How could I resolve a error code H5-01 on a sharp copier MX-6201N
  • 30 Answers
Can you take a video of the error?
Posted on Jan 14, 2013
2 Suggested Answers
  • 46 Answers
SOURCE: I have a Sharp MX-6201N copier that is showing
U2-10 is 'SRAM user authentication check sum error'
Press P * C * to enter the service 'simulation' mode then enter 16 on the key pad and press the start button.
You will be in U code clear.
Press 'execute' on the screen.
The machine should reboot.
It may start to work again.
If not you will need to replace either SRAM chip or the main board.
Posted on Oct 31, 2010
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Feb 03, 2016 | Sharp Mx-2600n MFP Copier
What's your question?my sharp prinrer mx 6201n not coming . no power light
check the electrical connection and power plug, mite have a bad power supply board
Aug 18, 2015 | Sharp Office Equipment & Supplies
H5-01 ERROR CODE
The following is from the Sharp website on error codes: SHARP MX M503N ERROR CODES Trouble Codes
H5 01 = 5 TIMES CONTINUOUS POD 1 NOT-REACH JAM
Mar 03, 2015 | Sharp Maintenance Kit 1 Mx-m700u Mx-m700n...
MX m354u. What does error Code U2-91 indicate?
This seems a common error across a wide range of Sharp printers/copiers. It means
PCU PWB EEPROM CHECK SUM ERROR
See the following two links (for example)
Thread U2 91 on MX 5000N and SHARP MX M363N ERROR CODES Trouble Codes
If haven't got manuals or other documents which may contain helpful information they can be downloaded here. This link also contains contact information for sharp so that you might get support
MX M354N MXM354N Digital Copier Printer Sharp
6.November.2015
Feb 27, 2015 | Sharp Office Equipment & Supplies
How do I fix error code F2-41 on Sharp mx-6201N?
Hi
This appears to be related to the toner sensor or harness connector. The details are given here:
Error Codes Sharp MX6201N Code F2 41
where you can also look at all the error codes for your machine or change the make & model number by using the drop down menus along the top of the page:
You can also obtain a full service manual in pdf format from this site.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 29, 2014 | Sharp Office Equipment & Supplies
What does error code dc on sharp 3100n mean?
image cartridge cyan need to be replaced
Jul 04, 2014 | SHARP MX-3100N
I have a Sharp MX-6201N copier that is showing error code U2-10. Does anyone know what that means and how to fix it ? Any advice greatly appreciated !
Oct 31, 2010 | Sharp Office Equipment & Supplies
Sharp MX-6201n get e7-06 error when scanning to thumb drive
Hi
Error E7-06 means Image data decode error. This appears due to Image expansion error. It has been caused due to MCU PWB abnormality or USB cable trouble
Try using a different USB cable. If this doesn't help then try the reset procedure---
Sharp ram clear -- Press function 9 * 8 # 7 then # or * until display reads memory clear, then press start. Note the other maintenance mode options displayed on the screen when pressing # or *.
Hope this helps...
Daniel
Oct 08, 2010 | Sharp Office Equipment & Supplies
48 people viewed this question
jasbo
jasbo
