Question about Bushnell Optics 2x24 262024W Prowler Waterproof Night Vision
Replace water boss magnetic disk - Bushnell Optics 2x24 262024W Prowler Waterproof Night Vision
How to find a boss speaker serial number for registration
most are located on magnet assembly somewhere if not look speaker over very thoroughly hope i helped
Feb 17, 2013 | BOSS AUDIO SYSTEMS Car Audio & Video
Hello - I have a Boss RC-2 Loop Station. While I enjoy the pedal's capabilities, it almost always creates an unwanted hum and sometimes an electronic pulse in every amp I use it with. (I typically keep...
Make sure the power supply for this is powered from the SAME receptacle as your amplifier is powered. Keep the cable from this to the amp fairly short and high quality cable. Keep guitar away from magnetic field sources... the wall wart adapters are notorious for generating magnetic fields.
Jul 20, 2011 | Roland Boss RC-2 Loop Station Stompbox...
My Saeco Incanto Deluxe keeps giving a message "Fill Water tank" even though the water tank is full. Does not allow me to choose any other options. Please Help.
Your machine has a magnet that floats in the water tank. If the magnet is not floating when you have water in the tank then you need to replace the magnet. You can also try to clean the magnet before replacing. It may be dirty and tends to stick to the water tank.
This is what it looks like. http://www.cerinicoffee.com/item.asp?PID=1318
May 15, 2011 | Saeco Vienna De Luxe Espresso Machine
Does this boss chaos c550 amp match up to perform correctly with 2 12inch kenwood peak power 600 watt magnet 500g (17.6)oz impedence 4 ohm kfc-w300s speakers
It's not bad, but at 400 watts, it's a bit underpowered
It'll be plenty loud, but the amp will distort before the speakers do, particularly if your subs are wired in parallel (as dual-driver boxes are typically wired)
Listen for distortion, and turn it down a bit if the sound gets fuzzy or static-y sounding
Feb 03, 2010 | Boss C550 Car Audio Amplifier
Reloading backed-up song data on Boss Micro BR
Are you transfering from one disk to another on your computer? There is a possibility that the format of the original disk is not being recognized.
Nov 29, 2009 | Boss Micro BR Digital Recorder
Boss BR 8...I insert the 100 mb disk, then asks to initialize..I enter 'yes' then it asks 'sure?' I enter yes then it says 'medium error' then ejects the disk..what's the problem?
If the disk had data put on with a PC you might try deleting all files and folders using the PC before formatting the disk in the BR8.
It is also possible that the media has gone bad.
A final try would be to degauss the disk and try to format on the BR8.
Sep 09, 2009 | Boss Micro BR Digital Recorder
"Fill water tank" prompt
this has happened to me too just yesterday (26 May 2013), I replaced the tank because I was lucky to have kept the spare bits off the old machine I had and it worked fine. Over time, the water gets into the float and corrodes the magnet. Best to just replace the magnet if you can or the whole tank. Good luck
Oct 26, 2008 | Saeco Royal Digital Plus Coffee...
The add water light stays on not matter how much water is in the reservoir
lot of time you have a magnet in the water tank fill it with water and gently tap the side of machine the magnet is block or jam on empty
THANKS FOR USING FIXYA
PIERRE
Feb 24, 2008 | Keurig Elite B40 Coffee Maker
Add Water
Turns out I finally called Keurig and explained the problem (says to add water when water container is already full...) and they told me that it was most likely an issue with the water container. They sent me a new water container about a month ago and it looks as though the problem has been solved!! Solution: Call Keurig and get a new water container!!!!
Dec 26, 2007 | Keurig B60 Coffee Maker
Fill Watertank Message
The black thing floating in the water tank is a plastic shell with a magnet inside. If you clean it...make sure you reinstall it with the tapered (smaller) side down. There is a slight size difference BUT it will make ALL the difference in the world.
I had no idea there was a magnet in that black/greyish case. The direction of the casing is important.
I had the same problem and that solved it!
Jul 29, 2007 | Miele CVA615 Espresso Machine
Bushnell Optics 2x24 262024W Prowler Waterproof Night Vision Logo
61 people viewed this question
Top Bushnell Optics Experts
George Merkley
George Merkley
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
