Question about Whirlpool GHW9100L Front Load Washer
Whirlpool duet ghw9100lw2 won't start
Unit has power but I get no lights when I push the "control on" button
  • 60 Answers
SOURCE: control locked light is on on my whirlpool duet
This advice is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Frigidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your specific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks
Posted on Nov 03, 2011
watugot
  • 290 Answers
SOURCE: Whirlpool Duet won't start
Open the door and look at the latch on the right side of the opening. Just above the hole the door latch fits into is a small switch. It should be sticking out about a quarter of an inch. You should be able to push it in and out easily. It is very common for these to break. If it is broken, the door latch assy will have to be replaced. About $65 for the part. You may be able to break a round toothpick or something else about that size to use as an actuator until you can get it repaired. Just stick it into the broken switch with about quarter inch sticking out. Then carefully close door. Post back to let me know if this helps or not.
Posted on Oct 08, 2007
SOURCE: Vibrating Whirlpool ghw9100lw2
At Lowes you can purchase foam rubber pads 4"X5" pack of two for $3.50. If walking forward and after cecking level and washer pads are tight, place half of one pad under each of the two front feet. Place the sticky side against washer feet. Solved my problem.
Posted on Feb 15, 2009
  • 1294 Answers
SOURCE: i have a front loader whirlpool duet #ghw9100lw2
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Posted on Apr 08, 2009
marka19
  • 1430 Answers
SOURCE: Whirlpool Duet washer stuck in "control locked"
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
Posted on Nov 26, 2010
Whirlpool duet washer won't start
Hi Danielle_347 ;
My husband is a sales manager of a large appliance store he said
he thinks this is what may wrong ; You have either one or two buttons
on the washer that says control lock (not the light - a kind you can push
in) If you can find it hold it in for 3 seconds this should do it. If not or
if you cannot find it he said please put the model # up because
different models have different solutions. I Really hope It works.
Sorry I can't do videos.
Apr 19, 2013 | Washing Machines
The light on my whirlpool duet dryer keeps blinking on all settings, won't start
push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Mar 18, 2013 | Dryers
Whirlpool dryer duet... the control lock light is on and the dryer won't work
this is the car and truck section - you may want to repost this in the dryer section
Aug 28, 2012 | Cars & Trucks
The Whirlpool Dishwasher GU 2400 won't staart
Sometimes I have to push the cancel button on my Kitchenaid and start over and push the selection buttons again. and then push start. Don't know if this will help.
Jan 07, 2012 | Whirlpool Dishwashers
Model #GHW9100LW2. Control lock light is on and i do not have a manual. How do I turn off the control lock so I can run the machine?
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however, your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE /CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Whirlpool Washing Machines
My Whirlpool Duet dryer has the "Control Locked"
Hi
To unlock it press the END OF CYCLE SIGNAL button for 15 seconds and the unit will reset.
Dec 31, 2010 | Whirlpool GEW9250 Electric Dryer
The unit is a duet dryer ser#wed9200sqo unit will not heat up
my whirlpool dryer duet model wed9200sqo, everything comes on but when i push the start but it just makes a sound like like it want to start but won't, would i need to put a new start switch in it?
Mar 18, 2010 | Whirlpool WED9200SQ Electric Dryer
Whirlpool washer model number GHW9100LW2,SER# CSR2021497
Central Control Board part 8182221. You can go online repairclinic.com to order parts.
Good luck
Jun 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet model number GHW9100LW2-control lock button stuck on red, cant do anything else. Tried pushing the pause cancel button nothing......An ideas? Thanks!
Press the "End of Cycle Signal" button, the last button on the bottom right, for 5-10 seconds. That should resolve the problem.
Uppi
Sep 07, 2007 | LG WM2077CW Laundry XL Front Load...
Whirlpool GHW9100L Front Load Washer Logo
78 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
