Question about Canon EOS-10S 35mm SLR Camera
Iso led keeps flashing on my eos 10s
Hi, I put a 200 iso film in the camera, But the iso icon on the screen keeps flashing, I set the iso to 200, but it still is flashing . Is this normal Martin
    Novelist:
  • Canon Expert
  • 357 Answers
Clean the iso detect pins in the film chamber, and check to make sure they are not bent
Posted on May 14, 2014
SOURCE: Can't change iso setting using iso button
If your camera is on auto, you must turn the knob on the top to manual.
Posted on Nov 05, 2007
SOURCE: Rebel EOS Rebel SLR film camera-pictures develop like film was exposed
The shutter is most likely damaged.
Posted on Dec 07, 2007
cammedic
  • 667 Answers
SOURCE: shutter speed and apiture priority
The green rectangle is full automatic. You can use the P mode for the same function. In the P mode, you can change settings, in the green rectangle, you cannot.
Posted on Feb 14, 2008
SOURCE: low battery warning
What type of batteries did you buy?
For digital cameras, you want to use batteries with high milliamp hour (mah) rating: "2500 mah" if they are rechargeable.
If you bought regular batteries, you want to use good quality. Look for the "e2" or "better for digital equipment" type.
Does the camera have a DC power plug option? Try taking pictures with it plugged in if it does. If it still malfunctions with power right from the wall, then you bought a bad camera.
Posted on May 13, 2008
  • 44 Answers
SOURCE: canon EOS Rebel K2 constant low battery indicator light
Canon also uses the low battery Icon as a generic error code. Try taking the lens off the camera. If this fixes the problem the lens needs a repair (most likely the aperture unit). If not then the camera needs the repair (either the shutter or dc-dc converter circuit).
Posted on Dec 12, 2008
Canon EOS Rebel T2 - film loaded, but then wouldn't take a picture, the frame count was flashing on screen. What is the problem?
Hi. Open the camera back and pull the film further over towards the pick up spool, close the back and try again to take a photo, i had the same problem with an eos 650 and it always worked.Good luck.
Apr 15, 2014 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Pics too dark
decrease shutter speed, increase aperture size (lower F-stop), and/or increase ISO.
Mar 28, 2014 | Canon EOS Rebel XSi Digital Camera
I can record, i can take pictures inside or when it is night but i can not take pictures with the light of the day or when there is a strong light. I can see from the lcd monitor the icon bute when i take...
You have the ISO Setting set too high. This is the setting that in a film camera was called 'film speed'. The higher the ISO, the better it will take pictures in low light. Yours may be set to 3,800 ISO, when it needs to be on 200 or 400. The light during the day is bleaching out the sensor and that is what you are seeing on the screen. Also the higher the ISO, the more grain you will see in images.
Understanding ISO - A Beginner's Guide - Photography Life
https://photographylife.com > Photography Tutorials
Sep 4, 2017 - The lower the ISO number, the less sensitive it is to the light, while a higher ISO number increases the sensitivity of your camera. The component within your camera that can change sensitivity is called "image sensor" or simply "sensor".
Film speed - Wikipedia
https://en.wikipedia.org/wiki/Film_speed Film speed. ... Film speed is the measure of a photographic film's sensitivity to light, determined by sensitometry and measured on various numerical scales, the most recent being the ISO system. A closely related ISO system is used to describe the relationship between exposure and output image lightness in digital cameras ... ‎Film speed measurement ... · ‎Film sensitivity and grain · ‎Digital camera ISO speed ...
What is ISO (Film Speed)? - I STILL SHOOT FILM
istillshootfilm.org/post/592532284/what-is-iso-film-speed As I explained in How Film Works, photographic film is made up of millions of light-sensitive silver halide crystals, which we call grain. The lower the film speed, ... film iso explain in digital photography Google Search
Oct 31, 2017 | Canon PowerShot Pro1 Digital Camera
I bought this canon rebel t2 film camera recently and used film with ASO 400. Portraits look ok. but the landscapes, especially the sky area look dark and grainy. I used ef 28-135mm usm lens. Any solutions...
That's odd that the pictures would be coming out under exposed unless the previous owner has gone into the camera functions and switched the ISO from auto to manual. Another reason is that the exposure compensation has been activated and set for - exposure
Under "normal" use the camera will read the DX code on the film canisters and adjust the ISO automatically. However the previous owner may have shut this off in preference to setting the ISO manually. Even though you have ISO 400 in the camera the ISO on in the camera setting may be ISO 1600.
