Ati ixp 400 mother board won't power up
Won't power up
5 Suggested Answers
  • 8 Answers
SOURCE: intel ati mother board
Provide me with some model numbers for your board. they will be printed on the board. I will then provide you with a link to the drivers and directions.
T0X1K66O
Owner, Founder, Head Technician
Leading Edge Computers LLC
87supra2jz@gmail.com
Posted on Apr 29, 2008
rcxrbt
  • 84 Answers
SOURCE: where to connect power switch of m7vig 400 mother
See the manual:
ftp://ftp.biostar-usa.com/manuals/M7VIG%20400/M7VIG400manual.pdf
Page nr. 9 you cane see JPANEL1 pin assignement.
Posted on Oct 18, 2009
  • 25 Answers
SOURCE: I installed new mother board
Hi there! Welcome to FixYa!
For you to further isolate the problem, you may need to follow the following steps.
First, check your power switch header if it matched the cables on the motherboard. check also the power cable for both ATX power (20 or 24 pin) and CPU power if they are firmly attached.
Second, run your system on a minimal hardware (power, processor and memory only) you need to remove Video Cards or other add-in cards if you have any and just run the system using onboard video (VGA)
If all else fail, then check individual hardware. (no need to check this if you are sure that they are working, but for the sake of isolation then you must.)
(1) Isolate the motherboard Check if it will work using other power supply (2) Isolate the power supply.
Check if it will work using other computer's motherboard (3) Isolate memory
If you are using 2 or more sticks or RAM, then try them one at a time. If all else fail then you may need to contact the vendor for possible RMA.
Posted on Sep 03, 2011
twistedki245
  • 35 Answers
SOURCE: Ms 1745 mother board won't power up
This isn't much of a solution, but I can tell you one thing. If the mother board smells like ozone, it's fried. Sometimes you can see where by comparing the clarity of the circuit routes. Sorry if this isn't much help,but if the board is no good then searching for a fix is pointless. GOOD LUCK. Hope it's something less severe.
Posted on Jul 02, 2012
Power driver seat won't move forward.
The switch actuator in the seat bolster may be broken.
Dec 10, 2017 | 1995 Ford Explorer
My asb light comes on when starting and stays on. Lights won't come on , power locks won't work, power windows won't work, radio won't work. All fuses are good and car runs fine.
Those are all really common symptoms of the alternator going bad on those cars. I would have it checked to make sure it's charging properly.
Dec 15, 2012 | 1996 Oldsmobile Cutlass Ciera
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
Sep 28, 2012 | Washing Machines
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Shut off won't turn back on
how long have you waited since it shut off? it may be overheating. if you've waited for a while and it still won't power up, you may need to test the power supply. if you don't have a power supply tester and most people don't you can remove it from the case and take it to any pc shop. they may charge you a couple bucks but most shops won't do that. if it's bad it will need replaced obviously, if it's not let us know :)
May 06, 2012 | Dell Vostro 320 Desktop Computer
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
My woofer is 18' 600w rms power. so what is the
Basically you cannot break you woofer with too powerful amp, but you can break it using too weak amp. This is because if you don't have enough watts going to you woofer the cones movement isn't controlled properly. I'm usually using +20% to the woofers RMS and peak power. This will also make the amp last longer because you won't use it at it's peak performance all the time. If possible use manufacturer whose prising policy matches your woofers manufacturers, that way you won't end up with "2000w peak power" cheap amp with real output of 30w. and in the other end cheap woofer won't handle expensive amp with real 600w rms so well, you need to find a midlle way here. Hard to say without knowing the make and model of the woofer.
This is a taste question for some people, and I haven't build a system to match so powerful woofer ever in my life. But I'm pretty sure you won't go wrong with this one.
May 20, 2011 | Audio Players & Recorders
Open Questions:
Can I hold DHHS accountable for the burden they put upon me? If not, is there someone that can be held accountable? What can I logically and honestly do to remedy this prob. I explained my prob below! I was getting QMB part of Mainecare and my spouse at the time we were dating but living together was getting the QI part of Mainecare. We are both disabled and only get SSDI. However being honest and do our best to always do the right thing we go to DHHS office on Griffin RD in Bangor, ME within a month of us getting married where the worker we saw tells us we don't qualify for anything but the min of FS and both Q1 part of Mainecare and serious voice tells us to divorce. I have made a few trips within last months to same DHHS. One sends us to Eastern Area of Aging to see if there were secondaries we can get. This past Monday hubby and I went to our appt with Eastern Area of Aging & was told they strongly believe I could get spousal exclusion also warning it could mean my hubby loses help but because it was a volunteer a newer one at that that she couldn't tell me definitely cause she didn't know the formula as she still learning; tells us to go back to DHHS to ask about spousal exclusion. So I go back to DHHS this past Thurs and got a worker with more smarts, heart with approx 10 yrs working for DHHS tells me I qualify for spousal exclusion and took the time to answer all my questions. I told her I had QMB till hubby and I married June 2016 & shared with her what the DHHS worker told us when hubby and I went in to show marriage certificate to update the change. She looked at me with shocked eyes and dropped jaw in bewilderment. Then says I would of never lost it as I would of qualified for spousal exclusion from the day we married. And had it been her that we got when we were being honest wouldn't have only told me about spousal exclusion but would of applied me as she could see I have major medical problems that is too much a financial burden for my hubby and I. She also told me I was to submit all unpaid bills even if monthly making payments were being made. I thought I was only to submit bills I paid in full or on a payment plan. So started Thurs night on a Medical Bills Tracker to go through all the medical bills and sort things out. I haven't even put a dent in the pile and see I'm responsible for just over 6K I'm predicting once done I could be closer, if not over, 10K. In collections is currently 1K but once done with pile amount in collections could be closer to 2K or more. So the mess has impacted my credit and if things were done by professionals I wouldn't be losing my hair stressing over my medical bills and how it declines my credit. I know I'm in a small group that actually pay their medical bills any and all bills to be honest! I am disabled and get SSDI. Worked 1992-2013 a lot of times working 2 jobs! Dr in 2013 practically dragged me out of work as was just diagnosed with Hep C, CKD Stage 3 & liver disease! I also have depression disorder, panic attacks, anxiety disorder! So even this incompetent DHHS worker putting extra financial burden on me unnecessarily affects those things. I am trying to do the right thing but get kicked down by the very people that are paid to help me. What are my rights and can I fix this at a faster pace then not even fixed it by the day I die?
Jun 23, 2018 | Major Computers & Internet
Computers & Internet Logo
145 people viewed this question
David Payne
David Payne
