Question about Samsung SP-R4232 42 in. Plasma HDTV
Samsung plasma tv hp-t5034 clicking noise - Samsung SP-R4232 42 in. Plasma HDTV
  • 35 Answers
SOURCE: My samsung plasma suddenly made clicking noises and tuned off
I wish to tell the world about the simple cheap fix for your plasma! . Please let me know if I helped. I have a 50" Plasma that deicded after a year it didn't want to turn on anymore. It just blinked red LED. Which made me see red! It took me a year to find this inexpesive fix I hope this information will be helpful to you.... These are spendy items and none of us were thinking that after a year (seems like a scam to me) the TV just won't turn on anymore.... Then they say your no longer covered under warranty or you are and they send you to some repair shop 1-2 hours away and always and I mean always tells you the part is on back order.
Lukster is right it is a power supply problem. However you don't need a new board nor do you need to pay someone a ridiculouse abount of money to fix this. I fixed mine for 40 cents.
You more than likey have bad capacitors.
Unplug the TV from power. Remove the back cover. (some models require a star srewdriver) You power supply board is right in the center. A bad cap is bulgded or raised. A good one is flat. caps have an X on the top of them. More than likely you will see a bulding or just straight raised edges on the X on the top of the caps. Cap 3300uf 10v is the ones you are looking for. Once you find them replace them with 3300uf 16v caps. If one cap is not raised replace it anyway. These caps need to be a higher voltage that why the tend to pop. 16V is plenty, don't go any higher in voltage than that.
The caps need to be soldered on. You have 2 options do it yourself or unplug all the wire harness from the board then unscrew the board take your power board (dont forget your new caps) down to a pc repair or tv repair and have them solder them on for you. It will take less than 10 minutes. I do recommend putting the board in an anti static bag. You can buy these caps at radio shack or buy them on ebay.
After you get it repaired replace your board plug all power supply wire harness back onto the board (I recommend numbering the wires as you remove them), replace the back panel cover. Plug her in and fire her up. and BAM it works. then turn it on and off a few times in complete amazement at how simple and inexspensive this was to do. Then get angry cause your repeated calls to tech support was wasted breath.
Semper Fi
Posted on Feb 07, 2009
moorah1
  • 181 Answers
SOURCE: I have a Samsung HP-T4264 plasma tv with a badly
No way, Jose!
Those bastards manufactures are always making sure you won't be able to use parts from one model to the other. Especially-display! LCD panels could be rigged, but no plazma's. Sorry!
Sell it for parts to some repair shop and get yourself LCD or LED panel. Plazma is gone!
Posted on Jan 21, 2010
  • 5 Answers
SOURCE: I HAVE A SAMSUNG 42 INCH PLASMA HD PWER WENT OFF
Sounds like power supply or control board problem. Trace down the noise and replace board. Sounds like 100-150.00 problem - hope wrong.
Posted on Feb 15, 2010
caroldon
  • 17130 Answers
SOURCE: samsung plasma 50in PS50B550 clicking noise
The clicking could be a loose connecction of the power plug or frrom the main power unit of your TV. Remove your plug and see the ends for burn outs, if so clean and use a different outlet. If not open the set after disconnection and check your main power supply unit for loose connection particularily in the surge protector, the main capacitor, the main drive, diodes or connectors. Wait to hear the sound and use a long insulated rod as a probe to confirm the origin of the sound. Solder or replace the damaged item. Hope this helps . Good day
Posted on Jul 22, 2010
electrotech1
  • 1126 Answers
SOURCE: Samsung model HP-T5054 Plasma TV
When you remove the back of the set. You will fined a couple of caps on the power supply board that are bulged and they need to be replaced, or you can buy a new power supply at www.partstore.com. If you want to just purchase the caps, you can get them at www.mcmelectronics.com
Posted on Oct 16, 2010
Will not turn on I have already replaced the Samsung plasma TV pn60e530a3fxza pwr supply
Samsung Plasma TV - Won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have Samsung 50" plasma tv model HP-S5053. The unit would not power on and blue light was out. Tried a different power source which did not change result. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
TV won't turn on
Jun 10, 2015
More results from www.cnet.com
Samsung 50 inch plasma wont turn on - YouTube
? 0:59
https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on. 8Jallin ... Up next.samsung plasma tv not working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56.
Feb 09, 2016 | Samsung Televison & Video
How to fix a 58 in plasma tv that makes a clicking noise ; no picture
SOUNDS LIKE A FAULTY RELAY HAD THIS FAULT PREVIOUSLY ON SAMSUNG -SONY-TOSHIBA
Jul 25, 2015 | Samsung PN58B560 58 in. HDTV Plasma TV
Samsung 50" plasma HPS5033X/XAA shut off and will
HGi:
This model is nortorious for Y-sustain board failure, replace the Y-sustain board and you should be good to go. The Y-sustain board is the one while standing with back off the set is the board on the left side of the television.
Jul 05, 2011 | Samsung HP-T5044 50 in. Plasma TV
Samsung HP-R4272 tv has been working fine for the past 4 years. now the tv picture is blank but the power supply is ok and the audio is fine too.
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
May 26, 2011 | Samsung HP-R4272 42 in. Plasma HDTV
Can't get my samsung hp-t4254 42" plasma tv to
make shure that the computer is set up to display on the screen. To check and see right click on your desktop, click on the option that says screen resolution, and then change your settings from their. The tv will not register that you have a computer plugged into it if the computer is not sending the tv a signal.
Mar 05, 2011 | Samsung HP-T4254 42 in. Plasma Television
My 50 inch samsung plasma tv turns off and on by itself. it also clicks while this happens.
My Samsung 52" plasma TV will shut off while watching TV. It will do it repeatedly and we have to turn it back on. Is it overheating and shuts down? How can this be fixed?
Oct 27, 2009 | Samsung HP-R4262 42 in. Plasma Television
Plasma will not turn on
i plug it back in and let it do its clicking and with in 2 min tv was working agian
Aug 01, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung SP-R4232 42 in. Plasma HDTV Logo
112 people viewed this question
Henry  Thomas
Henry Thomas
