Question about Honeywell VR8200C6008
Gas boiler makes a lot of black sut - Honeywell VR8200C6008
  • Honeywell Master
  • 5,245 Answers
This is dangerous condition. Call service technician immediately, and they might put the unit out of commission until repairs are made.
Locate manufacturer's website, and call manufacturer to get name of local technician qualified to work on unit, and this will get the unit back into working service quicker.
Soot means burner is not burning all the fuel, and venting is slowed.
Possibility unburned gas is entering flueway, and could cause explosion.
Clean burner parts, check vent draft, check gas pressure.
Catch unit up on required yearly maintenance.
Posted on Jan 06, 2013
  • Anonymous Oct 23, 2013
    Yeah, it really sounds like you need boiler repair. In Syracuse UT, keeping our boilers in working condition is incredibly important come winter. You wouldn't believe how cold it gets here sometimes.
After moving my gas meter from inside the home to outside and having a semi concealed meter connected we cant get the combi boiler to work properly we can get hot water and have the gas fire on but
your boiler needs a minimum gas pressure of 16 mb to light successfully. if your gas pipe has been extended it has to be able to flow enough gas. it may need upgrading to 28mm for even as little as a metre from the gas meter. if your central heating works ok when the fire is off then this is your problem
Oct 12, 2014 | Water Heaters
Why is gas boiler burning black sut gas boiler when it lights up its makes a lot of black smoke and sut.
Burning rich, check for air restriction at burner, possible spider web in tubes etc.
Jan 25, 2014 | Honeywell Water Heaters
Jan 05, 2013 | Honeywell VR8200C6008
Wocester 37cdi condensing boiler when on low fire makes a reverberating noise that appears to come from fan/burner gas mixing assembaly whentemp arond 50 -55
Does the lit gas vary in amount of flame ? Are the gas jets clean?
Is the autovent screw opened at least 1/2 to 1 turn?
Possible resonance within the boiler casing - press and hold side & front panels to suppress the resonance frequency
Mar 14, 2010 | Water Heaters
Boiler Venting.
There cannot be controlled venting of the flue , the products of combustion must have free flow to escape , The heat exchanger is above the burner which heats the water if you thinks this is high then maybe you a pressure problem . Or contact the makes tech line and ask them what they think the consumption might be for you heater .You may find this on google
Mar 22, 2017 | RTO W4 A.O Smith Gas Hot Water Heater...
The hot water and central heating wont work together
what size of gas line is going into boiler and water heater? is it black iron ? natural gas or propane? have you checked gas pressure at water heater and furnace ? if they work fine individually then you have a problem with incoming gas pressure. Call gas company and ask them if they would come out and check gas pressure.
Feb 03, 2009 | Water Heaters
Boiler overheating
the problem there a relay stuck or thermostat bring on the pump & you can lower your high limit aquastat!! also the flow valves can bypass hot hot water risers time to put in a seperate water heater domestic coil are not energy efficient !!!! aquastat high limit set @ 180f deg low limit set @ 140f deg!!!
good luck!!! tim
Oct 08, 2008 | Water Heaters
Honeywell VR8200C6008 Logo
70 people viewed this question
Top Honeywell Water Heaters Experts
Paul Carew
Lawrence Oravetz
Are you a Honeywell Water Heater Expert? Answer questions, earn points and help others
