Question about Microsoft Windows XP Home Edition
XP running very slowly after resotring an Acronis drive image
XP Pro Running Very Slowly after Acronis Restore
I have just installed a new HDD to replace a flakey one. I used Acronis True Image to clone the old drive content, (MBR, Boot Sector and all) and after some problems getting the new drive recognised by my BIOS, I restored the Image to it and successfully booted into XP. The problem is that after the first couple of background programs load and show in the system tray, everything slows down to snails pace. Although not all such background programs seem to be loading at all, it does reach a point where I can access the Start Menu - however, it takes about 10-20secs to respond to any mouse click. I haven't successfuly opened a program.
I've cloned a drive that had no apparent problems beforehand so I'm a bit mystified. I note that Norton 360 isn't getting started, but since it's not using resources I can't see that that's the cause.
I can open Task Manager, and it shows 30-odd processes going on, but the only one using any CPU resource is "SYSTEM", which is using 99. "System Idle Processes" is using 00. Clearly something is chuntering away leaving no resources for anything else - does anyone have any ideas what it might be? Nothing seems to be occupying excessive RAM.
I can start boot into Safe Mode but reducuing the programs running at start up in msconfig makes no difference to the speed problem
Thanks in advance for any suggestions
  • berniesmith Jan 20, 2009
    Drachnem/woleryi
    Thanks veru much for your prompt responses - I'll work through both and report back here.
  • berniesmith Jan 21, 2009
    Update:
    as I'd had no software probs with the old drive, I began by rebooting to it, with the aim of scanning, cleaning and generally removing superfluous stuff before re-cloning and working through the drivers.
    On rebot, it too was very slow, although not so bad as to be unworkable. It occurred to me that my old installation of Partition Magic might be fighting with Acronis Disk Director at start up so I removed it. Uninstall was very slow initially, but once it was past the "gathering data on installation" step (which took 20 mins ! ) it sped up dramatically to completion. A look at Task Manager showed that the balance of CPU resource had moved from "system" back to "system Idle Processes". Most of the PC's general speed of resonse to inputs was restored. Following this theme, I removed Symantec/Powerquest Drive Image as I now have Acronis True Image and I think they may be fighting. Again the initial step of uninstallation was very slow but speed was restored later. I shall remove Norton for good measure and then re-clone and restore to the new HDD. I'll then run scandisk, Ad-Aware and a few others, check out the USB drivers as necessary and report any developments.
    Thanks for your interest and assistance.
  • 34 Answers
SYSTEM, is the host of most of your drivers being loaded, take off all extra usb devices you may have, then update all your system drivers thought windows, if they dont find any, go the the manufacture's site and grab them.
Also, run a virus scan if you haven't already...
Posted on Jan 19, 2009
    Scholar:
  • 54 Answers
I have seen Malfunctioning Norton Security software cause these exact symptoms many, many, many times. I would download the Norton removal tool from the symantec website and get rid of all the norton software and see if there is a drastic increase in performance. if so problem solved.
If however that is not the case you should run a Thorough scandisk (scan for bad sectors) since you said the old HDD was flakey, the cloned image can transfer file system damage that may have been present on the old drive and in some cases may worsen when transfered to a new drive. if you do find file system errors i recommend you bite the bullet and do a clean install and make sure to re partition, not just reformat.
W3400 runs very slow, 64 bit, 2gig ram xp-pro
Your hard drive has the defective, there are bad sectors already in you drive, that's why it run slowly even though you formatted it.
Mar 27, 2012 | E-Machines W3400 PC Desktop
Making alot of noise when computer is on and running
Hi ,
If the noise comes from your HDD , this is bad news because it's telling you it's about to crash .
Make an urgent back up of your entire system and install a new Hdd in your unit .
With Windows 7 , the back up is easy to create : go to Start and tic " back up entire system " and follow instructions .
In other systems , use a third party soft like Acronis from http://www.acronis.eu/promo/ATIH2011/ATISpecific/index.html?source=eu_google&ad=ati&c=6575336934&k=acronis%20true%20image&gclid=CIXL0pTM0KYCFYJH3godJ3ocRw
Best regards .
Jan 23, 2011 | Western Digital My Book Essential Edition...
Backup of hard drive
I use Norton Ghost 9 and I love it. Initially, it makes a complete image of your harddrive. I would purchase a good sized external harddrive and attach it via USB and use it as your backup drive.
Norton will allow you to schedule "incremental backups" as often as you like. I have mine set for every night at 1AM.
The biggest reason to use this system is if your C: drive fails, you can use Norton Ghost to completely restore your system from the backup image on a new harddrive and be up and running as if nothing happened within a few hours. No installing applcations, settings or anything. It's wonderful!
Aug 12, 2009 | Dell Inspiron 530 Desktop Computer...
Lost system restore functionality after installing second xp pro
My computer properties system restore check if system restore is turned off.
If yes turn on all drives and restart.
If system restore is on then you need to create a new admin account and check system restore settings.
Also you need to have 6gb of free space in windows partition
Enjoy this will solve
Feb 08, 2009 | Microsoft Windows XP Professional
Computer running real slow and then shuts down
I am guessing from the "clicking" noise that the some sort of anti-virus app trying to scan the HDD and the HDD is virus-infected. If you do not have much stuff on the PC, do you think it is possible to reformat the HDD and re-install the OS? (this is obviously last resort - I am sure expert folks here will come up with better solutions)
Aug 28, 2008 | Compaq Presario X1000 Notebook
Hdd upgrade problem
Try reversing the connections so the new drive is detected as the primary master.
Oct 07, 2007 | Gigabyte GA-7VTX Motherboard
Recovery partition - repair
You have obviously deleted the partition that the laptop could recover from but usually if you are supplied a cd to recover windows, there is normally a drivers folder within the cd but not the aplications, such as anti virus although these are only for a trial period. for things like microsoft works if supplied, are normally on a seperate cd. Without knowledge of your partition software, you should be able to partition the HDD and then copy the files from one drive to another, but the restore may not work as the system files may not weave together when you come to restore. I would imagine it's only the drivers that's youre main concern, which you can install from your other laptop.
Jan 31, 2007 | IBM ThinkPad T30 2366 Notebook
Microsoft Windows XP Home Edition Logo
146 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
