Question about Maytag Performa PAV2200
Washing machine My maytag performa isn't spinning properly and won't drain the water
  • Anonymous Jan 29, 2009
    my washer fills the water but it won't even spin just clicks and it won't drain either just makes the same clicking sound until i turn it of then it clicks a little more then stops.
  • mudobber4u Feb 20, 2009
    I have a Maytag Performa, don't know where to find model number. It fills, washes and drains- no spin. I tipped it over and the belt looks good, I tightened some, but still no spin. We have clothes in it so this is no easy task, where it's located, lol.I bought an ohm meter to check the parts, but don't know where to go to. Can you name the parts I should look at for replacement, since I'm trouble shooting? Thanks. I just got some bad news on my fridge- if I have to replace the compressor, it's $258.00 just for the compressor- and ir says you have to buy the tray kit. I went to Whirlpool. It's real loud, and I'm thinking if that's what's making the noise it's gone, right?
  • 640 Answers
Check your belt...first ,,if good check your pump..1 of theses parts are defective...onthejob
Posted on Jan 24, 2009
Lat2500aae We have a Maytag Performa, Model
it sounds like the shocks on the drum maybe failing. on this model the washing machine mother board is close to the outer drum. the out drum may have made contact with it. and not turning on the pump to let the water out.
Oct 06, 2013 | Washing Machines
Hi maytag performa pav3200 failing to do spin cycle - is draining all water out still - any ideas, thanks tim
you may have a stuck tub bearing.tilt machine at a 45 degree angle take off belt and turn transmission pulley both ways. One way will be easy for the wash cycle and other more resistant but should be able to turn i nner tub or else their is your problem. To change this bearing need special tools.
Jul 03, 2011 | Maytag Performa PAV3200
It won't drain, code nd. Hose isn't kinked.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 16, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
heatman101
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
Maytag Performa agitates, but wont spin corectly.
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 07, 2010 | Washing Machines
Maytag Performa Washer PAV1000AWW. Shakes when spinning out
My washer doesnt drain in the rinse cycle?? dont kno what to do
Feb 15, 2010 | Maytag Performa PAV2200
My matag performa makes isn't spinning or draining the water
im sorry to say the problem you have is in the transmition a new transmition thrust bearing and seal kit would be needed to repair this properly parts alone you are looking at 250 - 300 dollars
Jan 19, 2009 | Maytag Performa PAV2200
Maytag Performa washer
Hi jamac74
The leak could be comming from one of 2 places, either the pump or the main seal. the best way to find wherer the leak is comming from is to take the front panel off. you can do this by poping the top up there is 2 clips that hold the top down. use a putty knife to pop the top up then there is 2 screws holding the front on.
Sep 16, 2008 | Maytag Performa PAV2200
My Maytag Performa washing machine filled up with water, and now just makes a humming and clicking noise. It will not agitate, spin, or drain.
sounds like your drive belt is lose.
Open the machine and check it
here is the link for your PARTS
includes also drawing
Jun 19, 2008 | Maytag Washing Machines
Washing Machines Logo
228 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