Checking for the Auto ISO and exposure compensation is fairly easy as you can see the film canister through the film window or you know you have loaded 400 speed film. on the LCD panel at the back of the camera is an ISO icon and exposure compensation.
Make sure the ISO for the camera is the same as what you have loaded and if the exposure compensation is to the right of 0 then the resulting picture will be dark. Move this back to the Zero.
I wasn't able to find an exact manual (if you don't have one) for your camera but have found a camera with similar. Here is a ling for that manual.
http://www.butkus.org/chinon/canon/canon_eos_rebel_ti/canon_eos_rebel_ti.htm
Hope this was a help
Dec 18, 2010 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Really Grainy low quality pictures with my new camera.
Try shooting with ISO value of 200 or less; or set to "Auto".
If you're missing the manual, you can get it in English, here. Page 76 briefly discusses ISO settings. This camera can select an ISO as high as 1600. ISO has to do with graininess of film - the higher the number - the more grainy the images. Higher ISOs are selected when light levels are low and no flash is used or is usable (such as when the subject is too distant). Some photographers use higher ISO settings with high shutter speeds to stop fast moving objects (like wheels on a race car). The grainier the film, the quicker it captures light. Fime grained film takes longer to capture light.
Generally, pictures taken outdoors in sunshine look best when ISO is 100 or less. 100 is a good choice for well lit indoor pictures, too; but may be better with an ISO of 200. ISO works like this:
If a picture can be properly exposed with an ISO of 100 in 1/15 sec, it would require only 1/30 sec at ISO 200, or 1/60 sec at ISO 400. When you double the ISO value, the exposure times are halved. What's the big deal about 1/15sec, 1/30 or 1/60 sec you might ask? Easy! the picture will probably be blurry at 1/15 and even 1/30 sec exposure time, due to the camera recording even the slightest movement of your hands. You'll need to supply a tripod or do something else (such as increase the size of the opening of the aperture or f-stop) to get a properly exposed image.
I hope this helped - if it isn't an ISO problem - let me know. Good luck!
Dec 10, 2010 | Canon PowerShot SX30 IS Digital Camera
Is there a way to turn off the flash?
The flash is automatic, you cannot control the flash. But you can put some black tape over the flash if you really don't want flash. Remember though, if the camera meter decides flash is needed, then your pictures could turn out dark/underexposed by covering the flash.
The manual can be found here: http://www.olympus-europa.com/consumer/208_manuals.cfm?prodID=P_N1246352
The manual says use 100, 200 or 400 iso films.
Maybe try high iso film like 800 iso or 1600 iso, best to try this out ahead of time to make sure you are satisfied with the results. The high iso films need less light so should perform better without flash, but the camera may not be able to rate these films correctly, trial and error is definitely required.
Oct 22, 2010 | Olympus TRIP AF 60 35mm Film Camera
What does iso mean on the setup on the camera and what do i have to do to get my flash work it isn't working ?
ISO refers to the sensitivity to light of the sensor. It's like film speed ratings on film cameras (ie. a 400 speed film is four times faster than a 100 speed film). There should be a button with a lightning bolt icon on the back of your camera. Press it and watch the screen for different options for flash. Stop when you get to the "A" or "Auto" plus the lightning bolt.
Jul 03, 2010 | Cameras
How to make night photo canon 1000d but the image to be frozen?
If it's not too dark, you can try setting the ISO to 1600 or even 3200. The downside is, you'll got image noise at higher ISO (sensitivity of sensor/film).
The other alternative is using the flash. If you need to increase shutter speed beyond the capabilities of the on-camera flash in order to 'freeze' the moving subject, then use an external flash unit and set it on high speed sync.
Mar 13, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Camera won't take a picture
WHAT YOU ARE SEEING IS BASICALLY AN ERROR WARNING THAT THE SHUTTER SPEED IS NOT RIGHT FOR THE LIGHT CONDITION AND THE LIGHTNING BOLT USUALLY MEANS THE FLASH IS NEEDED. IF THIS IS A FILM CAMERA, IT IS PROBABLY WANTING YOU TO PUT IN THE CORRECT EXPOSURE SETTINGS FOR THE CONDITIONS. DOES THIS HAPPEN WITH ALL CONDITIONS? HAVE YOU TRIED OTHER SETTINGS ON THE CAMERA? LET ME KNOW IF YOU NEED MORE HELP.
ARCLIGHT1217
Nov 03, 2008 | Nikon N5005 35mm SLR Camera
Canon EOS-10S 35mm SLR Camera Logo
96 people viewed this question
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
