I've not found any information helpful towards my problem. i removed the spacebar to clean a spill and i just need to reattach it
SOURCE: HP NC6120 NOTEBOOK
click the link below. if it doesn't work copy and paste the code at the bottom of this post to obtain the document you need. you will need acrobat/adobe reader which can be found at www.adobe.com
once you open the manual the info you need is on page 11. it describes the steps to clearing any cmos info and bios passwords
product manual
http://h20000.www2.hp.com/bizsupport/TechSupport/CoreRedirect.jsp?redirectReason=DocIndexPDF&prodSeriesId=447346&targetPage=http%3A%2F%2Fbizsupport.austin.hp.com%2Fbc%2Fdocs%2Fsupport%2FSupportManual%2Fc00502970%2Fc00502970.pdf
SOURCE: Acer laptop spacebar fell off
The space bar key is connected tothe keyboard a little bit differently then any other key.
There is a metal retainer connectedto the space bar key (on some keyboard models). Separate the retainer from thespace bar key with a flathead screwdriver.
Install the retainer back inplace as it shown on the picture. You have to engage the retainer with thesmall hooks on the keyboard.
Put the space bar key back inplace and gently press on it with fingers until it snaps back in place.
That’s it. The space bar key isinstalled back in place and should work as before. If you still cannot fix yourkeyboard, then you’ll have to find a new oneand replace it.
Pleas rate my solution on fixya if you are done.
SOURCE: took spacebar off to clean up a pop spill...metal bar NOT attatch
There might be a metal wire if it is missing, which snaps to the keyboard, you may need a new keyboard.
If you are unsure, you should probably thake it to your local computer repair shop.
Good Luck.
SOURCE: Spilled coffee on D600 notebook, power supply
Unfortunetly that sounds like it may have been enough to cause fatal damage. If it was plugged in or running then it most likley caused an electrical short . If it wasn't powered you may have just killed the keyboard.
I've tried to fix several laptops broight in that had coffee, beer, soda, and water spilled on them. Everyone turned out to be non repairable. The worst one was only 3 days old and that was coffee and considered user abuse which meant no warrenty.
You could replace the mainboard and the keyboard if needed and get it running again. That would cost more than this is worth. You should be able to put the hard drive into a usb case ($15 +) and copy off your files and such. It is fixable but not really worth doing.
SOURCE: Hello i've got an audio
you have to install first UAA (Microsoft Universal Sound driver)
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=3375953&prodNameId=3375995&swEnvOID=1093&swLang=8&mode=2&taskId=135&swItem=ob-47284-1
then install the sp28481.exe (Conexant CX20468-31 AC97 Audio driver) from the same link you already have.
It should work fine.
