Question about NTL VS1500 Cordless Phone
No ring on handset
The base rings with an incoming call but the handset does not. Tried to find the instruction manual OL but no joy.
  • 1 more comment
  • badger62 Mar 10, 2008
    We have an NTL VS1001 cordless pair of phones
    The main phone ie (1) does not ring, only the second phone (2) rings. Cannot find instruction book.
    Any help would be appreciated.
  • Anonymous Mar 28, 2014
    One handset does not ring when receiving an in coming call. How can I fix it?
    Can't hear incoming ringing
Http://www.telephones4u.co.uk/userguides/vs1001.pdf
Here's a full user manual for the phone.
HTH
Posted on Apr 20, 2008
It may have lost the link to the base unit. Make a note of all the personal details, stored number, etc., then reset the handset. Do this by pressing the spanner button until the display changes, then press and hold the 'R' (delete) button until the handset resets. You'll have to set it up again, but at least it will link.
Spanner then 1 for ringtone, CID for volume.
Spanner then 2 for keypad bleep, 1=off, 2=on.
both cases press spanner to confirm changes.
Posted on Dec 04, 2007
I have no ringing tone (incoming calls) on handset 1 which fits to base station. I have not lost contact with base station hence your remedy is not applicable, all I wish to know is how to get the incoming ring tone back.
Posted on Mar 10, 2008
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
Can't hear phone ringing
Adjusting the Ringer Volume (From the Uniden manual)
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
  1. With the phone in standby, press ArrowUp or Arrow Down on the handset or VOLUME + or VOLUME - on the base. The handset or base sounds the ringer at that level.
  2. Use Arrow Up on the handset or VOLUME + on the base to make the ringer volume louder.
  3. Use Arrow Down on the handset or VOLUME - on the base to make it softer or turn it completely off.
  4. When you hear the ringer volume level you want to use, stop pressing keys.
  5. The handset or base will use the new ringer volume starting with the next incoming call.
  6. If you set the ringer volume to Off, the handset or base won’t ring.
  7. Other handsets or base will ring according to their individual settings.
Jan 03, 2010 | Uniden DECT 6.0 Cordless Telephone...
No ringing tone on handset
Need a manual for Williams sonoma bread machine
Model # 2094
Ray
Sep 15, 2009 | Panasonic Cell Phones
Handset won't ring
You need to reset the main base and make sure the ringer volume is turned all the way up. Disconnect the power from the back of the main base, press and hold find hs key while reconnecting power until you hear long beep. Should reset base and handset.
Mar 17, 2009 | Uniden DECT 6.0 Cordless Telephone...
GE 28851 base handset #1, will not save ringer tone or volumn I selected. Brand New.
As it turns out, the primary base handset did save the newer selected ring tone and volume level setting.
However, the base maintains its own ring tone and volume level setting from factory.
Therefore, the base will present its own settings along with the handset setting during an incoming call.
So, one has to lower the volume of the base (in non-talk mode). The base should display in window: LO.
Then, only the ring tone and volume level selected for handset will be presented during an incomiong call.
How did I do????
Ken
Jul 09, 2008 | Uniden Cordless Phone
We have BT Studio 1100 with three handsets. From working well, they all became dead. We have changed the batteries. The phone line is working, and there is electricity reaching all the cradles which...
I have the same phone but with two handsets. Incoming calls only ring on the base and I cannot answer or make calls as the handset is permanently flassing "base 1". I have tried disconnecting and reconnecting. Also tried to restart setup but this is showing unavailable although I can still access the phone menus.
Jul 01, 2008 | Lands Phones
Uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Jan 20, 2008 | Uniden Cordless Phone
Model 28112ee2-4 dect 6.0
For the handset, you can use the menu button to check the HS Setup settings. For the answering machine, you may have pressed the side button that turns it off. It would say "off" on the lcd if you did that. According to the manual (I just bought one of these).
Dec 21, 2007 | Uniden Cordless Phone
Phone rings, but once answered its not possible to hear a voice.
Similar issue - brand new phone - but incoming calls (skype or landline) would ring - and then nothing, and outgoing calls the handset would just reset.
The handset would just lose signal constantly (less than 2 meters from the base station).
The phone shipped with the latest software - but eventually I reinstalled it - no change, then de-registered the handset, powered everything down and re-registered the handset and that *seems* to have done it .....
So
1 - reflash / re-install latest software from philips website (even if the phone already has the same version)
2 - de-register handset (follow instructions)
3 - unplug base station and remove batteries from handset
4 - turn on base station, put batteries in handset
5 - re register handset (follow instructions in manual)
and that seems to do it.
Nov 18, 2007 | Philips VOIP8411B/37 IP Phone
RCA 25450RE3 - Incoming Call Ringer Setting
try turning ringer speaker volume down. if that does not work, then remove battery for 10-15 minutes and replace and try again.
Oct 12, 2007 | RCA H5450RE3 Accessory Handset For -25450...
NTL VS1500 Cordless Phone Logo
546 people viewed this question
Top NTL Lands Phones Experts
Computer Repairing
Computer Repairing
Cliff
David Burbee
David Burbee
Are you a NTL Lands Phone Expert? Answer questions, earn points and help others
