Question about RCA P52960 52" Rear Projection Television
Replacement STK numbers for convergence amps
I need to replace the convergence amps for my P53960 projection TV. (Chasis number PTK195Y06B) I need a reference part number for the originals to get the righ STK units.
  • Pat Morrison Jan 19, 2009
    I gather this is the amplifier board, correct?
    Was there a retrofit kit put out for this system also?
    Scholar:
  • 87 Answers
This unit does not use the STK series convergence amps.The convergence power supply is what you need.I will provide that number for you after while.
Posted on Jan 19, 2009
  • Albert Vasquez
    Albert Vasquez Jan 19, 2009
    The part # is 242675 and you can get one through partsstore.com
  • Albert Vasquez
    There were 2 versions of conv.power supplies for the PKT195 chassis and that part # is the one that both versions use as a replacement.
WHAT IS IC NUMBER CONVRGENCE POWER TV RCA MODEL P52960 CHASSIS PTK 195Y06B
Posted on May 03, 2011
Convergance chip
devices: Any Projection TV with a Convergence Amp board
If I knew which Mitsubishi Projection TV you're looking at, I could help quite a bit more. In general, the "convergence chips" on a typical Convergence Amplifier board are actually two STK's mounted to large heat sinks. "STK" is electrical engineering slang for "Convergence Amplifier Integrated Circuit".
Here's a helpful Solution archived at FixYa:
http://www.fixya.com/support/t4337218-image_bowed_line
You'll see in the photo that the STK on the PC board actually have part numbers on them that begin with "STK".
Dec 09, 2011 | Mitsubishi Televison & Video
The picture is bowed and you can see double and the color is wrong
convergence ic stk----- you can repair this yourself if you can solder you can obtain ic.s from matt electronics or any electronic suppliers locate the convergence ic.s on chasis there will be 2 the number will start with stk- most likely stk-392-110 hope this helps
Oct 10, 2010 | Hitachi 43F300 43" Rear Projection...
Convergence Problem
Hi, the "trick" to this is you don`t need the samsung part number because the stk 392-040 is actually made by Sanyo, call this number and you`ll get exactly what you need 1-800-575-9833 there in Orlando, Fl. and only sell original Sanyo stk``s which is what came in your tv, make sure you check for burnt resistors around those stk`s before installing and powering up your set with the new stk`s, video-tek
Feb 08, 2009 | Samsung Televison & Video
Hitachi 51UWX20B Projection TV
Hitachi part number JT23051 is Obsolete the new part number for the Deflection Convergence PWB is JT23051R its available from Hitachi for around 350.00
Oct 08, 2008 | Televison & Video
Phillips 60pp920217f My TV has a problem with the red and blue convergence. I am unable to adjust
The problem you are having is with your convergence amps your set uses STK 392-120's if you replace them you will get your convergence adjustment back, Philips part number is 932212344682
Aug 13, 2008 | Televison & Video
Hourglass effect (convergence bad on left and right side)
Sounds like the classisc case of convergence amp ICs needing to be replaced. What is the model number of your set and I will post the STK numbers you need as well as a place to get replacements with free instalation instructions
May 11, 2008 | Televison & Video
Mitsubishi Projection TV HD1080
you need to replace your convergence ICs. Post your model number of your set, and I will post the correct stk numbers and a link where you can get new ones.
Apr 16, 2008 | Mitsubishi WD-62525 62" Rear Projection...
JVC AV48WP30 Rear Projection TV
There are a number of different STK type parts. You need to look on the old ones for the part numbers. May have to dissassemble the heatsink to see the number. STK is pretty good about its numbers and you should have no trouble finding them.
partstore,com
mcminone.com
nteinc.com
Dec 31, 2007 | JVC AV-48WP30 48" Rear Projection...
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
RCA P52960 52" Rear Projection Television Logo
214 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
