Question about Furniture
I need instructions for alta 3-pc dining set - Furniture
How do I reset the time on my fitbit alta
Theoretically the Fitbit should keep the time updated though syncing, but there are some things that throw it off. I would try these steps in this order. Check after each step to see if you have the correct time before doing the next step.
1. Re-sync your Alta to your phone/computer
2. Check your settings on your dashboard to make sure you have the correct time zone selected.
3a. If you sync to a phone make sure you do not need to update the app then try disconnecting and reconnecting the Fitbit (in your Bluetooth settings).
3b. If you are syncing to a computer, then try re-syncing your Fitbit. you might need uninstall/reinstall your software and make sure you are running the most recent version.
4. Try removing the Alta in the Fitbit app (should be under device settings) and then reconnecting it.
Hopefully one of those steps will get you on the right time, but if not, try resetting your Alta by doing the following:
  1. Plug in your Alta in a USB (computer, or adapter) as you normally would to charge it. It should begin charging.
  2. Press the button on your charging cable three times within eight seconds, briefly pausing between presses. (The button is on the end of the charging cable).
  3. Eight seconds after the first button press, you'll see the Fitbit logo on the screen. This means Alta is restarting.
  4. After you see the logo you can unplug your tracker from the charging cable.
Oct 20, 2017 | Exercise & Fitness
How do I reset the time on my Alta fitbit?
Theoretically the Fitbit should keep the time updated though syncing. I would try these steps in this order.
1. Re-sync your Fitbit to your phone/computer
4. Try removing the device in the Fitbit app (should be under device settings) and then reconnecting it.
Hopefully one of those things will get you on the correct time :)
My Fitbit Alta is showing incorrect time. How can that be changed?
Oct 12, 2017 | Exercise & Fitness
I have a Mainstay Albany Lane 6-piece folding dining set gray
Walmart sells this go to garden center or customer service an order the items you need here is the Model# MS16-301-001-13
Oct 02, 2017 | Baby Gear
Assemby instructions for dining room set
Kindly provide the details like IKEA model name/part code for giving the right guidance
Jun 10, 2016 | Furniture
Where can I find an assembly manual?
Amazon.com - Windermere Counter Table - Coaster 100438 ...
www.amazon.com > ... > Furniture > Tables
Amazon.com, Inc.Include assembly service ' Price $33.38 ' ZIP Code ... Coaster Hyde Counter HeightSquare Dining Table with Storage Base in Cappuccino(Table only).
Coaster Hyde Counter Height Square Dining Table with ...
Amazon.com, Inc.Amazon.com: Coaster Hyde Counter Height Square Dining Table with Storage Base ... Learn More; ASIN: B00399COLM; Item model number: 100438; Average ... Also, theassembly instructions manual did not come, however, VisonDecor did ...
Nov 01, 2015 | Coaster 100438 Counter Height Dining Table...
Need assembly incstructions for Target Dining Storage cabinet
I suggest that you contact the Target store that you got it from and ask them to send you the assembly instructions. If they can't provide you with the assembly instructions, ask them for the phone number of the Walker company.
Sep 23, 2012 | Target Home Buffet: Walker Dining Storage...
Addding second computer
1)install a good internal wireless pci card(best is linksys in my opinion)
2)you could also use a usb wireless adapter.
3)hardwire the pc to the back of the transmitter.
Dec 23, 2008 | Linksys Wireless-G Broadband Router
Furniture Logo
353 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
