Question about Frigidaire Dryers
Trying to find operations manual for Frigidaire dryer model FGOB4000FSO
Dryer has no control identifications on the operating buttons so I don't know what buttons to push to change the current settings.
watugot
  • 290 Answers
SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Posted on Nov 25, 2007
sdmc73
  • 121 Answers
SOURCE: CAN'T FIND OPERATING MANUAL FOR FRIGIDAIRE ELECT. DRYER GLER341AS
frrigidaire.com service and suport and enter your model# and tou can download the manual
Posted on Nov 30, 2008
falter
  • 245 Answers
SOURCE: My dryer makes a loud squeaky noise when it is in operation
opne the backwall from ur dryer and replace belt.....go in touch with maytag and ask them for a new manuel to send to you
Posted on Mar 07, 2009
localwonder
  • 6784 Answers
SOURCE: CONTROL LIGHTS BLINK BUT WONT OPERATE
Anytime the lights blink simultaneously on this model, it is because of a major control fault that has occurred.
unplug the unit or shut the breaker off for 3 minutes. if the lights continue to blink after the 3 minute reset, replace the control/timer module asap.
Posted on Jun 03, 2009
Maytag317
  • 1136 Answers
SOURCE: CHANGING DRYER CORD
All you need to do is, attach the middle connection from the cord to the middle post on the dryer. The 2 outside connections on the cord will attach to the outside posts on the dryer. It does not matter on the outside connectors as far as which side they go.
Make sure they are fastened down tight. If the connections are loose at all, they will go bad.
Please let me know if this has helped you at all or if I can assist you further.
Thanks
Vic
Posted on Jul 23, 2009
I have a Frigidaire gallery dryer, I got as a gift but I don’t know how to use it. Can you help me?
Karla the link below will download the pdf file that has the operating instructions for your FDG436 model number read from the photo you provided.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/131526300.pdf
Mar 19, 2018 | Frigidaire Dryers
Model FEQ1442ES0. I press the start button and all I hear is a click, nothing happens. What's wrong?
I appreciate your inquiry, Cody!
I see that your Frigidaire dryer is not operating after you hit the start button and it clicks. It is possible that your control panel or wiring harness could be causing this issue with your dryer. You may need to perform a reset on your dryer and you can do that by disconnecting power from your dryer for at least ten minutes. If this does not correct your issue I would seek assistance from a professional technician for a proper diagnosis and repair. I hope this information is helpful to you. -Matt
Jun 15, 2015 | Frigidaire Dryers
How do I read the owners manual for model FGRB6600FSO
Instructions Operating Problems
  • 1 Check your dryer's power supply. Reset any flipped breakers, and replace any blown fuses.
  • 2 Open the door, shut it and press "Start" to be sure an open door isn't hindering the dryer's operation.
  • 3 Turn the dryer's control dial beyond "Off," into a cycle selection, before starting it.
  • 4 Check the gas supply valve. An opened valve will appear parallel to the line. If it is perpendicular, turn it to open it.
Jan 15, 2013 | Frigidaire Electric Dryer
Control locked light is on on my whirlpool duet front load dryer and it won't do anything
This advice is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Frigidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your specific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks
Nov 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Don't see any problem with my wahsing machine, but the "dr" keeps signalling on the washer keeping it from operating. What do I do, the door seems to shut fine?
DR is door error
This generation of dryer has alot of control board failures(the relay for the heat burns the terminals for the wires), you can inspect these relay connection visably by removing the front control panel
This is indicating an open door circuit. Since the circuit cannot complete, you cannot program any cycles and the "clean filter" light will remain on until you can do so. You will find a technical data sheet inside your dryer, either just under the top panel, or inside the lower panel, if so equipped.
Hope helps.
Jul 28, 2011 | Frigidaire ATF6000ES Front Load Washer
Hello, I need the hose to drain water outside that fits the fridgidair portable air conditioner #FAPO9EP1Z1. Is there another small tube or is there any other hoses or vents that I need? I don't see...
impreston - with out the following parts , you really don't have "just the air conditioner."
1- Flexible Exhaust Hose
2- Hose Adapters
1- Sliding Window Kit
1-Foam Window Seal
1-Remote Control
The drain hose is something you supply. A garden hose, no longer than 5 feet will do if you want it to be a continusos drain, rather than drain into the water collectiong bucket. But, without the first 4 items lister above, you won't be able to operate the unit.
Here is a link that may be of some help to you, since you don't have an Owner's Manual.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020252a0373en.pdf
You will beed to contact Frigidaire (1 -800-374-4432 ) for the parts you're missing.
Hope this helped you. Please let me know. Thanks.
Jul 12, 2011 | Frigidaire FAP094P1Z Portable Air...
I have a gas Frigidaire Gallery dryer. There is an error code "LOC". I can't get it to work now.
This indicates there is an error with the door lock mechanism. It will most likely need to be replaced. This will prevent the dryer from working and is a safety feature to prevent injury while the dryer is in operation. It is fairly quick and cheap to repair.
Oct 07, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
I have a Frigidaire Gallery Electric Dryer Model #GLER642AS3
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
Dec 20, 2008 | Frigidaire GLER642A Electric Dryer
Nov 30, 2008 | Frigidaire Dryers
Dryers Logo
74 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
