Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Frigidaire stacked washer will not wash
Does not turn in wash cycle makes grinding noise after spin cycle
    New Friend:
A knob part for the washer
Posted on Feb 06, 2013
  • 21 Answers
SOURCE: My washer makes a loud noise in the spin cycle.
In my experience with 417 Frigidaires is that when there is a noise in the spin cycle as you describe the drum bearing is failing. This is a very expensive repair that that when I looked up labor and parts could exceed 600 smakeroos.
Posted on Feb 14, 2010
docjohn174
  • 943 Answers
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
  • 30 Answers
SOURCE: frigidaire front washer has power but won't fill up, drain or go through correct cycles
You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
Posted on Oct 15, 2008
  • 220 Answers
SOURCE: Frigidaire Washing Machine Model # GLTF1670AS0 Makes very loud
If you want to take the time, I just replaced my drum bearings and seal for $62.00. No really any special tools needed. My model showed the bearings were not sold seperately and you had to buy the complete tub half, but when you take it apart, you can knock out the bearings and buy them online or at a bearing house. I have a seal part number also.
If I remember right the bearing part numbers are 6306-2RS and 6307-2RS (1 each) and the seal is a 40mmX80mmX10mm thick. Make sure you get the -2RS bearings because they are sealed. The ones that came out of mine are shielded bearings ( -Z ) and they will not resist moisture if the seal shaft seal fails.
Most AutoZones have seal and bearing drivers you can "borrow". They really help during installation so you don't deform the seal or damage the new bearings.
Any good bearing house should be able to macth on up or if you post back I can give you the exact number. I think most brands of front washer use the same bearings, but you may want to take yours apart before you buy.
Worst case the junk yard doesn't care if it comes in pieces or as one piece. Give it a try.
Not sure you will want to get this involved, but its not really too bad of a job.
Posted on Dec 31, 2008
  • 5 Answers
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Posted on Aug 02, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Grinding noise before spin cycle
Good Morning John,
I see that you are hearing a grinding noise before the spin cycle in your Frigidaire washer, model# GLET1031CS0. A certain amount of "grinding" or gear sounds are normal in a heavy-duty washer. If you notice that the grinding sound appears to be getting louder, I suggest contacting either the manufacturer or your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Mar 16, 2014 | Frigidaire Washing Machines
Washer won't spin after rinse cycle
Hello Dorothy - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Sep 29, 2012 | Frigidaire FEX831CS Top Load Stacked...
My Frigidaire front load stacked washer/dryer makes a horrible noise and won't spin. It works perfectly except for the spin cycle
you need to remove the agitator take the cap off and remove the bolt from inside the agitator and then remove it look at the metal trunion in the bottom of the tub and see if there is a broken bolt holding the trunion to the shaft.there is a chance the transmission need to be replace if there is no broken bolt
Nov 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire was tub makes loud thump noise during spin cycle....
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
Jul 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Washer leaks during spin cycle
If the machine is leaking then the bolt on the drum need to be tightened. you can acces them by removing the top or rear cover of the machine. If the machine is wobbling it need to be leveled or a shock absorber or spring connected to the drum has come loose or needs to be replaced
May 31, 2009 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire GLTR16704 Front Load Washer 417.39012891
Time for a new one.
Sound like you have done the main shaft bearing.
Nov 18, 2017 | Frigidaire GLTR1670A Front Load Washer
Frigidaire top load washer machine
is it overfilling ? you may have a bad pressure switch.. let me know?
Aug 23, 2007 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
