Question about Panasonic CQ-C1101U CD Player
No remote wire in stock radio
Ok so my bro has a 98 cadillac deville and we have every thing hooked up then we see theres no remote wire to power the amp how can i fix this what kinda wire do i need to get and were do i run it to and from
  • ridin4shady Jan 25, 2009
    yea we got it thanx but man i have another problem
    i got 2 10 inch subs there p1's rockford fosgates and i jus have them running to my stereo and the left sub wont work but its not blown and all the wire work right because when i hook the other sub to the same wires it works and the non working sub wont work on the other wires
    i know its not blown cuz theres no scratching noise and it dosent smell burned what you think it is
  • Anonymous Mar 17, 2014
    Where do I run my remote wire on my 97 caddilac deville
  • 26 Answers
You can use the accessory wire. The one that loses 12v positive when the key is turned off and has 12v positive when the key is on. If you can't find that you can use a switch. Find a constant, wire run it to a switch, then to the amp. If doing it that way, you just have to remember to turn the switch off when you shut the car off.
Posted on Jan 21, 2009
Wiring for 2006 cts stock radio
2006 Cadillac Deville Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Dec 03, 2016 | 2006 Cadillac CTS
Ford stock amplifier
need to wire the power wire for the amplifier to the remote wire on the aftermarket radio usually a blue wire on the after market radio
Feb 20, 2013 | 1998 Ford Expedition
So when I hook the RCA cables up into the green box that hooks up to my stock radio it makes this weird bluuuuuuuu noise and now the red protection lights on my amps on now HELPPP PLEASEE
Ok bro this happens with 3 things rule one can't run RCA cables on same side as supply wire ok that's one if u are useing converter ajust it properly to specs that's two and if that's not it it is a faulty ground connection
Jan 03, 2013 | Cars & Trucks
Theres a new batterie in my cadi but something seem to be draining the it over night, could it be a piece of **** radio installment?
yes it could be first thing unhook all the power wires to the system charge battery then let it sit over night and see if it starts ok if it does you nee to hook a cutout on your piece of the system that is draining the battery.let me know if this works or not .
Oct 26, 2010 | 1994 Cadillac DeVille
Son tried to hook up stereo in his 98 Deville..Now trunk release, fuel door release, high beams, power windows and a few other things don't work. Checked fuses are good..
That's because he likely cut the power wire to these when he was looking for power sources for his stereo.
GM almost always has at least one empty spot on the fuse panel that will provide a power source for aftermarket equipment such as stereos. He'll have to put an in-line fuse in it. It should be marked ACC. If not a test light will easily show him where he can draw power from the fuse box. Hope this helps.
Sep 08, 2010 | 1998 Cadillac DeVille
What wire do you use to hook up the power antenna wire to; i am changing from factory radio to a purchased radio but i have a power antenna wire but not a matching wire on the radio
you are not putting a factor radio it not have that same colors . look at the wire diagram to tell which color to hook to car side
Feb 25, 2010 | 1996 Cadillac DeVille
The stereo amplifier stays on in my 97 cadillac deville ALL the time, even after the 10 minute RAP....I have to pull the fuse when the car is off to preserve the battery. How to fix?
It will depend on what kind of amp you have, most amps have a remote, you run a wire from the remote outlet to a positive that comes on when the radio is on generaly it will be the auto antenna hot wire on the radio.
Nov 10, 2009 | 1997 Cadillac DeVille
2001 Cadillac deville will not start or jump. No power to radio, no power at all,
posible bad battery cable or bad ground,check all the wiring,i have had battery cables that battery acid has gotten inside the cable and eaten the copper wire and the cable looks good on the outside, check the simple things first to save unneeded costs.
Oct 09, 2009 | 2002 Cadillac Deville
94 Cadillac Concourse Dash color code chart
dawg i had the same problem and there is no way out of this! Believe me i tried it and fired the dash board twice!! I had everything workin got my bangs on and boom like 3 min later it frys. Best bet...go and get the wiring harness. 100 bucks :( but its the only one for ALL Cadillacs! I didnt want to spend the money for it but its was better than frying the dash again and better than using the piece of **** stock radio :)
Oct 19, 2008 | 1994 Cadillac DeVille
98 Deville casette/radio stereo won't play after swapping to CD/Casette/radio
Since the replacement is a different one from the one you are replacing, the car wiring harness is probably different from the one needed for the new radio. This is a really important difference if the new one is part of a Bose system and that is not the option installed in your car. The best way to check is for you to identify the option codes for each radio and go to alldatadiy.com and compare the wiring diagrams.
Apr 16, 2017 | 1998 Cadillac DeVille
Panasonic CQ-C1101U CD Player Logo
757 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
