Question about Toshiba HDTB105XK3AA Canvio Basics Hard Drive HDTB105XK3AA
Toshiba hard drive no funciona es nuevo. HDTB105XK3AA
Is new. have solid blue light, but see nothing in monitor.
5 Suggested Answers
bunnydawg
  • 5158 Answers
SOURCE: Troubleshooting Toshiba Satellite P205-S6267
is the laptop getting extremely hot on the bottom.
Could be thermal shut down (keeps the cpu from meltdown temperatures)
Robert
Posted on Aug 30, 2008
pankaj_dic
  • 1250 Answers
SOURCE: Toshiba satillite A215 won't boot up. No sounds from drive, fan, nada, zip. worked fine yesterday.
connect to the external monitor through the vga port of the laptop, check the display, if the display is there then its the problem of your laptop screen
like the soluton or not rate it please
Posted on Oct 17, 2008
  • 27 Answers
SOURCE: I have a new SATA hard drive to put into a used
You problem is your memory. Try putting up the old memory and i'm sure that it will work again.
Possible Solution 1.
If you just add-up the new memory, try removing the old memory and just use the new memory because they might not have the same brand, speed, or something else.
Possible Solution 2.
If you are using only the new memory, you might want to try the old memory only and if it boots up again, you might have compatibility problem on your newly bought memory.
Hope it helps.
Posted on Jan 10, 2010
SOURCE: The AC power light (DC input) on the Toshiba
Ensure the wattage and ampage matches. If it does, then your system board might be gone.
Posted on Jan 18, 2010
Prende pero por un rato y luego la reseteo y ya no davideo
make sure that their is no cd in the drive and try booting in safe mode by hitting the function key F8 and choosing safe mode and if it works then shut it down and restart it again. good luck.
Nov 13, 2015 | Computers & Internet
External Hard Drive not recognized
Try another usb cable if that works. But if nothing, make sure if your hard drive can be found in device manager and see if it has a correct capacity. If both doesn't work at all, you have to remove the hard drive to it's case and insert into the pc directly but that might void your warranty. This additional resource link might help you fix your hdd http://adf.ly/dkhUg
Feb 18, 2014 | Toshiba Computers & Internet
Solo indica FRECUENCIA FUERA DE RANGO
Yo tengo el mismo problema. Desde que compre mi Laptop hasta ayer funcionaba perfectamente con cualquier proyector, pero hoy que quise proyectar solo me aparecio "Frecuencia fuera de rango!".
Ya probe en varios proyectores, varios monitores, varias configuraciones de resolucion baja (800x600) y con varios cables nuevos y siempre me esta marcando lo mismo. Lo unico que paso de ayer a hoy es que se actualizo Windows, pero he restaurado dos dias atras y aun asi sigue el mismo resultado. Por lo que he visto en la web, yo creo que el problema esta en la computadora! Lo ultimo que me queda por probar es restaurar a configuracion de fabrica, pero eso implica mucho trabajo ... y si eso no funciona creo que puede ser que la salida vga sea la daniada
Mi Lap es HP ProBook4540s
Oct 23, 2013 | Sony VPL-ES4 Projector
1995 audi a6 no spark through coils but cranks and has fuel prssure and timein is still in line
You need to run a fault code test on the electronic engine control system first and see what codes show up. This test requires a special scan tool.
Oct 30, 2012 | Audi Cars & Trucks
Mi monitor parpadea y no arranca ? que debo hacer tengo conocimientos de electronica pero no se que hacer
Primero verifica la luz frente a tu monitor si la misma esta parpadeando o de color anaranjada hay un problema con la tarjeta de video de tu computadora. Si esta verde esta recibiendo señal de tu tarjeta de video. La mejor forma de saber si tu tarjeta de video esta funcionando correctamente es utilizar otro monitor que sepas que esta funcionando correctamente y conectarlo a la computadora. Si funciona bien, tu monitor esta dañado. Mi recomendación es compra uno nuevo por que es mas economico que repararlo.
Mar 03, 2011 | LG Office Equipment & Supplies
Hola el problema es que son dos telefonos registrados en una base pero el 2 que seria el movil no funciona no da linea suena como si estuviera ocupado,ya lo intente con el manual y nada ha es nuevo gracias...
Hola, el procedimiento sujerido del fabricante en este caso es el siguiente:
  1. Retire y vuelva a colocar las baterias
    del terminal.
  2. Intentelo de nuevo desconectando la
    alimentacion de la base y volviendola a
    conectar y siga el procedimiento de
    registro de un telefono.
Registro de un auricular.
  1. Inserte la bateria para encender el
    auricular. En la pantalla LCD
    aparecera "PULS TECLA OK
    PARA REGISTAR".
  2. Pulse pantalla LCD aparecera "PULSE
    PAGE DURANTE 5 SEGS".
    Antes de que transcurran cinco
    minutos, pulse la tecla de
    localizacion (PAGE) que se encuentra en la
    estacion base para iniciar el proceso
    de registro.
  3. Si el registro se realiza con exito, el
    auricular volvera al modo en espera.
    Si el registro no se realiza
    correctamente, en la pantalla LCD
    aparecera "PULS TECLA OK PARA
    REGISTAR". Repita el proceso de
    nuevo.
Feb 28, 2011 | Philips CD1503B/17 Phone
A CABO DE COMPRAR UNA ACER ONE MINI. PRENDE LA COMPUTADORA PERO LA PANTALLA SE QUEDA EN NEGRO, HACE UN RUIDO COMO SI LEYERA EL DISCO DURO PRO NO APARECE NADA. QUE ES LO QUE PUEDO HACER
puede hacer la bateria que esta baja, tratar de cargarla primero sacale la batteria luego poner sela y cargar y prenderla de nuevo haver si funciona
Feb 19, 2011 | Acer Aspire One PC Notebook
Genius 9x12 pensketch mouse broken
Hmmm, does it require batteries by any chance ?
Apr 25, 2009 | Genius Pensketch 9x12 USB Deep Blue...
Our Panasonic phone model KX-TGA820B is not working
acabo comprar mis telefonos y los conectamos pero solo uno funciona los demas dice que no hay enlace que me acerque a la base e intente de nuevo pero no funciona solo es un audicuar que funciona
Jan 12, 2009 | Panasonic KX-TG1033S Cordless Phone
Problemas con la camara web
Hola soy nuevo en esto de los foros, tengo problemas con mi camara web 1,3m que viene integrada a mi Toshiba Satellite A215-S4807, tengo Windows Vista Home Premium, entonces mi camara web casi nunca logra funcionar con el msn e incluso el programa que trae ("C:\Program Files\Camera Assistant Software for Toshiba\traybar.exe.exe") no funciona correctamente ya que a veces funciona y otras no... ahora ultimo no ha querido funcionar mas con el msn.
Quedo de ustedes y esperando sepan ayudarme.
Gracias de antemano. Carlos
Jan 25, 2008 | Computers & Internet
Toshiba HDTB105XK3AA Canvio Basics Hard Drive HDTB105XK3AA Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
