Question about Nautilus Ntr 800 Treadmill Lift Motor
Screen says error, treadmill won't start
V-fit treadmill won't start and shows error message.
Test the power supply coming to the equipment and try again. If the problem with power is o.k proceed with LUBE very important. God bless you
Apr 07, 2013 | Exercise & Fitness
My emage treathmill won't start and it displays a FF on the screen
Hi There,
This is in need of a new console. This is the only way to fix the problem.
Dec 25, 2012 | Icon Image 17.5 S Treadmill
Sole treadmill says "INITIAL" on the screen and won't run. This occurred after I removed the magnetic emergency stop switch.
Normally you must put the key in the hole, after you press the button start and ready.
However I recommend you to follow the instr. manual for easy start. Since that every manufacturer has a little diferrent mode of start. If you do not have it download free from
www.fitness.manualsonline.com
God bless you
Dec 17, 2012 | RTO Sole Fitness Package F85 Treadmill &...
Error 1
1) adjust the speed sensor, clean it, and tight the plug very well
2) measure the input voltage motor, if there the motor need repair
see my personal TIPS
3) measure the voltage output board, for input voltage motor, if there are NOT the board is faulty.
see the diagram.
God bless you
Sep 28, 2012 | York Exercise & Fitness
My treadmill life fitness 9100HR won't start
Have you checked the drive belt @ the motor, if it is OK then check the fuse, if it is ok then the brushes in the motor may be worn out
May 04, 2012 | Life Fitness T3 Treadmill with Advanced...
My York Fitness Inspiration Treadmill won't work :(
Dear Sir:
You have a lack of power in power supply.
Attached is the block diagram for easy diagnose and troubleshooting ,see my tips for more details for to make some measure with your VOM.
Please do not by pass any c.breaker only you will complicate the electronic system.
After you see the block diagram, you can conclude if the power supply +transformer+or main mother board is faulty.
Of course ty your circuit breaker from your house, and see the ground or your outlet wall, see if there some problem to ground.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua.
Feb 18, 2012 | York Exercise & Fitness
Treadmill buttons don't work right. TV won't turn off. Treadbelt won't run.
1) Try to reconnect the plug between console and pcboard very well.
2)Clean the contacts with special contact cleanear( radio schack or computer store) with carefully only the buttons, if you can open the cover better.
3) adjust the Sensor SWITHC.
4) Look for any wire loose, or making bad contact, or break wiring( continuity) test the fuse and breaker.
If after you did those steps, and the problem persist, the console board is faulty.but first change the sensor switch, you must be shure after adjustment.11_18_2011_12_23_17_am.gif
Nov 17, 2011 | Exercise & Fitness
Treadmill won't start
Dear Sir:
I will try to help you, please follow the next step in this videos , and use the patience and carefully:
You have electrical problem
http://www.youtube.com/watch?NR=1&v=inR6gJ0_37w
http://www.youtube.com/watch?v=GdlAxZHLDys&feature=related
http://www.youtube.com/watch?v=AFuRo2zHpCg&feature=related
http://www.youtube.com/watch?v=yX_0vRPdMfU&feature=related
You must use the DVOM(digital voltmeter for to check the breaker and fuse and power cord) +Screwdriver+Hexagonal.
If you need further assistance, please reach me. Sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA.
Oct 11, 2011 | Exercise & Fitness
Nautilus Ntr 800 Treadmill Lift Motor Logo
Top Nautilus Exercise & Fitness Experts
David Payne
David Payne
Electro Med Services...
Techmotionusa.com
Techmotionusa.com
Are you a Nautilus Exercise and Fitnes Expert? Answer questions, earn points and help others
