound through the speakers and the music will increase slightly in volume for a split second before going back to the way it currently is. Both speakers "A" and "B" have the problem, all inputs, and I have tried multiple speakers and CD players to test the problem. I took the cover off to see if it was something obvious, and dont see any loose solder points, and there isnt even much dust. It has been a great reciever and I really dont want to have to buy a new one, but if possible please tell me if the problem would cost more to fix than it would be worth. Thanks in advance for any help you can give me =D
  • scott grant Jul 02, 2007
    I decided to take it apart a little further and see if there was anything behind the circut board that I can see is obviously wrong. Well, I found the problem and I think its pretty much the end of the reciever, but I wanted to ask and see if there's some way to fix it that I have just never heard of.
    The corner of the circut board is cracked completely off and it seperates about 4 of the solder lines (or whatever you call them) at the top and botom of the corner. The lines are too small for me to solder them back and fix it myself which is why I think the end is nigh =(
    thanks for the help, and if anyone has any sugestions please feel free.
    Novelist:
    Champion:
  • 219 Answers
Maybe your tape monitor button is pushed or something along that line of thought. Check all your switches and buttons in front and back of the unit for proper position.
Posted on Jun 28, 2007
6ya staff
SOURCE:
My car idles fine, but lurches and surges after warm up.
Tune up could be bad plugs dirty and rusted.Use AC Delco.Any codws?
Oct 10, 2016 | 1993 Pontiac Grand Prix
Hi, My Bosch Model B20CS50 SNI/01 side by side
It sounds like the fridge is in need of a regas, but that seems unlikely after only three years, although not impossible. An indication of that would be if the compressor could be heard to be running all the time. If it cuts out after running only a short time it could be the thermostat that has gone faulty.
Mar 23, 2011 | Bosch Appliances 20.19 cu. ft....
Dell pv755 has no display, red light when computer is on. 7 yrs old,time for new monitor?
no necessary, the lcd monitors have a use life of aprox 5000hours or 2 to 5 years.... you can chance the capacitors because that´s the first thing that get old for the use, if your monitor have this 7 years without trouble maybe this could be the fail....
Aug 12, 2010 | Optoma PanoView PV755A 15" Flat Panel LCD...
Hi, I have a marshall VS65R I bought in 96. It sat in storage for close to 8 years. I plugged it in and it sounded great....a week later at band rehearsal I played two songs and the sound went out...I...
Some of these have electrolytic caps in the power supply that are nearing end-of-life. I would take unit in for servicing if you are not electronically adept.
First thing though, check for a bad input jack as these often go bad. A wiggle test of the plug should make that possibility reveal itself.
Jun 15, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
No satellite signal pick up
Yes ! 3 years is at the end of the expected lifespan of the battery
Jun 30, 2009 | Garmin Forerunner 205 GPS Receiver
When antenna is open screen starts flipping out of control
TRY USING AN EXTERNAL ANTENNA. THIS SOLVED MY SIMILAR PROBLEM.
LENN
Mar 20, 2009 | Garmin iQue 3600 GPS Receiver
Bose 5disc changer trys to pick up any disc just makes noise of motor running, sat not used for year.
I called bose,they sent me e-mail info send around $85 and the unit,they send a new unit. no repairs not bad I guess. Open one up if you get the chance, thats why no repairs! Enjoy-- d.g.d.
Dec 28, 2008 | Bose Wave Radio
96buick century won't start on occasions
im not exactly sure ,but the same thing happened to my sunfire and it was the fuel pump.....u can pick those up for around $50-60 bucks at a junkyard.....it sounds like ur not getting any fuel flow...sorry thats all i can think of hopefully this was helpfull;)
Nov 12, 2008 | 1996 Buick Century
Maxtor Personal Storage Unit 3200 - Model U01E100
it makes no difference how old the drive is, unless you transfer the same amount of content everyday and can chart and predict. It  might help to wrap your mind around the actually capacity and extent of files you trasfer and use. If that drive is a 200GB....1 gigabyte is roughly 1 cd and a half. A compact disc can hold 700MB, or gauge it to like a ipod.  So if youre possibly transferring say 2GB per day, you will reach the max of the drive in 3 months?
2GB X 90 days=180GB
If you are using graphic applications, or video...you may want to look towards a 320 GB or 500GB as things only get larger with current computers........Just 3 years ago, who knew what a gigabyte was? Now we own drive in upwards to 1TB ( terabyte ).
keep me posted..
Oct 24, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Technics SA-AX540 Receiver Logo
74 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
