Question about Mitsubishi Televison & Video
Mitsubishi LT 46133 vertical lines on screen
  • 197 Answers
SOURCE: line in left side of screen
bad panel call mits has 2 year extended warraty for panel, need to call for authorized service center
Posted on Jun 07, 2009
jhinsincity
  • 616 Answers
SOURCE: I have a LT-46244 and there are two vertical black
No format burn-in if thats what you mean, tv needs to serviced. good luck Julio milleniumtvsvc@gmail.com
Posted on Jul 23, 2009
  • 3 Answers
SOURCE: Mitsubishi 40" TV, LT-40134 Vertical lines on left side of screen
I've got the same TV with the same problem. Sometimes by moving it on the stand the lines will go away but it only sometimes temporarily fixes the problem. For a while it seemed like it needed to heat up to go away but that is not the case. It seems like there is a bad connection somewhere but i cant seem to find it. One day, one thing will fix it, then the next day it wont do the trick. It gets very irritating.
Posted on Oct 26, 2009
budmrtn
  • 11361 Answers
SOURCE: i have a vertical line across my screen from top
Vertical lines more likely to be caused by bad T-CON board, you need to check the connections between the T-CON board and the main logic board, it can possibly be the main logic board also.
Please see my basic troubleshooting guide:
http://s807.photobucket.com/home/budm/allalbums
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: try www.shopjimmy.com or Ebay
Posted on Jun 25, 2010
TODDAS
  • 431 Answers
SOURCE: mitsubishi 52" gray vertical lines appeared then
no 200v for video line open low value resistor for the 200v
Posted on Nov 05, 2011
Mitsubishi LT-46131 powers off on its own
It could either be a faulty power outlet that you are plugged into or the power supply is overheating and triggering the circuit breaker ( reset button )
Dec 02, 2013 | Mitsubishi LT-46133 46 in. HDTV-Ready LCD...
LT-46133 FLICKERING BLUE LIGHT
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 18, 2012 | Mitsubishi LT-46133 46 in. HDTV-Ready LCD...
White Band On Screen - Remove It!
if a white band is seen---go to a blank or unused video input and examine the screen---both sides---if it is seen on both (even if more so on one side) you may have burned the screen by using the 4x3 format.
If this it is permanent damage.
Mar 31, 2012 | Mitsubishi LT-46133 46 in. HDTV-Ready LCD...
Mitsubishi LCD #LT40148--left side of screen has vertical lines.
I would guess a sustain or similar board---one for each side of the set and typical shop repair will exceed 200 parts and labor
Mar 17, 2012 | Mitsubishi LT-40148 40 in. LCD TV
I have a vertical line across my screen from top to bottom about 2mm thick about 2 inches from the right side of my mitsubishi lt-40133. how do i fix this?
Jun 25, 2010 | Mitsubishi LT-40133 40 in. LCD HDTV
Oct 09, 2009 | Mitsubishi LT-40133 40 in. LCD HDTV
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
Jul 23, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Line in left side of screen
Jun 04, 2009 | Televison & Video
Televison & Video Logo
56 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
