Question about Kobo E-reader Touch 2gb, Wi-fi, 6in - Silver
Kobo touch e-reader freezes up
Unit freezes up and I cannot turn it on. It does have a full battery charge.
3 Suggested Answers
arky241640
  • 778 Answers
SOURCE: How to install bookmark in e-reader?
Hello, Here is website for the download of the users guide for this product: http://download.kobobooks.com/magento/userguides/downloads/KoboDesktop/kobodesktop_userguide_en.pdf
Posted on May 30, 2014
  • 173 Answers
SOURCE: can you get a replacement battery for a kobo touch
Will one of those extra battery packs work to power the kobo? I just bought a 'pocket juice' at walmart to use with my cell phone.
Others are saying it is not worth putting in the real battery.
http://www.mobileread.com/forums/showthread.php?t=102752
Posted on Dec 22, 2014
My kobo is frozen on starting sync won't turn on or off
Note: If your Kobo device has been physically damaged, it is no longer covered by Kobo's limited warranty. On a Kobo eReader, a physically damaged screen will look like it's been shattered, or you may see vertical or horizontal lines on the screen with a frozen image. If you haven't dropped or damaged your Kobo eReader, but are experiencing issues, try the steps below in the order suggested.
  • Turn your eReader off and then on again.
  • If your screen is frozen, slide the power button to the right and hold it for 10 seconds. Your eReader should turn off.
  • Turn your eReader off and charge it for at least four hours. Note: Your computer should be turned on while you are charging your Kobo eReader.
  • If your eReader isn't charging, try using a different Micro USB cable or a different USB port on your computer. Note: If your eReader's battery is completely drained it can take up to 15 minutes before it reacts to being plugged into power.
  • If you're having trouble while reading a book on your Kobo Aura H2O, Kobo Aura, Kobo Aura HD, Kobo Glo, or Kobo Mini: tap the centre of the screen to bring up the Reading Menu, tap the > Home icon to return to your Home screen, then open your book again.
  • If you're having trouble while reading a book on your Kobo Touch: press the Home button and open your book again.
  • Try a basic reset.
  • If you're still having issues, consider a factory reset.
  • If you're unable to reset your device, please contact Kobo Customer Care
Mar 14, 2015 | Kobo 6" eReader Touch Edition
Kobo won't turn on, screen blank
This can happen if the battery is very, very flat. Try charging it overnight.
If charging it doesn't help, try using a paper clip in the reset hole to force a factory reset (you may lose any user-installed books).
Mar 01, 2015 | Kobo Glo E-Reader
I have to keep me kobo plugged in while I read. Can I fix this?
Unfortunately, Kobos weren't designed to replace the batteries. Short of buying a new eReader, reading with it plugged in is the only way around bad batteries.
Oct 16, 2014 | Kobo 6" eReader Touch Edition
My kobo wont turn charge and turn on
Broken psu connector or moethboard junk it its not cost effective to repair.
Aug 20, 2014 | Kobo Arc
Kobo ereader problems
Unfortunately, the batteries on Kobo were not designed to be replaced. If the batteries will no longer accept a charge, it is time for a new e-reader.
Aug 14, 2014 | Kobo 6" eReader Touch Edition
Kobo n613 not charging, no battery level indication on screen. Changed charger but still not charging. Also, do not know how to remove back cover to access the battery.
I do not have the n613 but please check your USB ports as these some time give a problem when you try to charge your battery through the computer - also check your connects from the e-reader to the computer as this could also be a problem..... if the above still does not work I suggest you plug the e-reader in and try and re update it...
Hope this Helps
Jul 27, 2014 | Kobo eBooks by Kobo
My touch screen kobo reader has stopped working
Make sure the Kobo is fully charged and switched off. Hold down the 'HOME' key while turning the Kobo on. When you see the power light release the 'HOME' key. The lights will flash. Follow the onscreen prompts.
Jan 06, 2012 | Kobo eBooks by Kobo
Is there a battery you can replace on the literati ereader only had sinceDec..been charged but will not turn on..hit reset did nothing?please help spent alot of money on Kobo books.
MY e-reader would not turn on either. I charged it overnight and tried the reset. I called the company and he told me that it sounds like the battery and it cannot be replaced due to the fact it is sealed. My loss! I can recover the books I bought from Kobo though.
Feb 20, 2011 | Sharper Image Literati Reader 16375680042...
Kobo E-reader Touch 2gb, Wi-fi, 6in - Silver Logo
Top Kobo Computers & Internet Experts
downhille
 Mikey
Mikey
Mark Schmit
Mark Schmit
Are you a Kobo Computer and Internet Expert? Answer questions, earn points and help others
