Question about Lexmark X5470 All-In-One InkJet Printer
HAVING PROBLEMS FAXING, I GET A MESSAGE AFTER I SCAN SOMETHING TO FAX THAT READS "FAILED TO OPEN OR INITIALIZE THE FAXMAN DATASE"
  • Justin Wolery May 11, 2010
    are you using the printer as a stand alone fax or are you scanning to the PC and using fax software? if so what software are you using? can you be more descriptive about the individual steps you took up to the error message?
    If your printer has the ability to dial out and fax on its own i would use that method over scanning to the pc first as this is less likely to have a problem, and can also be helpful and diagnosing the issue your having (i.e. being software or hardware related)
  • Lexmark Master
  • 684 Answers
Clear NV RAM.....
Unplug the Power Supply from the Printer....
Press and Hold the #5 button on the Printer and plug in the Power Supply.......
Don Release the #5 button till the Printer turns on completely....
After releasing the #5 button........
Press the Menu button once Keep on Pressing the Right Navigation Key till u find an option saying Maintanence goto maintanenece and go to manufacturing and click on clear NV RAM.....
Now as soon as the Printer is Restarted.......
U will be able to send and recieve faxes.....
Thanku.............
Posted on Jan 22, 2009
Fax Failed
Is your Verizon phone system running through digital signal? or analog signal? Have you contacted Verizon Technical Support to verify if their phone system is suitable for faxing?
Jun 16, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
When recieving a fax the print speed is at a snail pace. It takes for ever for the printer to print a page of the recieving fax.
try this and let us know. do fax diagonastics.
Test the fax setup from the control panel Follow the steps below to perform a fax diagnostics test.
  1. Set up the all-in-one for faxing according to the setup instructions found in the product's User's Guide .
  2. Make sure you have inserted the print cartridges and loaded paper before starting the test.
  3. Press Setup , 6 , and then 6 . This displays the Tools menu and then select Run Fax Test . The HP all-in-one displays the status of the test on the color graphics display and prints a report.
  4. Review the report.
    • If the test passes and you are still having problems faxing, check the fax settings listed in the report to verify the settings are correct. A blank or incorrect fax setting can cause faxing problems.
    • If the test fails, review the report for more information on how to fix any problems found.
  5. After you pick up the fax report from the all-in-one, press OK . Then turn the printer off, and then on again. If necessary, resolve any problems found and rerun the test.
Accessing the Diagnostic Utility from HP Solution Center The fax Diagnostic Utility can also be accessed from the HP Solution Center software, by selecting the HP Fax enabled product in the drop down box, and then following these steps:
  1. Select Settings , Fax Settings & Setup , Fax Setup Wizard .
  2. Tab through the Fax Setup Wizard to get to the end of the process. This is a good opportunity to ensure that your fax machine is setup correctly.
  3. Click Click here to run the Fax Test . The HP all-in-one displays the status of the test on the color graphics display and prints a report.
Sep 14, 2009 | HP Officejet J5780 All-In-One InkJet...
Error message -no loop current
It can't find a DIAL TONE check the line with a regular phone.
Mar 06, 2009 | Philips Magic5 Voice DECT Duo - Fax /...
Fax problems with hp 5600
I have fax pluged into phone line and every time I try to send it states fax failed. How do I correct
Jan 28, 2009 | HP Officejet 5610 All-In-One InkJet...
HP officejet 6110 all in one scanning
LOOKS LIKE YOU HAVE A MECHANICAL PROBLEM , need to check the motor , guidance path where the bright light travels , needs to be serviced , hope this helps
May 05, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Faxman.comm win error
i have a x3450 printer i can't get faxman.comm off my computer. i can't use it please tell me how to remove.it is causing me a promblem.
Apr 15, 2008 | Lexmark X3350 All-In-One InkJet Printer
Prainter failed without warning,will not respond
Hi Tcov,
Please click on the web link given below and perform the steps as provided in the web page.
Please read the documentation provided in the web page carefully to fix the issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00045587&cc=us&lc=en&dlc=en&product=79499
Have a great day!
Feb 02, 2008 | HP PSC 2210 All-In-One InkJet Printer
Faxing
Check for the latest driver's update software on www.hp.com.
Nov 08, 2007 | Office Equipment & Supplies
Problems sending and receiving faxes
then there is a sensor problem, here is the manual check troubleshooting section
http://www.retrevo.com/s/brother+2820+fax++manual
Sep 07, 2007 | Brother IntelliFax-2820 Laser Fax
Officejet 7310 HP
Follow the steps below to perform a fax diagnostics test. 1. Set up the all-in-one for faxing according to the setup instructions found in the product's User's Guide. 2. Make sure you have inserted the print cartridges and loaded paper before starting the test. 3. Press Setup, 6, and then 6. This displays the Tools menu and then select Run Fax Test. The HP all-in-one displays the status of the test on the color graphics display and prints a report. 4. Review the report. * If the test passes and you are still having problems faxing, check the fax settings listed in the report to verify the settings are correct. A blank or incorrect fax setting can cause faxing problems. * If the test fails, review the report for more information on how to fix any problems found. 5. After you pick up the fax report from the all-in-one, press OK. Then turn the printer off, and then on again. If necessary, resolve any problems found and rerun the test. If the test passes and you are still having problems faxing, check the fax settings listed in the report to verify the settings are correct. A blank or incorrect fax setting can cause faxing problems.
Aug 07, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Lexmark X5470 All-In-One InkJet Printer Logo
85 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
