Question about Panasonic Televison & Video
Hi: I am trying to get our Panasonic Viera TX-P42c3b tv to the Bush 3.1 Home theater system we were given for Xmas. We can get the DVD player to work with the TV and get theater sound, but not regular TV. I bought a digital optical cord and a RCA to digital optical converter, but we still can't seem to get it to work. If you can pull up the specs on the back of the Bush 3.1 system and walk me through how to connect it to the set and what settings I need to change on the TV to hear theater sound when we are watching just television that would be great. Thanks.
  • 205 Answers
SOURCE: connecting Panasonic DVD to TV
What kind of cables are you using to hook up the DVD to the TV? Are they they composite, component, or S-Video? What are the connectors you're plugging both ends of the cables into labeled? Are you plugging the audio cables into the TV or directly into the sound system?
Posted on Jan 12, 2008
  • 3 Answers
SOURCE: home theater system connections
I have the same tv but my dvd surround is a toshiba, that shouldn't matter though. When I watch a dvd I go to component 2 which is where I have my dvd connected on the input of the tv when I watch tv and want the surround on I go to component 1 which is the tv input then on my dvd player I go to auxillary and I can watch tv in surround. I don't know the LG home theatre system but you should be able to select your inputs like between dvd, tuner, aux. Flip between them and you should get sound. hope this helps.
Posted on Jan 19, 2008
  • 187 Answers
SOURCE: panasonic home theater
switch the HDMI cable to another HDMI port (if available).
or use and AVI/COMPONENT to make sure the device (HOME THEATHER) is working fine.
Try also another HDMI cable or hook another device into it to see how it works.
If you determine the HDMI port in not working properly, then your Mainboard is damaged and need to be replaced, try EBAY for a general picture of prices but you will need your product code wich is located in the back of the TV next to serial number.
Posted on May 27, 2009
  • 7 Answers
SOURCE: I just bought a Dynex DX-LCD19-09 19 inch TV. I
The only audio out jack on your TV is for the headphone on the left side of the TV. You need to purchase a 3.5 mm to RCA audio cable, connect the 3.5mm jack to the left side of your TV and the 2 RCA audio cable ends to the audio in of your Home Theater and then select AUX 1 or AUX 2 on the home theater depending on which jacks you plugged into.
Posted on Dec 22, 2009
  • 909 Answers
SOURCE: We just bought a 60
If your surround system has either white/red phono connectors or scart marked as "aux in" or "tv in" or similar, and the TV has a headphone out socket, then you could use these. The cable required will be available on e-bay or a good electronic stockist.
Posted on Aug 19, 2010
How to connect my hdtv to surround for audio
It looks like from my searching you have an optical link on your tv and your reciver. You should just have to choose that as your output on the tv and your input on the reciver. It should be labled something like spdif. In my opinion it is the best cable ever until hdmi came out now its still really good.
Jan 05, 2017 | Panasonic Audio Players & Recorders
Cannot get the tv audio working. Radio iPod all work fine Panasonic surround sound sa-pt750
Hi. Make sure you get audio from tv from the right place. Ie audio out not audio in.
Nov 05, 2016 | Panasonic Sa-pt750 Multi 5 Dvd Player...
Connecting Panasonic SC-PT550 to TX-L42E5B
I have a pansonic tv that i brougt last winter ,All you have to do to get audio from it is use a optical cable,
Nov 26, 2012 | Audio Players & Recorders
I have a panasonic viera flat panel plasma tv and a samsung 5.1 ch blue ray home theater system and the speakers work fine on the home theater system while playing a dvd, but does not work when watching...
1. The easiest solution would be to connect a stereo RCA (red and white) cable to the audio output on the back of your TV.
2. Then connect the other end to the input on your home theater system.
3. Change the home theater system to the correct input.
Feb 12, 2011 | Samsung HTC550 Theater System
My surround sound will not work through the TV, only the DVD
If your tv and surround has an optical input/output.Then you can connect with an optical lead.This will then play the sound from whatever you are watching.You normaly select dig1 or input1 on the surround system.
Nov 12, 2009 | Panasonic Televison & Video
Connection problems with Panasonic Viera Cast
I have had the same problem with my Panny DMR-BS850 which was resolved by changing the ethernet cable I was using which had only 4 contacts on each plug end for one which has 8 contacts. I tried all variations & combinations of IP & DNS before buying the new cable from my local pc store (£10 for 10m cable) and was relieved when setting the system to auto connect it worked within 3 mins. I think the slight delay was the router setting up a new address for the new hardware it detected.
My new cable states on it "Verified For Gigabit Ethernet" and is Cat 5e rated and I was assured that it will carry data for runs up to 95m long, which is contrary to the Panasonic support agent who told me to shorten my initial 5m cable to prevent signal degradation.
Give it a try.. it might just work.
Jul 13, 2009 | Panasonic Home Theater System System
Unlock regional video restriction
If you wish to get some details; visit the site linked here. Pull up older posts. Unlock procedure and to override the password lock and to set the device region free procedure of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
May 01, 2017 | Panasonic Viera TX-32LX77 LCD TV
Unable to get home theater sound on cable tv mode
I had this problem on my own tv and it nearly drove me mad, in tv menu under sound submenu their is a setting called spdif mode, there are choices in this mode that can be made, My current tv has Auto, off and pcm. some tv's have more choices. Try playing with these settings and its possible you can get it to work with cable, your cable signal probably uses a different sound format to the blueray/dvd player. note if this works the sound might not work when you go back to blueray/dvd player so note the setting before you change it in case you need to go back to it when you change over viewing choices. good luck.
Aug 17, 2017 | Panasonic Home Theater System System
Sc-pt660 + 46pz85u = NO SOUND!
Don't worry about sending the TV audio to the Panasonic. Just send a digital audio signal from the cable box to the Panasonic.
DVD - Panasonic connected via HDMI
TV - Panasonic connected via HDI
cable connected to cable box and TV. But you will not really be using the cable connection to the TV (TV Tuner) since you will want HD feed from cable box through HDMI input on TV.
You aren't concerned about feeding the TV speakers because your audio will always come from the home theatre.
Note that some components don't feed audio through HDMI, in which case you will need to use optical digital audio.
Sep 08, 2008 | Panasonic Home Theater System System
Televison & Video Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
