Question about Sonicare Philips Flexcare+ with UV Sanitizer HX6942/20
Sonicare hx9642/20 toothbrush making short humming noises and will tend to turn on on its own. How can I fix this?
    Problem Solver:
  • 8 Answers
This happened to me as well. One long, two short beeps. Incessantly. Only happens when brush is on the charger.
Try this simple fix first. Hold down the SILVER button for 5 seconds while the toothbrush is on the charging base. If the fix works, it will fix the problem immediately like magic.
If that doesn't work, try this:
1) remove brushhead.
2) use screwdriver in the base and turn 1/4 turn
3) push out assembly from the top
4) dry the inside of of the base handle. allow to air dry
5) allow the switch to air dry
6) reassemble
Posted on Jan 16, 2016
2 Suggested Answers
  • 653 Answers
SOURCE: How do I register my sonicare toothbrush
Go to the Philips website to register your product. The site link is below.
Register your Product Philips Sonicare
Posted on Jan 10, 2015
How do I get help with my Philips Sonicare toothbrush, it runs when I am not using it, how is that possible?
There is probably no fix for it, as it is not made to be repaired; if it malfunctions, you are supposed to discard it and get a new one.
However, it is likely the problem is in the switch of the toothbrush.
It may have some foreign matter inside that is causing the contacts to close when not in use, and that its why it is turning on all by itself. If you want to try something to fix it, I would get a tank of compressed air and a blower and try blowing the air into and around the off/on switch.
It might fix it, or it might destroy it.
Aug 04, 2016 | Sonicare Philips Essence 5500 Toothbrush
It is making 3 beeps and I would like to know what that means, and what I should do next.
Hi Noel:
The instructions that came with it should tell you.
I'd guess at 2 possibilities:
1) Needs re-charging
2) Brush needs replacing
Aug 26, 2015 | Sonicare Philips Rechargeable Toothbrush...
Why is it making a loud noise after reacharging,never before
Are you sure the brush attachment is "tight" to the handle? Do you have a new brush to try? It should confirm handle is bad or it is the brush attachment "tightness" .
Mar 11, 2015 | Sonicare Phillips Philips Sonicare...
My sonicare toothbrush starting beeping during the night and kept beeping.
Probably two reasons for this. 1) the contacts at the base of the brush are not clean which will prevent proper charging , the low battery beep is telling you to recharge.2) the battery needs replacing.
Sep 23, 2014 | Sonicare Philips Flexcare+ with UV...
What are the best electric toothbrushes available?
The best electric toothbrushes are the Oral-b Professional Care and the Phillip Sonicare Diamond Clean. You can find more information on these electric toothbrushes on their respected websites: http://www.usa.philips.com/c/diamondclean/289711/cat/en/ and http://www.oralb.com/products/professional-care-smart-series-4000/.
Feb 04, 2013 | Health & Beauty
Philips sonicare essence 5500 doesn't stop blinking
Turn it on and put it on the charger while still on. This should turn off toothbrush. And it stopped the blinking!
Dec 11, 2011 | Sonicare Philips Essence 5500 Toothbrush
My sonicare toothbrush won't charge
The best tutorial for repairing Sonicare toothbrushes is here:
Repairing your Sonicare
The problem is either a corroded circuit board or worn-out Ni-Cad batteries. Both repair solutions require soldering, but full repair is possible.
Sep 30, 2011 | Sonicare Philips Essence 5500 Toothbrush
Recently my sonicare toothbrush has been turning off and on by itself. Is it trying to tell me something? Or do I have a spirit in my house that happens to have really good oral hygiene?
I just got the same problem Sonicare model HX6932/10 .
It would turn on and off at random on its own. pushing power button didn't help,and usually aggravated it starting a new cycle of random spasms. I tried a "reset" by putting it on charger and holding the silver button for 5 seconds, and it would do some morse code "two short and one long" vibration and beap. And it wouldn't stop until i took it off the charger, but replacing it on the charge it would take up its signaling morse code..
I was able to fix the toothbrush by giving it a couple of smacks against the table. Holding it in my fist i HIT the bottom of it (the charging part) against the table several times.
So far it seems like the toothbrush is fixed. turns on and off when i push the button and no more wierd morse code when i put it in the charger. Just to be safe i did the "reset" again, and i this time i got the morse code "two short one long" vibration with the lights at the bottom flashing in unison, but when i let go of the silver button. the morse code stopped for good.
I think it is fixed. YAY.
update: its still a bit finicky but reseting helps (sometimes i hold both of the buttons and it does the trick - during the reset).
Dec 09, 2010 | Health & Beauty
Sonicare Philips Flexcare+ with UV Sanitizer HX6942/20 Logo
1,288 people viewed this question
Top Sonicare Health & Beauty Experts
Ted Maxwell
 steve
steve
Are you a Sonicare Health and Beauty Expert? Answer questions, earn points and help others
