Question about Yamaha RX-V663 Receiver
Tv speaker noise from yamaha rx-v663 hdmi connection
I am getting noise like static in my samsung 37" 1080p tv when I hook the hdmi cable from the rx-v663 to the television - if I go straight from the hd cable box to the tv over the same wire, I dont get the noise.
Is it possible that the tv cant decode multichannel audio - that is the only clue in the receiver manual ?
Thanks
  • Anonymous May 05, 2009
    I am getting this loud rumbling noise from the tv speakers during start-ups that goes away after it has warmed up. The tv speakers are inactive during use but emits only this noise when you first turn the system on for the day. If I connect the satellite box directly to the tv, there is no noise. I have tried to separate the signal cables from the power cables from the speaker cables with no success. It started out fine for about a month until the first traces of noise. Without any changes, the noise has gotten louder and longer. I run power through a Monster power strip. TV is Samsung 580 and satellite box is VIP722dvr. It' HDMI all around. Samsung has not been much help except to point the problem at the rx-v663. They may be right.
    Problem Solver:
  • 4 Answers
Try running your A/C from TV to your reciver swichd outlet sound like it could be a grounding problem.This will put all ac from same outlet to the same componets.And will elimanate any difference in potencial
Posted on Feb 23, 2009
Yamaha rx-v663. Want to watch cable tv while listening to cd (blue ray).
Don't think there is a way to make that happen with your setup
Dec 31, 2012 | Yamaha RX-V663 Receiver
Hello!!! Thanks for letting me ask these nagging questions. I bought a set of six JBL Home Theater Speakers.I did manage to have them connected and working. But I face a dilemma: How do I connect my...
You want to connect the JBL's to the yamaha using standard speaker wire. Get a few HDMI cables and run one from the blu ray to the yamaha and from the yamaha to the tv. To use the JBL's for watching tv, get an optical cable or coaxial cable (either will work) and connect that from the tv to the yamaha and you are all set.
Aug 20, 2011 | JBL Dual 8 3-Way Floor Standing Speaker...
Yamaha rx v663 video signal skipping
I'd leave it that way if it was me.
Jan 28, 2010 | Yamaha RX-V663 Receiver
Yamaha v663 HDMI port problem
There is no way to replace the port yourself, it's a 32 pin connection with wire the size of hair. You may be able to get a repair house to quote on a replacement, however pulling answers out of technicians is like pulling teeth! Check with www.yamaha.com for authorized service centers and call to ask. can't hurt.. Hope this helps. If you can't get a straight answer, send a reply, I been working with Yamaha for over 13 years now and may be able to get you some answers.
May 24, 2009 | Yamaha RX-V663 Receiver
Verizon Fios connection issue with RX-V663 Receiver
I had the same problem with RXV3900, was told by verizon and yamaha it's a software issue with the box. Verizon is suppose to be working on a new update, but no time frame for now. I'm using component to receiver, and hdmi to tv with no issues.
Mar 15, 2009 | Yamaha RX-V663 Receiver
Cannot get my yamaha rx-v663 to decode DolbyTrueHD audio of get my SBL/SBR speakers to work without turning the bi-amp on.
You should always connect with HDMI when using and decoding HD sound formats. If you use the normal digital option it will use PCM. Also check if your source is set to HD formats via HDMI connections.
Mar 06, 2009 | Yamaha RX-V663 Receiver
Xbox 360 dashboard will not show using Yamaha RX-V663
I had this issue once before, recheck all the conenctions on the tv, and make sure that the HDMI plug in for the TV * if its the older model * make sure it is placed to HDMI not TV.
Please let me know how it goes,
Thanks
Justin
Please rate me
Jan 07, 2009 | Yamaha RX-V663 Receiver
Suggestions to hook up HDMI cables
I'd suggest running all HDMI.  I believe your receiver has 2 HDMI in's and one out.  Run the out to your TV and run the components to the inputs on the receiver.  This way the receiver will control the video.  Works good for me!  Hope this helps!
Dec 27, 2008 | Yamaha RX-V663 Receiver
Yamaha RX-V663 - HDMI doesn't work.
Hi and welcome to FixYa,
Initially, a workaround:
  • as you posted, audio out of the DVD goes to the receiver;
  • HDMI out of the DVD goes to the Schaub Lorenz LCD.
Even if it were a compatibility issue or HDMI processor issue on the receiver, the above should get you going.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 19, 2008 | Yamaha RX-V663 Receiver
Audio but no video from Sony Blu-Ray w/ HDMI hookup to RX-V663
Okay...my first contribution to any forum but I have the same problem (Yamaha RX-V663 and Samsung Blu Ray) and found the solution. The problem is you probably have your HDMI cables from your DVD player and reciever connected to a DVI input on your TV. The DVI may have problems communicating--not HDCP compliant. My system was working great then I hit a button on my remote...just playing around. I think it was the pure audio and I turned off the receiver. After that, the audio worked but there was no video. After many frustrating hours, the fix was to unplug the HDMI and DVI cable then turn the power off, cycle the power again, and plug the HDMI and DVI cables back in (the DVI was the last cable plugged in, not sure if that matters). By unplugging everthing you've reset the communication between the HDMI components and the DVI TV.
See page 18 of the yamaha owners manual, second to last note on bottom right of the page. It says there may be a problem...
I also noticed that the yamaha reciever was sending 1080p (my older tv is 1080I) and that is why the video wouldn't display on the TV. You can see this in the video signal info screen, unfortunately there is no setting to switch it back, just recycle the cables and power and it should reset.
Uncredibly frustrating but I got my picture back!
Jason
Dec 01, 2008 | Yamaha RX-V663 Receiver
Yamaha RX-V663 Receiver Logo
493 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
