Question about Copystar Cs-400ci
How can i fix my copystar cs400ci, having problems with improper placement of the toner waste box
  • Copystar Expert
  • 337 Answers
What do you mean exactly. is the drawer with the blue button broken. will it not stay closed? there were many many firmware upgrades and part changes on that machine to eventually make them run right. toner motors, 6 revisions of the dv units, transfer belt modifications, and much more. much of it was in way or another related to toner waste.
Posted on Jan 30, 2013
5 Suggested Answers
SOURCE: All the copies are coming out solid black
On my copier the exposure would light when I made copies but come to find out it wasn't bright enough. Look at the lamp and see if it doesn't have black burnt spots. If so then it is the lamp.
Good luck
Posted on Apr 12, 2009
mysticus_tam
  • 38 Answers
SOURCE: We have a 99 and
C7-99 is not a waste toner error code.
Posted on Dec 03, 2009
n25an
  • 622 Answers
SOURCE: i need location of a waste toner in a copystar cs
i don't think it has one...
Posted on Dec 26, 2009
babaprithi
  • 372 Answers
SOURCE: my copystar cs-1810 keeps printing dark
check the charging corona unit.it might be dirty of not aligned properly.clean it with alcohol
Posted on May 25, 2011
Replace the waste toner box
Please write me your copier brand name and model name.Some times when waste toner is full the tank than show massage replace the waste toner box.You should clean the waste toner than fix this massage.
Oct 20, 2013 | Copystar Ri-2530 Printer
WHAT DOES CODE C7990 MEAN ON A COPYSTAR CS-1820
Waste toner reservoir overflow
problem (when the total number of
copies is 100 thousand sheets or
more)
• After E31 is displayed, 1,000 sheets
are copied. Or waste toner exceeds
5 g.
Defective waste
toner sensor or
engine PWB.
Shake the process unit from side to side
and turn the power switch off and then on.
If the problem cannot be solved, replace
the process unit.
After replacing the process unit, turn the
power switch off and then on. If the problem
cannot be solved, replace the waste
toner sensor or the engine PWB.
Mar 30, 2011 | Copystar CS-2030 Copier
I have an error code C-7 980 on a Copystar 1500. What does that mean?
This is a drum related problem. The waste toner is full. Remove the drum unit, remove toner cartridge and unscrew 2 chrome screws on on the left side of the unit. empty the waste and screw back the screws. replace toner and put back in the machine
Oct 26, 2010 | Copystar CS-1500 Copier
My kyocera copystar CS-1815 shows in the message screen "Waste toner near full." How do I empty the waste toner?
Hi there just open it up and inside there will be a small plass bottle that hold the waste toner you can clean out and put back.
Mar 04, 2010 | Copystar CS-1815 Printer
Error E31
The waste toner box is full. Replace it with a new waste toner box.
Aug 14, 2009 | Kyocera Copystar CS-1620 Black and White...
COPYSTAR 1500
the waste tank is full, remove the drum carriage. on bith side remove screw( the one who is inside the hole) dump the waste toner
Jun 22, 2009 | Copystar CS-1500 Copier
ERROR CODE "C7980". I HAVE ALREADY EMPTIED THE TONER WASTE. WHAT DOES IT MEAN AND HOW DO I FIX IT?
Hello sir; The code you display which means waste toner bottle full, just dump it .
May 12, 2009 | Copystar CS-1820 Copier
SERVICE ERROR c7980
The errorcode comes up when the waste toner is full.
Unfortunately the waste toner collection is in the process unit.
You will have to replace the whole cartidge.
Dec 05, 2008 | Copystar CS-1820 Copier
Copystar CS-1815 waste toner
There are two screws on the drum unit. They are on the left hand side and one on the right hand side. Remove the screw from one side and take off plastic small side cover. Dump the waste toner. Do the same for the other side and then put it back together. Turn machine off then on and the error code should be gone......
Apr 17, 2008 | Copystar CS-1815 Printer
Copystar Cs-400ci Logo
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Tammie Duggan
Tammie Duggan
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
