Question about 4-Seasons Oil Cooler 2001-2001 Mazda Tribute Oil Cooler, 01-01 Mazda Tribute 4-Seasons Oil
Mazda Tribute sputters in the morning on startup
V6 Mazda Tribute sputters and stalls in the mornng on startup, esp on cold days like we are having now. It runs fine and even when you give it gas, only happens on idle. Once the engine has warmed up the sputtering goes away and the engine runs great, even on idle. Already changed out the plugs and coils but no dice, still doing it every morning...... Any suggestions?
2005 mazda trubute won't start and i replace 40amp and got it work and it drive for a while and then it blow again
Mazda Tribute Questions - CarGurus
www.cargurus.com > Questions > Mazda
CarGurus2001 Mazda Tribute 3.0 Wont Start. out shopping one ... 0. Report. rebel54 asked a2005 Mazda Tribute i Maintenance & Repair question about a month ago ...
Tribute won't start - Mazda Forum - Mazda Enthusiast Forums
www.mazdaforum.com > ... > Mazda Vehicles > Mazda Tribute
May 22, 2007 - I have a 2002 Mazda Tribute V6. On Sunday it wouldn't start. ... 2005Tribute won't start! rizakag, Mazda Tribute, 4, 03-27-2006 09:29 AM ...
Why does my fuse in my 2005 mazda tribute keeps blowing ...www.cargurus.com > Questions > Mazda > TributeCarGurusSep 4, 2014 - Why does my fuse in my 2005 mazda tribute keeps blowing when I try to switch gears?Electrical problem - 2004 Mazda Tribute - RepairPalrepairpal.com > Questions > Mazda > Tribute > 2004 Mazda TributeApr 5, 2011 - Electrical problem on 2004 Mazda Tribute ... meter on the battery cable note the battery draw then remove fuses one at a ... 2005 Mazda Tribute.2005 Mazda Tribute, Fuse #3 Blows, No Tail Lightswww.sparkys-answers.com/.../2005-mazda-tribute-fuse-3-blows-no-tail.h...
Jan 30, 2016 | 2005 Mazda Tribute
Mazda tribute dies no gauges radio will start later
SOUNDS LIKE YOUR ALTERNATOR IS WORKING RIGHT CHECK THAT FIRST
Oct 22, 2012 | 1986 Toyota Cressida
2004 Tribute V6 - Airbag warning light has remained illuminated after startup on two different occasions in the past 5 days (over approximately 14 separate startups). Turning engine off, then restarting...
It could be anything from a loose wire to a component failed. Take it to autozone or similar and have them scan air bag system for codes. This is a free service. Once you have code and meaning get back to me
Jun 09, 2017 | 2004 Mazda Tribute
Mazda tribute 2001 stall hard when it's cold
I am dealing with the same problem right now. I replaced the plugs last weekend, but code still came back. It is only rough in the morning, then drives fine all day, except for the engine light being on. I'm trying to look up as many posts as possible before replacing any more parts. Please let me know if you find a solution and I will do the same
Nov 04, 2010 | 2001 Mazda Tribute
What is the best for mazda tribute 2001? v6 2wd 3L
The best battery is the biggest one that you can fit in the battery box. There is no such thing as too much battery. The one that came in your car from the factory is the smallest one they could get to do the job. Certainly you should be in the 500 CCA (cold cranking amps) range, especially if you live in a cold climate. Hope this helps.
Oct 07, 2009 | 2001 Mazda Tribute
2002 mazda tribute v6 stalls intermittently when you let off the gas pedal....seems to do it only when it is warm and again very intermittently. Vehicle has 110k for miles.
You need to have a scan done and pay close attention to the throttle position sensor and the idle air control .
Also (since we have so little information to work with) check your engine compartment while it is running and listen to see if you have a vacuum leak. See if you hear a hissing sound.
A vacuum leak will cause it to stall after it is warmed up. The computer will keep it running at a higher RPM until it warms up and with a vacuum leak it will stall when the idle comes down to the 600-700 level.
Hope this helps.
Oct 01, 2009 | 2007 Mazda Tribute
DOES THE V6 MODEL HAVE A TIMING CHAIN OR BELT?
A 2002 Mazda MPV 3.0 V6 has a timing chain
Please rate me if you are staisfied with the answer.
Sep 15, 2009 | 2002 Mazda Tribute
2002 Mazda Tribute V6 difficult to start.
IT SOUNDS LIKE THE IAC VALE OR IDLE AIR CONTROL VALVE IS BAD, WHAT YOU CAN DO IS TAP ON THE VALVE. IT IS LOCATED ON THE INTAKE RIGHT BEHIND THE THROTTLE BODY, JUST TAP ON THE SILVER PART WITH THE BACK OF A SCREW DRIVER A COUPLE OF TIMES. THIS SHOULD UNSTICK THE VALVE AND YOUR TRIBUTE SHOULD RUN. THEN IT IS JUST A MATTER OF REPLACING THE VALVE. YOU CAN GET THEM FROM ANY AUTO PARTS HOUSE.
Jun 29, 2009 | 2002 Mazda Tribute
4-Seasons Oil Cooler 2001-2001 Mazda Tribute Oil Cooler, 01-01 Mazda Tribute 4-Seasons Oil Logo
32 people viewed this question
Top 4-Seasons Oil Cooler Computers & Internet Experts
David Payne
David Payne
Are you a 4-Seasons Oil Cooler Computer and Internet Expert? Answer questions, earn points and help others
