Question about Sekonic Digi Lite F L-328 Exposure Meter Flash/ambient
Sekonic L-328 Battery is fresh and all contacts are clean. Power switch also ok. But, if you turn unit off and then turn on - it remains shut down. You must eject battery and insert it back to bring it to work. I saw two seconics with this problem.
2 Suggested Answers
tbreeze47
  • 3083 Answers
SOURCE: Re: Sekonic L-328. Sometimes the
You could be having a switch problem, or another intermittent problem. Most the the switches on devices these days require that the unit be disassembled to clean them, and that's tedious. You should call Sekonic and see if they can help, or service the unit.
Good luck, and hope this helps.
Posted on Apr 21, 2011
Camera goes on and off immediately
Even though they are charged thay might have a fault. 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 26, 2010 | Kodak EasyShare M873 Digital Camera
My Kodak EasySharecamera cannot remain on. Pressing the On buttom
Camera comes on for 2 seconds and shuts off. battery charged and good condition
Here are the steps for no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 20, 2010 | Kodak EasyShare M863 Digital Camera
Camera wont turn on-batteries are OK
Here are the steps for M763 no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 15, 2010 | Kodak EASYSHARE M763 Digital Camera
The Focusing ring BUZZES and Shuts off
1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable. 4. The alternative is a repair. Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 14, 2010 | Kodak EasyShare M1093 IS Digital Camera
When turning camera on the shutter opens then shuts straight away and switches off
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 11, 2010 | Kodak EasyShare M863 Digital Camera
Kodak M1033 lens comes out but will not go back
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 22, 2009 | Kodak EasyShare M1033 Digital Camera
Kodak easyshare m340 turn on lens come out then shuts off
Dec 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Easy Share V1003 Turns on, then shuts down.
Make sure that you are installing a fresh/ full charge battery
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
Aug 23, 2009 | Kodak EasyShare V1003 Digital Camera
My camera turns on, then immedeately shuts off. I
Remove the battery
Contact KODAK:
Jul 13, 2009 | Kodak EasyShare Z885 Digital Camera
Sekonic Digi Lite F L-328 Exposure Meter Flash/ambient Logo
104 people viewed this question
Top Sekonic Cameras Experts
Are you a Sekonic Camera Expert? Answer questions, earn points and help others
