Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
How to replace floater door - Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
  • Bissell Master
  • 18,402 Answers
This video may help
Posted on Jan 05, 2013
Led light wont come on
When you remounted the freezer door you might have missed or damaged the switch (button) when you moved the unit. Check that and replace it if necessary. That should fix the problem.
Nov 14, 2013 | Electrolux Vacuums
Sharp r-530es microwave. when depressing door Pushbutton, the door will not open. (problem started itermittently but now will not open at all(unless I pull on the door to assist)
Hello there, the mechanism for opening microwaves is such that when the button is depressed it raises the hooks which hold the door back. In some microwaves the hooks also have another part which pushes the door out while some units have door hinges which have spring mechanisms which pushes out the door. Depending on what is obtainable on your unit the problem might differ. What you want to do is this, when the door is open press the button and see if the hooks which are supposed to hold the door in place move as expected but considering that the door opens when you pull the problem is more likely from the spring mechanism which is supposed to push the door out.
Try cleaning the hinges and the space in between the door and the control panel. Try this and let me know as any other process might require a replacement part.
Hope this solution has been helpful?
Thank you for visiting FixYa.
Sep 21, 2011 | Sharp Vacuums
How do you replace the belt on xl2200 upright oreck vacuum cleanrer
Ok with the front of the vacuum facing you look on the left had side of the power head then follow these steps.
1.Remove the door by removing
the hold down screw located on
side of power head.
2.Slide the door forward by
prying open with a screwdriver
or coin.
3.Remove the belt from the brush
roll pulley and the motor drive
shaft.
4.Loop the new belt over the
motor drive shaft. Place the
opposite end of the belt on the
brush roll pulley.
5.Rotate the brush roll three (3)
complete revolutions to ensure
that no part of the belt is
overhanging the end of the
motor drive shaft.
6.Replace the door by sliding it
into the groove at the bottom of
the housing. Replace the hold
down screw.
Jun 22, 2011 | Vacuums
I cannot find my owner sheet and need to change the belt in my upright oreck
THERE IS A SINGLE SCREW ON THE SIDE OF THE VAC KNOWN AS THE 'BELT DOOR'.
LAY VAC ON IT'S RIGHT SIDE, SO THE BELT DOOR IS STICKING STRAIGHT UP IN THE AIR. REMOVE DOOR AND BELT DOOR. CUT OLD BELT IF IT IS NOT BROKEN. TUCK NEW BELT UNDER BRUHROLL PULLEY FIRST THEN STRECH OVER MOTOR SHAFT.
DO NOT REPLACE BELT BY REMOVING BASEPLATE. 1) THE MOTOR IS NOT STABLE ENOUGH FOR THE TIGHT BELTS WITHOUT THE SUPPORT OF THE MOTOR 2) REPLACING BASEPLATE IMPOPERLY MAKES VACUUMING DIFFICULT. ">
Feb 18, 2011 | Oreck XL21 Bagged Upright Vacuum
How do you replace the 'after filter' in the electrolux guardian?
1. Press latch and open the door that covers the tools.
2. Squeeze clips at front of tool tray, lift and remove.
3. Remove filter.
4 Replace filter.
5. Replace tool tray and close door..
Instructions can be found in the Renaissance manual, which you can download from the following site. Go to "older models", find Renaissance and click on it, then click "download". Instructions are on page 9. The Renaissance is basically the same model as the Guardian.
http://www.aerusvacuums.com/support/manuals/
Nov 28, 2010 | Electrolux Guardian Bagged Canister Vacuum
Broken trap door on dirt bin, can I just replace the door or do I need the whole bin
I have the same problem, and found the "trap door" available at http://platinumvacuum.com/dyson-dc07-bin-base-assembly-904279-10.html Since the part number is shown there, you may be able to find it elsewhere more easily using that. I will keep looking elsewhere myself.
Jan 27, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
F6055-900 SteamVac Maxextract LS
Might just be a bad sensor, or it is coated over with dirt. If the tank lid has one of those round filters on it, make sure it isn't pushed all of the way up to the top, needs to have a 1/4 inch gap.
Jan 03, 2008 | Hoover F6055-900 SteamVac Maxextract LS...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
16 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
