Question about Dell A940 All-In-One InkJet Printer
Offline The power went off at my house and since it came back on the Power amd Mode lights just keep blinking green. The Control Panel indicates that the printer is Offline. I have unpluged and repluged it in, restarted the computer, still get blinking green lights. Pressing the power button does nothing.
  • Rosemary Seidler Jul 02, 2007
    I bought a new printer. Thanks for all of the suggestions.
  • 624 Answers
Troubleshooting for this particular problem is fairly limited, unplugging the power for about 30 seconds and reconnecting is about all the typical user can do. Chances are fairly good that either the problem is either the power supply or a damaged electronics board. For the typical user without access to cheap spare parts your only option is to contact Dell. IF your printer is still less than one year old call support up, tell them the LEDs that light and what you?ve tried. I wouldn?t volunteer any information about what you THINK may have caused the problem, chances are you will get a warranty replacement. If it?s older than one year old then you are best off looking for a new printer. As far as surge protectors go the vast majority of those on the market, especially those under $50, give little if any real protection. At that price you should look at some of the consumer offerings from APC or Tripp lite that will protect your PC, monitor and your printer. Good luck and don?t forget to let us know what happened.
Posted on Jul 01, 2007
    Problem Solver:
  • 40 Answers
Did you have surge protection on this printer? If not, when the power went back on, the surge of current may have damaged it. Surge protection is very important on all devices with electronics in them! If it wasn't a very expensive printer to begin with, it won't be worth fixing whatever the cause. You can take it too a computer store and have it looked at, but they will charge for that, of course.
Posted on Jun 30, 2007
SOURCE:
Runco flat panel tv displays solid green then blinking red light. What doe this mean?
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 14, 2013 | Runco Televison & Video
Sharp lc-32sb220u lcd tv. Green Power LED flashes steady
Okay, I found the problem. There is a problem with the
ccfl (lamp) groung PCB. Mine is completely burnt through. I am going to attempt to repair it, but will likely need to extract it from a different unit. This board is on the front right of the lx in the lamp housing behind the
lcd panel. What is happening: The inverter circuit on the power supply is detecting that one of the lamps is not lighting and it goes into shut down.
Hope this helps!
~Seth
Feb 07, 2012 | Sharp LC Televison & Video
My hp 2360 wont print, green light keeps on blinking, it says printer offline on the printer status bar
Make sure that cable to printer is attached and if printer still shows offline then in control panel for the printers make sure that you right click and choose Use Printer Online
What the flashing light means
The Power light can flash for several reasons:
? The printer cover is open.
? The printer is out of paper.
? A problem exists with the printer, such as a paper jam or a problem with a print
cartridge.
For information
Jan 30, 2011 | HP Deskjet 2360 InkJet Printer
My vaio wont turn on and the green light in the back keeps blinki
The green light blinking in the back indicates that the power supply went bad and is not turning on, go ahead and get the power supply replaced. Normally that light is supposed to be fully lit and green.
Apr 28, 2010 | Sony VAIO VGC-RB53 PC Desktop
Power went off in house when it came back on the green light on the front panel keeps blinking will not stop Mitsubishi Bigscreen model ws- 65909
I've got a 65535. When this happens, you can sometimes press the On-Off button for 10-15 secs until the light goes off. If that doesn't work, then unplug the tv for 30 seconds or so, then plug back in.
These sets are known to have power supply issues, and the blinking light may be a coincidence to the power supply failure. It's fairly easy to repair if you know how to solder.
Dec 10, 2009 | Televison & Video
No power only plug light and battery light is on
The lights are indicators of which operation does your laptop operates.
1. Power indicator is lighten to green meaning you are in the mode of charging your power.and if the power indicator turns to orange meaning you are now using battery power or the charging is finished.
2. Reading indicator is blinking meaning your laptop is currently processing but if the Reading indicator is not blinking and made a static light then your system is in hang up or not reading the processes.
3. Wireless indicator is blinking or lighten then you are in the a wireless mode connection. Also the bluetooth and Infrared connectivity.
So please check which light indicator is lighten when you on your laptop.
Thanks
Aug 06, 2009 | Toshiba Satellite M115-S3094 Notebook
Sony Projection TV 60 XBR, wont turn on, blinking green light
This sounds like when the power came back on a surge went into your tv and burnt out the TVs main power supply or possibly burn out the flyback power converter on the TV main board!
(I am pretty sure it is either one of these things!)
Please rate answer
THANK YOU!
Jan 15, 2009 | Televison & Video
Green blinking light on Mitsubishi WS-55813 HDTV
generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Offline and blinking lights
A couple suggestions. Unplug the usb cable from the pc to the printer, make sure there is no paper jammed in the machine, unplug the machine from the wall and see if you can move the print head left to right freely. If nothing is obstructing it plig the power cord in with out the usb cord plugged in. See if the machine goes to ready. If all of these fail, that means the main board has been damaged by a power surge, and it would be cheaper to replace the machine than repair it. Good luck!
Jun 28, 2007 | Dell 942 All-In-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
69 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
